Thumb shifters mounted on brakes? Kuwahara
Bikes: Cuevas Custom, Cimmaron, 1988 "Pinalized Rockma", 1984 Trek 510, Moulton custom touring, Raleigh Competition GS, Bridgestone Mb-2 & 3, 1980's Peugeot - US, City, & Canyon Express (6)
Quoted: 1096 Post(s)
Liked 3,739 Times
Was this a thing? Prototype mountain integrated shifter? Custom job by the owner?
https://losangeles.craigslist.org/sf...568727664.html
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Other than the rear wheel; that bike looks pretty original and unmolested. No extra scratches on the bar from previous shifter mounts, and a lot of 'recreational' 80s MTBs had tall gooseneck stems like that.
Behold: our own BikeForums provides the answer; it's an OE SunTour setup from c. 1989 : Combo Suntour MTB lever/thumb shifter unit?
So, yes, probably the original equipment
Likes For Ironfish653:
SE Wis
Quoted: 2746 Post(s)
Liked 3,393 Times
Likes For dedhed:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Shimano made an Exage Mountain group where the shifters attached to the levers and couldn't be mounted without the proprietary bracket. Still integrated imo.
Exage Country was similar.
Likes For clubman:
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 275 Post(s)
Liked 417 Times
Yep there's a 'mountain LX' group that's like that as well. Can be deceptive because it kinda looks like XT, but ime it's heavy and sloppy and the brake levers are plastic crap.
Likes For Soody:
Quoted: 4559 Post(s)
Liked 2,802 Times
Yup, my early 1990s Univega Via Carisma came with an Exage CX 500 group that included an all-indexed thumb shifter for the front and rear derailleurs. No option for friction shifting. The indexed front shifter worked well for awhile. Eventually I had to replace it with a low end but functional SunRace friction shifter. The other shifter for the rear derailleur failed after I was hit by a car while I was on that bike.
I think these were a variation of the Shimano Rapidfire shifters. The shifter pods had to be bolted onto plates extending from the brake levers. The plate extensions were drilled and tapped for the shifter pods. This placed both of the two-lever shifter pods under the handlebar, which was more intuitive for me. The longer lever helped with the upshifts against spring tension. The smaller thumby just relieved tension a notch at a time, so it didn't need as much leverage.
There was no other way to mount the shifters, although a machinist or handyperson could fabricate a mount to clamp onto a handlebar with the same drilled and tapped plate.
Unfortunately the shifters became balky several years ago and are sitting in a junk bin in case I ever decided to tackle restoring them. But I've long since switched to bar end shifters, which work nicely with the albatross swept bars I got to replace the original flat and riser bars that usually came with that type of rigid mountain bike that would now be called a hybrid..
Likes For Soody:
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
If it was lugged, it would be the splitting image. I like what you did with it.
Those shifters above, internally they are the same as the deore, there's a screw on the bottom that attaches them to the brake levers, they will mount on deore lever brackets.
