Frame blocks and chrome.
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
My son has an old chrome paramount with a dented top tube. The dent isnt any real problem but I do have an aluminum block set that would fit it. I know frame blocks will remove paint but does anyone know how chrome fares under these circumstances?
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 387 Post(s)
Liked 692 Times
In my experience, chrome plating is prone to brittleness and cracking, depending on the plating thickness. I don't think the plating would emerge unscathed, but I can imagine that a top-of-the-line frame like the paramount likely received a decent thickness to the chrome in those days.
Likes For panzerwagon:
Quoted: 753 Post(s)
Liked 737 Times
I've used home made maple blocks to roll out dents, and managed to keep the paint damages minimal. The blocks were quick an dirty with a rough surface in the bore. I used lots of grease and stopped when the clear coat showed damage but not the paint underneath. You can buy maple frame blocks that have a much better fit and finish. Thats what I would try.
Likes For bark_eater:
Bikes: a couple
Quoted: 563 Post(s)
Liked 862 Times
Quoted: 874 Post(s)
Liked 2,287 Times
I’ve never done any of that. The chrome could crack which could cause peeling to occur, but the surface is much harder than paint.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times
Unless the dent is really large, personally I would deal with it by putting a decal over it. Regardless of the how well the dent is "rolled" out it will still leave a slight impression in the tube and a decal will still be necessary to "hide" it.
Using blocks, even if soft runs the risk of marring the finish.
JMO, Ben
Voltaire
Voltaire
Likes For xiaoman1:
ambulatory senior
Liked 3,661 Times
Well I think we will leave it be! Thankyou for all the input.
Crawlin' up, flyin' down
Quoted: 1025 Post(s)
Liked 2,525 Times
Is the dent where the bars could have come around and smacked the top tube? BITD, many riders would hide (or prevent) such a dent by wrapping some bar tape in the strategic spot. I'm guessing your son's chrome Paramount has red decals, so some red bar tape (cloth, please) would look spiffy and period-correct. For a more low-key approach, Newbaums makes a gray bar tape that should be more subtle without being too matchy-matchy.
Or just leave it alone. That is absolutely a valid option.
Likes For bikingshearer:
ambulatory senior
Liked 3,661 Times
It's actually farther back on the top tube. Kind of hard to understand how it happened but the bike is 50 years old,
Likes For oneclick:
Liked 2,180 Times
Well, since there are questions about the location of the dent...why not post a picture?
Best, Ben
Best, Ben
Voltaire
Voltaire
ambulatory senior
Liked 3,661 Times
The day I picked it up in August I think. The dent actually is way less noticable in person.
Bikes: a few that I can't recall
Quoted: 344 Post(s)
Liked 300 Times
That would be a tricky one to roll out...but if the chrome didn't crack will being dented, the chrome is probably NOT going to crack when rolled.
Likes For Reynolds 531:
Liked 2,180 Times
JM2C's, Ben
Voltaire
Voltaire
Likes For xiaoman1:
Liked 2,525 Times
Yeah, if a handlebar did that, it would have to have been a reeeaaaalllly long stem.
Old bikes, Older guy
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 251 Post(s)
Liked 167 Times
Personally, I wouldn’t mess with it. If you decide to roll it, the maple blocks are probably a better option. Less chance of marking the chrome.
Cheers,
Van
Cheers,
Van
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
Likes For Senior Ryder 00:
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 164 Post(s)
Liked 102 Times
Is there any way to pop out the dent from inside the tube? It almost looks like you could slide something into the top tube from the seat post opening.
Quoted: 753 Post(s)
Liked 737 Times
I've never heard of anyone trying this, but if you got a longer aluminum tube with an inner diameter that matches the bikes top tube and an outer diameter that matches a larger aluminum frame block, you could cut the aluminum tube in half, put it over the top tube, secure it with pipe clamps so it wont rotate, and then roll the assembly with the block, there would not be any rubbing on the top tube.
Liked 2,180 Times
Trouble would be getting the stock inside the tube......125 to 200 and maybe "paint-less" dent remover would do it, but tube stock may be too thick for it to work.
Tape and Go would be my Motto...it will never be perfect!
Voltaire
Voltaire
Likes For xiaoman1:
Bikes: '85 Schwinn Madison, '46 Higgins Ultralite, 1950s Wally Green, '85 Trek 660, '82 3Rensho Export, '90 Trek 970, '91 Schwinn Paramount, '78 Dawes, '78 Trek 730
Quoted: 77 Post(s)
Liked 256 Times
I have wrapped a single layer of painters tape over a painted tube, then used frame blocks lubed with marine grease to roll out a dent, with out marring the paint. I have significantly improved dents, but never completely removed one.
I also removed a dent in a chainstay near the bottom bracket. I inserted a socket close to the diameter of the tube into the stay, then used an allen wrench to load the end of the socket against the dent and pushed it out.
I worked at an aviation plant at one time, we had this tool which had hydraulic lines with different size balls on the end to feed into a tube and hydraulically expand to the dent from the inside.It worked, but we never implemented it due to quality concerns with cold working a tube. I tried to find details on it unsuccessfully.
Likes For brewerkz:
Quoted: 77 Post(s)
Liked 256 Times
I would think something like this could work, if the tube openings at the seat tube, steerer tube are same size as the tube - install a ball or bullet and pull it thru with a cable.
https://www.flight-mechanic.com/rigi...nd-inspection/
Likes For brewerkz:
Bikes: 80s Alan Super Record, 79' Somec Special, 90s Rossin(?) Columbus Ego Triathlon, previously: Bianchi SBX Reparto Corse (stolen) and so on...
Quoted: 391 Post(s)
Liked 812 Times
These guys roll out a dent on the chain stay of a Team Mongoose bmx which seems to be chrome. Not a proof that the same happens to your TT but in theory it might work.
Likes For Lattz:
Liked 2,180 Times
https://youtu.be/Lvhdp-kKyYo
Great video.....but, the dent is still there and most likely all dents that are rolled out will still have a small dimple left. In order to get the dent completely out, force must also be applied to the other side of the dent......the "bump" in the bumping dolly.
Dent less paint uses a similar type of pressure behind the dent. Cups can work if there are no creases in the metal AND if it is thin enough etc.
Depending on the type of dent, sometimes heat can also be used but chrome and paint are damaged in the process.
Best, Ben
Voltaire
Voltaire
Likes For xiaoman1:
Quoted: 391 Post(s)
Liked 812 Times
Hey Lattz,
Best, Ben
Best, Ben
Likes For Lattz:
Liked 2,180 Times
Agree with you Ben its not a perfect solution, my intension with the video was rather '"just for the record, its possible with chrome" than "watch and follow." I personally would not touch that dent with or without wooden blocks but it's me. However good to know there are people out there who do such.
Understood and why I said great video......it is nice to see what one can expect when using blocks. Many folks see them as a panacea for removing a dent, when in reality they can remove a little but rarely remove the dent the completely, because of the nature of deformation of the metal. Thus the bump dolly or the addition of a small amount of filler to cover the "dimple", in my estimation in the end not worth the effort if one has to fill and repaint to get rid of the dent.
Personally, if I were to go down that route (slight filler) I would skip the blocks and lightly tap down the high spots and then fill.
Best, Ben
Voltaire
Voltaire
Likes For xiaoman1:
