Garmin Map question
Old 07-26-22, 05:13 PM
njkayaker
Quoted: 4255 Post(s)
Liked 1,354 Times in 940 Posts
Originally Posted by dmwill
I had a long exchange with Garmin to do with delays on turn by turn directions on my Edge 830. Turned out the culprit was the map of Florida I had pulled from bbbike.org and loaded up. Once we removed that map the delay went away. Maybe the whole state of Florida was to much and I should have just done a county or two.
No, the state isn't too big. The standard maps are much, much bigger.
The Garmins calculate the route and all the turns at the start. So, there really shouldn't be any delays while using the route. Strange.
Lots of people use these maps and I've never heard of the problem you had.
If you had two maps enabled that covered the same region, that can cause problems.
njkayaker is offline
Likes For njkayaker:
Old 07-26-22, 05:42 PM
Atlas Shrugged
Quoted: 1248 Post(s)
Liked 1,323 Times in 674 Posts
Or you can spend approx $20 and download the full Europe map from Garmin directly. Super simple and they work perfectly and are fully searchable.
Atlas Shrugged is online now
Old 07-26-22, 08:06 PM
Daniel4
Bikes: Sekine 1979 ten speed racer
Quoted: 1481 Post(s)
Liked 639 Times in 437 Posts
The old garmin.openstreetmap.nl that I used to use automatically redirects to garmin.bbbike.org. So I requested, received and extracted the zip file for Portugal.
I can see the gmapsupp file my Garmin device. But how can I get a map into BaseCamp?
Daniel4 is offline
Old 07-27-22, 12:46 AM
Badger6
Obsessed with Eddington
Badger6's Avatar
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times in 368 Posts
You will need to use a map installer to install a GMAP format map that BaseCamp can read. Garmin has a separate map installer program that you will need to do this. I am not sure if BBBike offers maps in this format, but with a little googling, it shouldn't be too hard to find them already built. I honestly have found much better success building routes in Komoot or Strava and then sending them to my Garmins over the years rather than using BaseCamp, primarily because those options offer better routing and there is the advantage of using heat maps (in Strava) to stick to roads that cyclists use.
Badger6 is offline
Old 07-27-22, 03:00 AM
njkayaker
That doesn’t include updates. So, you’d have to repurchase them if you want updated maps.
Old 07-27-22, 03:03 AM
njkayaker
One way to get them into BaseCamp is to create a virtual USB disk and put the img file into a \Garmin folder on the disk.
You could use an actual USB or SD card too.
Make sure the virtual disk is indicated as “removable” (otherwise BaseCamp won’t see it).
Note you can rename the map file.
I use the following software.
https://www.ltr-data.se/opencode.html/#ImDisk
I create a shortcut to “mount” the drive.
Old 07-27-22, 03:16 AM
njkayaker
(It would be somewhat surprising if he wasn’t aware of alternatives.)
Other planners are easier to use than BaseCamp.
BaseCamp, though, doesn’t need internet access.
BaseCamp is also fairly convenient as a route/track viewer. Especially, if you want to look at more than one track.
Old 07-27-22, 07:41 AM
dmwill
Bikes: 1989 Dahon Stainless Steel Classic, 1993 Burley Samba Mixte tandem, 2002 Gary Fisher Hoo Koo E Koo, 2003 Co-Motion Speedster tandem, 2021 Trek Verve 3, 2021 Priority Current
Quoted: 13 Post(s)
Liked 31 Times in 20 Posts
I had these maps installed:
  • Garmin DEM Map North America
  • Garmin Geocode Map North America
  • Trailforks
  • AMR Standard Basemap, NR
  • Garmin Cycle Map Amer, North
  • Florida openfietslite/latin1 BBBike.org
Garmin support said "disable the Florida openfietslite map that is listed on your edge. Where did you get that and how was it installed on it? We don't recommend installing 3rd party maps on the unit."
