12spd SRAM Cassette no room for 12th gear chain
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
Bike: Fargo 2021 XL Frame
Problem: SRAM 12spd cassette on SRAM XD driver hub, see pic- no clearance for the chain between 12th gear cog and alternator drop-out!. Can't get the chain on that cog!
Notes: I have a separate wheelset with a Shimano 12spd on a Microspline- no problem. There is enough room with that combination wheel/hub/cassette.
Whats the root cause? solution? What to look into? Thanks in advance.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
The only thing I can think of is you have the wrong axle cap on that side. And what is an 'alternator drop-out'?
Quoted: 198 Post(s)
Liked 332 Times
Replace my term "Alternator Drop out" with "frame seat/chain stay axle interface". The Fargo just uses a separate bolt-on piece here that is removable for different options, like for adding a Rohloff hub and Gates belt drive.
Bikes: lots
Liked 2,932 Times
I know it's a thru-axle. There has to be some kind of end cap on the axle to screw into the dropout...not the 'frame seat/chain stay axle interface'.
Quoted: 198 Post(s)
Liked 332 Times
Wondering why this is no issue at all with my other wheelset with the Shimano 12spd cassette? Maybe I do need to add a spacer on the SRAM cassette where it interfaces with the alternator bracket to get the clearance I need?
Bikes: lots
Liked 2,932 Times
Alternator bracket...please, stop with that crap. Post a photo of the DS of your wheel, that'll help.
Expired Member
Quoted: 3637 Post(s)
Liked 5,314 Times
If you don't get an answer, I'd suggest swapping back and forth between your two wheelsets and maybe you can see what's different. Also, support@salsacycles.com Please update when you get it resolved.
Likes For shelbyfv:
Quoted: 835 Post(s)
Liked 1,053 Times
I agree with cxwrench that you're missing an axle cap. Novatec website doesn't offer much info on axle configuration so contact them and ask or visit your LBS with the wheel. Contact Us – Novatec 2021 (novatecusa.net) A photo of the drive side of the hub/wheel removed from the bike so we can see the axle would be helpful.
Likes For Crankycrank:
Quoted: 198 Post(s)
Liked 332 Times
Thanks guys, I will try to provide some Drive side pics later today and than will check out the link at Novatecusa you sent!
Liked 2,910 Times
remove the cassette & remove the spacer. If that change enables an open space, try a thinner spacer if still needed to torque it back together.
-Oh Hey!
-Oh Hey!
Sram road axs cassettes only fit on an xdr freehub body, not an xd. An xd mountain bike cassette will fit on an xdr freehub body if a 1.85mm spacer is added.
Quoted: 198 Post(s)
Liked 332 Times
OK, did some measurements and took some pics.
The Novatec hub (SRAM cassette) wheelset is -2mm offset on the drive side compared to my Hope hub (Shimano cassette) wheelset. I took measurements with a caliper on both the drive side and disk brake side. My caliper's batteries were dead so I rounded to the nearest mm which is about the best I could read. illustrated here:
Here I used the Thru Axle to align the wheels looking at the drive side, left a gap between them
Drive side of Novatec hub wheel:
Drive side of Hope Hub Wheel:
Quoted: 198 Post(s)
Liked 332 Times
Quoted: 198 Post(s)
Liked 332 Times
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 741 Times
So much talk, so little measuring!
What is your dropout width?
What is the width of those wheels?
It's not going to solve your problem, but would be good to know ..... Looks like your frame is 148mm wide as far as I can tell from Fargo website.
Likes For trailangel:
Quoted: 4195 Post(s)
Liked 2,911 Times
That ~2mm difference. Are you sure that there isn't a 1.8 mm spacer behind your SRAM cassette that shouldn't be there?
Likes For himespau:
Liked 6 Times
that very well could be the answer. the difference in width of XD vs XDR drivers is 1.8mm and when you buy a new MTB cassette they now come with a 1.8mm spacer to allow them to fit on an XDR driver.
Likes For onitsuka_luv:
Quoted: 198 Post(s)
Liked 332 Times
Yeah that could be the case, I will remove the SRAM cassette this weekend and check for that spacer and eliminate if it exists than report back.
Thanks everyone!
Thanks everyone!
Likes For Toadmeister:
Quoted: 198 Post(s)
Liked 332 Times
Liked 2,910 Times
Likes For Troul:
Quoted: 198 Post(s)
Liked 332 Times
Pulled the cassette off tonight And reviewed the cassette and XD hub. Reinstalled and tightened down good. Guess what? I got the correct spacing now!
Root cause:. Cassette not properly tightened/engaged on hub. This was my first XD hub, so I'm learning!
Appreciate everyone's input and feedback. Really helps to bounce my problems off others who are knowledgeable.
About the 1.85mm spent spacer. That's included with xdr freehub bodies, so an xd cassette can be used. An xd freehub body cannot be used with an xdr cassette.
Likes For DaveSSS:
