Slime tubes
Slime tubes
Old 04-26-11, 06:30 AM
NCMTBIKER
Double Rainbow....
NCMTBIKER's Avatar
Bikes: 2012 Trek/Gary Fisher Wahoo 29r Hardtail
Slime tubes
Anybody use the slime tubes?do you like them. Do they work?? Thanks
NCMTBIKER is offline
Old 04-26-11, 06:59 AM
Bikedued
Bikedued's Avatar
Quoted: 160 Post(s)
Liked 29 Times in 23 Posts
They work great at trying to seal up the air valve? Yes that means you have to unscrew the valve core, and stick something down in it so you can put air in the tube. And they make a MESS if the tire ever blows off the rim during inflation. Plus they weigh alot? You're better off and lighter with a flat protected tire.,,,,BD
So many bikes, so little dime.
Bikedued is offline
Old 04-26-11, 05:44 PM
shenny88
They suck, and they wont seal a puncture for you either. They just make a mess in the process.
shenny88 is offline
Old 04-30-11, 08:13 AM
RIC0
PBR Racing
RIC0's Avatar
Bikes: Santa Cruz and Cannondale
I buy regular tubes and put slime in them myself I think the tubes that come with slim have way to much in them. I've been running tubes with slim for 4 years now and they work great for thorns. Never had a problem with it sealing up the valves either.
Too much slim will also throw the balance of the tires off, you don't need much slime for it to be affective.
RIC0 is offline
Old 04-30-11, 08:22 AM
gbg
I put some in for a friend and he got the tubes that were prefilled.
I bet they were 1.5 lbs each, WOW were they heavy.
I manually filled some of mine but found out they don't work in freezing temps,
they cause leaks at the valve when it freezes.
gbg is offline
Witterings
General Cycling Discussion
13
12-28-17 11:49 AM
ModeratedUser
Road Cycling
5
12-25-14 09:35 PM
sleazyrider46
Bicycle Mechanics
22
12-24-14 06:14 PM
AMusingFool
12
09-04-14 09:43 PM
FixedAgenda
Singlespeed & Fixed Gear
6
01-19-11 05:24 AM
