Wood BB and alloy crank bolt?
Quoted: 5888 Post(s)
Liked 3,471 Times
Phil Wood BB and alloy crank bolt?
I recently picked up a 1971 Witcomb. It has what I believe to be a Phil Wood bottom bracket. I've never taken one apart so I wanted to ask if it is a Wood before buying the tool to take it out.
Also the bike has very light weight crank bolts that I believe are aluminum alloy. Was that a "thing" BITD? I've never seen one and it seems like a stupid place to save weight but there you have it.
Quoted: 809 Post(s)
Liked 1,022 Times
Oh, you got me. Good tittle. I was expecting some sort of wooden bottom bracket. The bolt looks like it is cadmium plated steel. Use a magnet to be be sure it is steel.
Likes For PilotFishBob:
Liked 3,471 Times
It's too light to be steel. It is painted but perhaps it's ti. I need to track down a magnet!
Liked 3,471 Times
lol, good point. A wood BB (as opposed to a phil wood) would have been an awesome find. I need to find a way to change the thread title. In the meantime, it's good click bait, right?
Likes For bikemig:
Quoted: 4722 Post(s)
Liked 3,036 Times
Yes, aluminum crank bolts were a weight weenie item. You would install the crankarm using the stock, steel bolt, then remove the steel bolt and replace it with the lighter aluminum version.
Likes For T-Mar:
Liked 3,471 Times
Likes For bikemig:
Quoted: 809 Post(s)
Liked 1,022 Times
I thought it was a clever tittle. It got me to look right away.
Perhaps this is gold anodized aluminum bolt. That is beyond weight weenie! I think that T-mar's advice is good. Install with a steel bolt, replace it with the gold anodized bolt, weigh the bike and then immediately replace again with the steel bolt. Is the spindle hollow?
Ok, I believe following T-mar's advice would work, but I wouldn't ride with the aluminum bolts.
Likes For Velo Mule:
Quoted: 1639 Post(s)
Liked 829 Times
Just remember not to torque down the aluminum bolt too hard or risk the head cracking off on you....
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Liked 3,471 Times
Friendship is Magic
Bikes: old ones
Quoted: 26413 Post(s)
Liked 10,379 Times
...it's sort of interesting it has that lock ring on there. I don't know any way for sure to distinguish the Phil Wood BB without trying a tool in there. I think it has something to do with the number of splines. If it's not Shimano or Campagnolo, the only other thing I encounter here is the Phil Wood BB's .
Liked 3,471 Times
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Anyway to take it into local bike shop? If you have a good relationship with the mechanic, they may let you use the tool for free.
Likes For mkeller234:
Likes For crank_addict:
Quoted: 3464 Post(s)
Liked 2,829 Times
Looks like a Phil to me, or at least Phil rings.
I have been surprised before!
Those are Arnold Industries aluminum "retaining" bolts.
Attach the cranks with a steel bolt, remove then install to retain the arms, do not try to set them with those.
They WILL break.
Don't be afraid of them.
Knowledge is power
They are 70's Cool.
They WILL break.
Knowledge is power
They are 70's Cool.
Likes For repechage:
Liked 2,829 Times
Looks like a Phil to me as well, BUT, the vintage Phil bottom brackets had asymmetrical spindles and the both sides of the rings would have been flush with the edge of the BB shell. There would not have been room for a lock ring on there. I suppose this could be relatively modern Phil Wood that was put on much later; it's possible. I don't remember the red bearing, but it's been a long time. Modern Phil bearings are not red.
FWIW, there were quite a few lesser known sealed bottom bracket BITD. This could be one of them. That makes more sense to me. Maybe some of them were designed to use the Phil spline standard. OR it could be Phil Wood rings on some other BB, as suggested above. With current info, that would be my best guess.
I'm not at home so I can't check but IIRC Phil tools have 18 teeth and the Shimano BB tools have 20 teeth.
Bikes: Indeed!
Quoted: 1507 Post(s)
Liked 3,474 Times
The Phil tool has 18 teeth that should slide into 18 slots in the "cup." It is darned close to 30mm in diameter. (My digital calipers are broken)
Brent
Brent
This Phil BB posted on Velobase looks like a match. It has a symmetrical spindle and red bearings. Was this a really early one? Anyone know? By the time I was working on them a lot they were asymmetrical and neither the adjustable or the drive side cup/ring protruded past the BB shell. No lockrings at all.
It's kind of funny that there is a steel lock ring on that cup, considering the crank bolts are aluminum.
VeloBase.com - Component: Phil Wood (Cartridge Bearing)
(Image pilfered from above Velobase page)
Addendum. OK. Looks like this was the original design from the first year of production in 1972. Makes sense. Phil Wood didn't make them this way for very long.
Liked 3,471 Times
They WILL break.
Knowledge is power
They are 70's Cool.
They WILL break.
Knowledge is power
They are 70's Cool.
https://www.ebay.ie/itm/Arnold-Indus...-/133351857704
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
Somembody was closing out ti crank fixing bolts for 10.00. I bought a couple of sets and they work well. Of course i tighten with steel and really cant tell the diff on my touring bike.
Liked 3,471 Times
Wait you use these on your touring bike? Brave man. Tell me that at least you cut your toothbrush in half.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Phil didn't use lockrings either, but that could have been an end-user modification.
The bolt looks like Arnold Industries' gold anodized aluminum crank bolts:
Liked 2,829 Times
I would buy a Phil form factor remover if I did not own one...
(reminds me that I need to buy a 4 prong Winner Pro remover... I did find my three prong TDC..., two prong Suntour "perfect" Regina, Phil "atom" form factor... and a number of others... One always needs the next one on the shopping list)
