Velocity deep v with tires bigger than 28?
Have some velocity deep Vs and wondering if anyone has tried running tires bigger than 28. 13mm inner rim width? Looking to covert an old bike to gravel and wondering or is 28 good enough for this purpose?
Quoted: 6963 Post(s)
Liked 10,961 Times
Velocity actually lists the ID as 14mm, which is still pretty narrow. I'd have no problems running 32mm-wide tires, maybe even 35mm. That might work okay, and it gets you into faux-gravel range. Just understand that 35mm tires won't be great on the rough stuff.
Likes For Koyote:
Clark W. Griswold
Quoted: 4350 Post(s)
Liked 3,989 Times
As Koyote said you could probably run wider tires but it is pretty narrow and Deep Vs are not my choice for much of anything beyond looks on a fixed gear bicycle. If I wanted a little deep but nothing too heavy Ailerons or Quills depending on braking needs or if I am carrying a bit of weight Dyads and a lot of weight Atlases and if I want low profile roadie stuff for some reason (on a gravel bike) I would go A23 all of which are fantastic rims but some have different purposes.
35s would work but yeah wider is always better especially off road 38s are really the minimum for me these days.
Likes For veganbikes:
Liked 10,961 Times
Likes For Koyote:
Likes For bboy314:
Clark W. Griswold
Liked 3,989 Times
I absolutely love the durability of the Deep V rims. Been using them for rear wheels on commuter bikes whose owners have had issues with wheel true or rim bends. Been doing this for at least the past 15 years. I use one myself on my beater bike as well. Been in service since 2010 and zero issues. Not indestructible like an Aerospoke wheel, but darned close. Often I match them with 38mm tires and make sure the rider knows to keep max pressure in the tire, and if a conti tire, I recommend over inflation of 10psi, which is what I do on my own bike. For gravel use on roads that are not washboard, running lower pressure will be fine, but don't get too crazy with the pressure as you are inviting problems.
Never had any issues running 38mm tires on them. No pinch flats, or other issues everyone warns about, but often have zero experience with. Use good rim tape, Velox is my choice.
Likes For TiHabanero:
Quoted: 4391 Post(s)
Liked 1,555 Times
You can run them with 55mm tires. There is no limit.
Likes For Kontact:
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,217 Times
Same here. I think mine are 38s. No issues but I wouldn’t expect any as I run 17mm rims with 58mm tires and have for decades.
Stuart Black
Stuart Black
Likes For cyccommute:
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,434 Times
Yep, I have used up to 35mm. My gravel/offroad riding is of the easier variety. Regarding width, I have found 28mm tires on gravel is certainly doable, depending on type of gravel, definitely not optimal. In my situation 32 is good, 35 is better. That was the widest tire I could use on any of my bikes. If I was going to really get into gravel riding, I would want a wheel/tire combo built for that purpose, with 35 being minimum. For handling and comfort, a wider stance is a lot better, not to mention puncture resistance, even with tubeless.
Likes For delbiker1:
Quoted: 5224 Post(s)
Liked 3,581 Times
FWIW came across this chart recently
https://i.stack.imgur.com/S0Tib.jpg
found that here
https://bicycles.stackexchange.com/q...-on-my-bicycle
found that here
Likes For rumrunn6:
Cool... it's a Kilo TT that's looking lonely in the corner I'll be building up. I typically ride brakeless, but will include a front brake on this one. Suggestions on caliper brakes with 32 - 35mm clearance?
Liked 10,961 Times
Likes For Koyote:
A known issue with that frame is the quality control on the fork. I luckily got one that supports bigger tires. I've run 25 on that fork and there's plenty of space for 32, possibly 35.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
In that case, you'll probably need to start by measuring the reach.
Likes For ThermionicScott:
Liked 2,568 Times
https://www.sheldonbrown.com/calipers.html#reach
RUSA #7498
Ah right.. thought you meant the other reach - up to 51mm should work. The discrepancy is with the fork width... it's like they used different sized crowns during manufacturing.
Likes For testertips:
Liked 10,961 Times
What is the clearance in the rear triangle -- between the chain stays and between the seat stays?
Liked 1,555 Times
found that here
found that here
And the maximums are especially vexing as well. Does no one remember the A23 rim and what tires they were intended for?
As a general principle, matching your tires to your rims might make some sort of sense if you could demonstrate a problem in lateral instability with certain ratios. But let's see the testing.
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
This seems like nonsense. A technical and scientific looking chart with no explanation given for its underlying rationale. Yet anyone who had a nicer MTB the '90s have fat tires are super skinny rims, suggesting that these max tire limits are nonsense.
You can get away with almost anything as far as width goes. As long as it fits your frame and fork.
Likes For SkinGriz:
Rhapsodic Laviathan
Don't forget that your tire needs to clear not just the fork legs, but the front needs to fit under the fork crown. You need about as much clearance there as you need on each side of the tire.
Likes For Jax Rhapsody:
Rhapsodic Laviathan
