Child Seat Compatibility
Hi,
I have a Trek Marlin 5 (2017) mountain bike. I want to install a rear mounted child seat for my 18 month old.
I'm not sure whether the bike is compatible with frame mounted or rack mounted seats. The bike has brake discs.
Quoted: 1815 Post(s)
Liked 1,693 Times
According to Trek, the bike has rack and fender mounts. If you can install a rack you should also be able to install a child seat using the same mounting points
Likes For alcjphil:
Quoted: 1074 Post(s)
Liked 295 Times
Depends on where the caliper is mounted. If the caliper is on the topside face of the chainstay, then you should be able to use a regular rack. If the caliper is on the topside face of the seatstay, you may need a disc brake specific rack.
I was hoping to install a frame mounted rack to be honest as I'd read that this is the preferred option. But I take it that's out of the question
Liked 295 Times
Yours has the caliper on the top of the seatstay. As such, you’ll need a disc-brake compatible rack.
Likes For Fernagx:
Bikes: 1990 Trek 850, 2005 Cannondale R1000, 2019 Cannondale Topstone 105
Quoted: 26 Post(s)
Liked 35 Times
I have the Hamax Sleepy (lower tier model than the Caress) and am super happy with it. The only thing I'd double check is (based on a quick Google search) it appears that the Marlin has quite a steep seat tube angle. Since the seat tube angle is what determines the child seat angle, I'd double check that it still fits.
