Shimano shift lever ST-7S60 service manual?
Old 05-25-23, 08:17 PM
scamander
I opened up my Shimano shift lever ST-7S60 and messed it up. Any one have a service manual? Thank you.
scamander is offline
Old 05-25-23, 11:18 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
Google Shimano ST-7S60
found this
https://manualzz.com/doc/53870856/sh...e-instructions
I don't know if that helps.
Bill Kapaun is offline
Old 05-26-23, 12:54 AM
maddog34
maddog34's Avatar
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times in 534 Posts
for what it's worth... that shifter is discontinues=d and no parts are available... your best bet is to find a used or NOS replacement if fixing it is not possible... Internal geared hub, correct?
Search: "Nexus 7sp Internal gear shifter" on ebay.. many twist grip options, and a few trigger shifters, came up.....
i don't think the Standard 7sp. Derailleur shifters will work, but someone here might know... derailleurs have some odd positions in the mid gears to deal with, so.... get the Internal Micro-shift trigger unit would be a safe bet.. as would be the twisters for internal geared hubs....
maddog34 is offline
Old 05-26-23, 12:22 PM
scamander
The ST-7S60 service manual continues
Huge appreciation to the 2 folks who replied so quickly and helpfully.
The Google link manual doesn’t have images of the inner workings, which is what I need. I hope to fix it rather than replace as it’s a very cool look for this Schwann cruiser. The search for a service manual continues….
Old 05-26-23, 01:52 PM
scamander
Hi and thanks! Can you suggest an Internal Micro-shift trigger by brand and item number? Trying to find one on Amazon.
Old 05-26-23, 02:44 PM
maddog34
maddog34's Avatar
Microshift TN 70N... search on ebay to see it.. "microshift 7 sp internal gear trigger shifter" .. $25, including shipped.
...just checked Ama-Zone.. not seeing one. not a high volume sales item, i guess.
maddog34 is offline
Old 05-26-23, 02:47 PM
KCT1986
Quoted: 345 Post(s)
Liked 320 Times in 234 Posts
Unfortunately, Shimano rarely has documents that show the inner workings of their parts (gears, pawls, springs...). Many of these parts are preassembled units and not intended to be taken apart. The whole shift unit is replaced onto the handlebar bracket or brake lever (if applicable) upon failure.
If you search Shimano's tech doc site, the available docs are easily found but as mentioned above, is not always too useful.
Your best bet is, if you can find something on the web by someone else that has done & documented the disassembly of your shifter or a similar model.
KCT1986 is offline
Old 05-26-23, 02:58 PM
maddog34
maddog34's Avatar
it is relegated to the "Discontinued" list now.. sigh.
maddog34 is offline
Old 05-26-23, 10:11 PM
scamander
Appreciated
Your responses are more than I ever expected, and I’m very appreciative. Thought it would be crickets but quite the pleasant surprise.
I’ve ordered a “NOS Shimano Nexus Shifter Lever Trigger ST-7S20 for 7 Speed Internal Hub” from eBay.
