I got the seat post out!!
B-b-b-b-b-b-bicicle Rider
Bikes: 1997, stumpjumper S-works hardtail, Medici, Giant Perigee(track dropouts and fixed gear), Columbia twosome, schwinn twinn, '67 raleigh 5 speed internal hub, Old triumph 3 speed, old BSA 3-speed, schwinn Racer 2spd kickback, Broken raysport criteriu
Liked 5 Times
I found a schwinn Frontier on the curb. I replaced the bottom bracket, tuned it up, and the tried to adjust the seat post so i could give it a test ride. No luck. I oiled it, banged on it, tried twisting it, nothing. I turned it upside down and put penetrating oil into the seat tube, let it soak for a few days. Nothing. I added some lemon juice. It was a steel post and frame, so the acid might hopefully eat some of the rust. Still nothing. I drilled a 1/2" hole through the post and inserted a hardened steel hitch pin and whaked away at that, clockwise and counterclockwise..it started to twist. I got it rotating, but couldnt get it to pull out. I put the post in a vice, had my 2 sons twist the frame on the post while i pulled. After about 15 minutes of twisting and pulling it was out far enough to get a stem clamped on. Another 5 mintes, of pulling and twisting and the post was out. You can see how ovalized the hole i drilled has become fom the pin-banging.
Likes For orange leader:
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 345 Post(s)
Liked 189 Times
Thanks! I actually have a frame I'd been waiting to have another go at, I may try the hole-drilling trick to get some leverage.
Likes For Viich:
Quoted: 4197 Post(s)
Liked 3,849 Times
Good job! Now you know why shops generally cringe at this job. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Likes For zebede:
Quoted: 427 Post(s)
Liked 699 Times
If only someone had checked and put some grease on the post as needed. As the saying goes "an ounce of prevention is worth a pound of cure". Good job getting the post loose!!
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
I've got a Fuji America touring bike with stuck seat post. I've left it as is for well over a year, since it's only about a half-inch low for me. Perhaps it's time to give it a try. I had to cut one out of an Ironman Expert a few years ago using a hacksaw blade. What a Beotch!
Liked 5 Times
I think i saw his....he has several. I definitely used it for inspiration. wanted to build that post puller he built, but i don't have any welding skills or gear, but i had a similar idea to use threaded pipe, and leverage off the brake bridge....but it would probably snap the bridge. his bottom bracket idea is good.
Liked 5 Times
I think the seat post was the wrong size for the frame.!! i used calipers to measure it when buying a replacment, and it didn't seem to match the internal frame diameter. I second guessed my measurement and ordered a size between the two (thinking maybe i was measuring corrosion), so I ordered a seat post that was 0.2mm smaller than the one i pulled out, and 0.2 larger than what i measured in the seat post. I ended up buying a 2nd post, that was .4mm smaller than the original that i mangled getting out. 2nd post slides in real nice-like.
