Frame Identification, yet again
Old 01-22-23, 12:30 PM
Aardwolf
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 291 Post(s)
Liked 654 Times in 331 Posts
Hiya Folks,
Yet another frame identification enquiry, I'm hoping somebody might find it slightly interesting.
I bought this really cheap (£20) to learn frame painting on (it's not even my size) but it seems to be an early 50s 3 or 4 speed
so I'm just wondering if anybody has an idea what it is.
Frame Number: on NDS rear dropout, looks like 1110 652
OLD: front 95mm, rear 114mm
BB: Bayliss Wiley, Nervex stamp on shell
Headset: T.D.C (Continental S possibly, 27mm crown race)
Seat post: Sturmey Archer 25.48
Weight: frame 2275g, forks 800g
Braze ons: single shifter + cable stops + weird 'boomerang' pump peg
Drive Side:
Head tube:
Forks:
Frame number:
Seat tube:
BB shell stamp:
Aardwolf is offline
Old 01-22-23, 12:40 PM
merziac
merziac's Avatar
Quoted: 4501 Post(s)
Liked 6,367 Times in 3,663 Posts
No idea, no help but very cool.
merziac is offline
Old 01-22-23, 01:03 PM
juvela
juvela's Avatar
Quoted: 3801 Post(s)
Liked 3,324 Times in 2,170 Posts
lug pattern: NERVEX 45/159
fork crown: NERVEX pattern Nr. 7
bottom bracket shell: NERVEX Ref. 158 -159
upper pump peg: NERVEX Ref. 845
lower pump peg: NERVEX Ref.846
serial placement and format consistent with one employed by Urago; likely used by other makers as well...
marking below axle slot could indicate year
juvela is offline
Likes For juvela:
Old 01-22-23, 01:20 PM
Aardwolf
Wheelman
Quoted: 291 Post(s)
Cheers, I understand most of that
Apparently NERVEX Ref.846 is for an Ad Hoc frame pump (https://www.bikeforums.net/classic-v...ged-frame.html)
Which sugests it's French, I was thinking Bayliss Wiley meant it was probably English.
I'll have to check which direction it turns, but I only have the fixed side.
Serial number suggests 1952 then which seems about right.
Aardwolf is offline
Old 01-22-23, 01:27 PM
juvela
juvela's Avatar
you could measure distance betwixt headplate fastener holes
this could be compared to that of member owned known Urago cycles
cycle appears very french; would be surprised if it is of another national origin
t'is a simple check to measure tube diameters and threading...
juvela is offline
Old 01-22-23, 01:28 PM
Mr. 66
Mr. 66's Avatar
Quoted: 1134 Post(s)
Liked 1,726 Times in 950 Posts
The fork crown does match a Urago that I have.
Mr. 66 is offline
Old 01-22-23, 01:46 PM
Aardwolf
Wheelman
Quoted: 291 Post(s)
Yep, I found the Sheldon Brown French page (https://www.sheldonbrown.com/velos.html)
Top tube: 26.15 diameter
Down tube: 28.12 diameter
Seat tube: 28.14 diameter
So according to Sheldon it's French
Head badge holes are spaced 5cm
Aardwolf is offline
Old 01-22-23, 02:01 PM
Aardwolf
Wheelman
Quoted: 291 Post(s)
Tried the fixed cup.
I was having trouble remembering which side is the fixed side
(Then I checked on my Holdsworth)
Threaded it into the fixed side (right) and it tightens turning anti clockwise, which I believe is English or Swiss thread.
Aardwolf is offline
Old 01-22-23, 02:19 PM
juvela
juvela's Avatar
it is possible to start BSC cups in metric shells as the BSC thread pitch diameter is 34.85mm while the metric is 35.0mm
within a couple turns they will start to bind as thread spacing differs
here is the Urago headplate current at this epoch -
fastener spacing for it is 45mm
juvela is offline
Old 01-22-23, 02:33 PM
1simplexnut
1simplexnut's Avatar
Bikes: 1963? Anquetil , 1973 PX10,1979 PX10,1984 PX10, VITUS 979 PX10DU,1970S ALAN,1985 PSV10,1980s PY10FC,1978 bERTIN,ALAN carbon
Quoted: 283 Post(s)
Liked 636 Times in 283 Posts
Hi I have an early 60s Bertin alloy head badge on my desk it measures exactly 5 cm .
Maybe Bertin ?
1simplexnut is offline
Likes For 1simplexnut:
Old 01-22-23, 02:35 PM
Aardwolf
Wheelman
Quoted: 291 Post(s)
I just dabbed some grease on the Bayliss Wiley fixed cup and wound it all the way on - anti clockwise all the way.
Aardwolf is offline
Old 01-22-23, 03:07 PM
juvela
juvela's Avatar
if cycle manufactured with metric dimension tubing but BSC threading possible frame could have been produced in France for a British importer/distributor
such beasts exist
steerer diameter not mentioned
a BSC threaded adjustable head race will thread on to a metric steerer but will flop about a bit
juvela is offline
Old 01-22-23, 03:21 PM
Aardwolf
Wheelman
Quoted: 291 Post(s)
Just measured it at 24.91mm,
which is in line with Sheldons 25mm for French bikes
Aardwolf is offline
Old 01-22-23, 04:35 PM
juvela
juvela's Avatar
Maybe Bertin ?
this is an interesting suggestion
member verktyg has written that Bertin was a supplier of some Urago frames
it is possible the two companies may have employed the same serial format at one time
here is a drawing of an Urago serial of 1959 -
Ron Kitching was the Bertin agent for the U.K.
if subject frame a Bertin product it may have come through that supplier
the forum's Bertin expert bertinjim may be able to comment upon the Bertins manufactured for the U.K. market...
juvela is offline
Likes For juvela:
Old 01-22-23, 04:52 PM
Aardwolf
Wheelman
Quoted: 291 Post(s)
There's an interesting piece about Ron Kitching and Andre Bertin at https://bertinclassiccycles.wordpres.../ron-kitching/
By 1948, Ron Kitching’s Cycling Centre was importing a wide range of goods and ideas from Europe. In 1953, Kitching began to wholesale to other British shops and his influence and success grew in parallel with his European associates and suppliers, especially Andre Bertin.
Aardwolf is offline
Old 01-22-23, 05:22 PM
juvela
juvela's Avatar
member verktyg has written that at the importer/distributor he was part of they could order any detail(s) they wanted with the Bertin cycles they imported into the U.S.
the catalogue/brochure models were evidently examples only
so it is possible RonKit may have been able to order Bertins with BSC threaded bottom bracket shells...
perhaps bertinjim will know
juvela is offline
Old 01-22-23, 06:08 PM
Aardwolf
Wheelman
Quoted: 291 Post(s)
Here's a very similar bike:
It's a mid 50s Bertin from https://bertinclassiccycles.wordpres...ers-1950-1959/
Aardwolf is offline
Likes For Aardwolf:
