Do I need a washer between this rack and the frame?
Bikes: 1997 Lemond Zurich, 1987 Schwinn Prelude, 1974 Schwinn World Traveler, 1999 Bianchi Campione, 1990 Specialized Stumpjumper, Schwinn High Plains
Quoted: 46 Post(s)
Do I need a washer between the front rack attachment point on the frame and the bicycle rack? The bike comes with a bolt, lock washer and a washer installed because I guess it looks nicer that looking at a threaded bare hole. When I purchased the basket another washer wasn't provided so I'm assuming I don't need to go out and purchase additional washers. I want to check with you guys to make sure I am installing the washers in the correct order. I plan to install it this way: allen head bolt > lock washer > washer > backet arm > frame. Is that the correct way to attach everything?
Quoted: 5224 Post(s)
Liked 3,581 Times
no & yes. your plan sounds good
Quoted: 1438 Post(s)
Liked 1,092 Times
Earn style points for greasing all threaded fasteners, they will drive easier and remove easier. Properly-torqued fasteners tend to stay put better but you should check periodically, rack hardware especially.
It looks as if the end of the strut may interfere with the weld bead, I would hit it (the strut) with a file if that was the case, so that the strut sits square against the mating surface.
Likes For dsbrantjr:
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
AS stated the weld looks to stand proud of the mount. You may need an additional flat washer between the frame and rack strut to gain clearance of the weld if you'd rather not file the strut.
I personally use blue loctite on rack mounting bolts as they tend to loosen on our crap roads.
Likes For dedhed:
Quoted: 965 Post(s)
Liked 1,629 Times
Wow... Great observation, I did not see that. Ya might want to consider adding another washer. What ever the case I would certainly cut out a small piece of clear Gorilla tape and put it over the hole to maybe add some paint protection properties...
Likes For zandoval:
SE Wis
Liked 3,390 Times
I wonder why they welded it on that side instead of just top & bottom.
Quoted: 536 Post(s)
Liked 415 Times
Lock washers are usually not supplied or required.
But you can do whatever you want, there is no harm in adding extra things to the fastener, including blue loctite.
I install a lot of used racks onto bikes, and the only new fastenrs I provide are the M5 or M6 hex bolt with one washer.
Quoted: 2604 Post(s)
Liked 1,928 Times
The only thing I'd be concerned about is to make sure your bolt is long enough to have adequate threads in the frame when you've got however many washers you choose and the rack in between.
Likes For pdlamb:
Quoted: 6193 Post(s)
Liked 4,808 Times
You can file the weld, but then you mess up the paint. I'd put as many washers as it takes on the inside of the rack arms to keep them off the weld. And buy a longer socket head cap screw if necessary.
Liked 3,581 Times
A year ago I put fenders and rear rack on my new bike. In places where any metal would have been touching painted parts of frame I used fiber washers in between. Pretty thin, tough and come in a variety of sizes. Home Depot has a good supply, probably the other home improvement stores too.
Quoted: 536 Post(s)
Liked 415 Times
I don't do this to bikes I flip, I don't bother to do this with my own personal bikes, but it definitely works and does not compromise a fastener in anyways to those that want it.
Some folks use pieces of inner tubing, but it's too thick and too soft, but works somewhat if everything is tight enough.
Likes For guy153:
Likes For soyabean:
SE Wis
Liked 3,390 Times
Quoted: 536 Post(s)
Liked 415 Times
Folks that don't do any MIG/TIG weld just never get it.
The thicker and more weld there is, the stronger. That's why it's so apparent at the tube butts.
When you can't see any welds, it may as well been glued there with epoxy.
Quoted: 536 Post(s)
Liked 415 Times
These are photos of eyelets used to keep rear panniers balanced, they do not take load, as it is the axle eyelet boss taking the weight.
The OP shows an eyelet for a front pannier rack which is constantly stress twisting and turning from just steering alone.
Quoted: 198 Post(s)
Liked 52 Times
"redneck" is also stacking washers. washers have the potential to introduce slip, and sometimes that's not desirable. consider buying an assortment of spacers in plastic, nylon, or aluminum. they're helpful to have around.
Amazon.com: EEEEE 151pcs Nylon Spacers Round Plastic Spacers Wall Plate spacers for Screws Hardware spacers Standoff Assortment Kit, OD 11mm ID 6.2mm Length 3mm 4mm 5mm 8mm 10mm 12mm 15mm 18mm 20mm 25mm for M6 : Industrial & Scientific
Quoted: 321 Post(s)
Liked 263 Times
OP's frame is aluminium where usually everything is just actually welded. It would be perfectly strong enough to have left gaps at the sides, but it looks a bit sloppy.
Quoted: 321 Post(s)
Liked 263 Times
But aesthetically speaking not welding all the way around those rack mounts would look a bit Walmart to me.
Quoted: 536 Post(s)
Liked 415 Times
The weld bead on the front of those eyelets are no larger than the beads on the frame of the bike, so that is acceptable.
An exceptional amount of stress will be there for this pannier rack or basket in the front because it's to be mounted entirely on the tube only, unlike the usual stays to distribute weight onto the fork as typically expected. It's basically an apartment patio that is hanging entirely on the ledger with nothing underneath.
Quoted: 321 Post(s)
Liked 263 Times
Which is what you would expect on something like outdoor steel patio chairs or the sort, just a few welds here and there.
