Tubes, really? 2 rides 2 flats
Bikes: 2010 Fuji Absolute 3.0 1994 Trek 850
Quoted: 762 Post(s)
Liked 555 Times
really just a rant but, 2 new michelin tubes. 1 failed before the ride, the other at mile 16. Both where the stem attaches
had probably been over year with no flats, so guess I'm due
you got tube recommendations?
thanks
thanks
Habitual User
Quoted: 4943 Post(s)
Liked 8,083 Times
These things are rarely tube issues. If the punctures were in the same spot, I suspect there's an issue with the rim. In your case, check the stem hole for anything sharp or unusual. Sometimes, the rim tape will shift a little when you're putting things back together, and expose a sharp edge that cuts the tube at the base of the stem.
Quoted: 1943 Post(s)
Liked 2,164 Times
Lol! Can’t help you on that one. I only buy Michelin Airstop butyl because they have held up better than anything else I’ve used.
John
John
Likes For 70sSanO:
Quoted: 762 Post(s)
Liked 555 Times
Likes For Flip Flop Rider:
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,217 Times
Stem failures are due to user error more often then not. Are you using a handheld mini-pump or frame pump? Pumping at 90° to the stem can often put stress on the tube connection, especially if you have to pump a whole lot like you do with many mini-pumps. A floor pump at home greatly reduces the stress on the stem. A pump like the Topeak Morphs does the same on the road.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 1062 Post(s)
Liked 665 Times
Agreed, and I think the hose is the key. The last mini-pump I bought was one that came with a little hose, for that reason. I don't have a lot of stem failures any more, but because I patch my tubes, stem failures are practically the only failure mode, so I notice them when they happen.
Liked 2,967 Times
a slightly too short of a stem can induce premature failure from an inflation device that has a poor connection; requiring firm force during the use of a handheld pump.
idk if it is just me, but it grinds my gears when a rum hole has sharp edges (burrs) that can cause a flat or factory debris rattling around within the double wall (that too, can cause a flat) . WTF is the QA inspection?
-Oh Hey!
-Oh Hey!
Quoted: 1819 Post(s)
Liked 1,693 Times
I had a failure of a Michelin latex inner tube at the stem a couple of years ago, but that inner tube had outlasted 2 sets of tires and was well into its third when it happened.
Quoted: 762 Post(s)
Liked 555 Times
I'm the user, so the error I'm sure is with me
lots of ding dings here..stem was very short on both tubes, and the pump connects at a 90 degree angle to the stem. It's a floor pump. And the rim tape is old
Over the hill
Quoted: 996 Post(s)
Liked 1,204 Times
All of the suggestions above are great, but I'll add one more by asking how old are the tires? I always start to get frequent flats when a tire starts to wear thin and lose its puncture resistance.
It's like riding a bicycle
Quoted: 4227 Post(s)
Liked 2,488 Times
I've noticed that there is a difference in quality between different brands of tubes...One time I bought a couple of very cheap tubes, they cost $ 2.99 and everyone of them failed while brand new while I was inflating it...This never happened to me with more expensive brands of tubes.
Liked 2,488 Times
Quoted: 1743 Post(s)
Liked 1,281 Times
I've given up on tubes. More trouble than they're worth. The other day I changed a tube for a friend. As I was tightening it the stem just snapped off in my hand. WTF. I've got 3 years on tubeless and no flats or hassles.
Likes For Toadmeister:
Liked 4,217 Times
Sometimes. But more often than not, it’s a user error problem.
Stuart Black
Stuart Black
Quoted: 762 Post(s)
Liked 555 Times
put on new rim tape. Very lightly sanded the edges of the hole. New tubes coming in the mail tomorrow
while I've got you here, the tires are 26x1.50 Schwalbe marathons. Tubes were sized 1.0-1.5
rims are from 1994
thanks again guys
rims are from 1994
thanks again guys
climber has-been
Quoted: 3427 Post(s)
Liked 3,562 Times
1. You were tightening the valve stem?
2. The stem broke in two, or
3. The stem broke away from the tube, in one piece?
Likes For terrymorse:
Cheerfully low end
Quoted: 645 Post(s)
Liked 1,044 Times
Are you using Presta valve tubes in rims with the wider 10mm hole for Schrader valves? That might increase the likelihood of failure. Some of my 26er wheels use Schrader rims and I added those little adapters made by Wheels Mfg. That seems to reduce the chance of a sharp edge damaging a tube.
Otto
Otto
Over the hill
Quoted: 996 Post(s)
Liked 1,204 Times
My guess is the nut that holds the stem in place, but that just goes back to the user error comment because it should never be that tight (and is not really needed at all).
Likes For urbanknight:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2579 Post(s)
Liked 5,636 Times
Who you calling a ‘rum hole’ buddy!? And I believe you need a different forum to discuss the, ‘premature failure (of) an inflation device’.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Liked 1,281 Times
Valve core actually. Broke off in my fingers as I was tightening it down. It hadn't fully seated. I've never had that happen in 40 yrs of cycling.
Over the hill
Quoted: 996 Post(s)
Liked 1,204 Times
Couldn't that happen on a tubeless setup as well? (Seriously asking because I have yet to use tubeless, but they still have a presta stem, no?)
Liked 1,281 Times
I don't know. Although the stem/valve core are not a part of the tube with tubeless. And. as I'm sure you know, not all tubes are of equal quality.
climber has-been
Liked 3,562 Times
I've never thought of that failure mode from CO2 inflation, but it makes sense.
I try to position the cartridge vertically, with the nozzle at the top. That reduces the chance that liquid CO2 gets squirted into the tube, where it then can evaporate (and make stuff really cold).
At least I think that helps.