Here is a picture of what it was doing. Blue arrow keeps moving, but after exiting traffic circle unit still thinks that's the next upcoming turn. Sometimes it would stay that way past a couple of turns then tell you to make a U turn to go back to the parts you "missed" even if you were still on course. Removing the openfietslite map resolved this behavior. Yeah, they said they'd not seen this either, don't know why my unit is special, but hopefully the next person that runs up against this might find this and save a little time.
Already exited the traffic circle, but unit thinks we haven't gotten there yet.
dmwill is offline
Old 07-27-22, 07:55 AM
Atlas Shrugged
My understanding is any updates are covered for the 1st year. I have gone down the freebie map route and yes they work however the Garmin maps just work better, are clearer and include popularity routing. It’s only $20 and for a lot of us it’s worth it. Just look at this thread and read all the goofy challenges people are encountering.
Old 07-27-22, 08:04 AM
njkayaker
“Goofy challenges” is an over statement.
A year is close to nothing. It’s also not hard to use the other options.
Some of the Garmins don't have enough space for two large maps. So, people would need to remove the standard map, install a very large map, removing it when they return and, reinstall the very large standard map. Using a custom map (which is typically much, much smaller) avoids this "challenge".
It’s also $20 for each Garmin on the trip.
(I think the Garmin versions generally look fine but some people don't like it.)
Note that the newer Garmins (1030+, 1040, maybe the Explore2) come with world-wide maps.
Old 07-27-22, 08:20 AM
njkayaker
It's completely unsurprising that Garmin support would want nothing to do with a non Garmin product.
(Customer support is expensive for companies. Often, the support groups are given directions to reduce the cost. One easy way of doing that is not dealing with issues that are anyway related to non-company products. The staff is often trained to deal with a limited range of issues too.)
(One of Garmin's own maps doesn't work in Garmin's BaseCamp product. Garmin has no idea why. The other maps (out of like 5) work fine in BaseCamp.)
  • Garmin DEM Map North America <elevation data.>
  • Garmin Geocode Map North America <points of interests for address lookup.>
  • Trailforks <maps for mountain biking used for Trailforks feature.>
  • AMR Standard Basemap, NR <world-wide base map. doesn't have much detail. "NR" means no rouiting information.>
  • Garmin Cycle Map Amer, North <map for North America (which included Florida). This has routing information.>
  • Florida openfietslite/latin1 BBBike.org <Much the same as the "Garmin Cycle Map" but just covering Florida.>
These two maps (which both have routing issue) cover the same region (this is the problem I pointed out earlier).
You have to disable one of these maps. "Removing" either map would have resolved the issue!
It's a known problem (known for years), It would happen with two Garmin maps that covered the same region.
Why did you install a Florida map (when the Garmin map already covered it)?
Old 07-27-22, 09:02 AM
dmwill
Quoted: 13 Post(s)
Mostly to try new things and learn, and I have! Thank you for that excellent description of the different maps. Secondarily was to see if I can get more accurate heatmap based routing of where people actually go. The Garmin data has tried to send me down roads that aren't roads, across fences into private property, and doesn't seem to know about a rail trail extension here so it keeps yelling U-Turn! U-Turn! until we clear that section and get back to something it knows.
dmwill is offline
Old 07-27-22, 09:11 AM
njkayaker
The "heatmap" stuff is based on people's recorded rides. The alternative sources for maps don't have this data.
More detail might explain some of this. Garmin is using the same data* (Openstreetmap/OSM) as the alternative sources. The rail trail extension issue seems like the Garmin map isn't as up-to-date.
* Garmin uses its own data for points-of-interest (POI). Part of this is for "advertising revenue" and part of it is that OSM can be spotty with respect to POIs.
Old 07-27-22, 10:01 AM
dmwill
Quoted: 13 Post(s)
Here's a recent example. The inset is what the Edge thought we should do - take a sharp left off the waterway trail on "Unnamed Road" (or something like that) then a right on to Ocala Rd. Turns out that Unnamed Road shown with red dots on the Google Earth picture is really a drainage ditch with a fence all the way across it.
Garmin wants us to hop a fence and ride the drainage canal.
I sent in a report to Garmin with coordinates and gpx file a few months ago for the rail trail thing, guess the correct answer to that is "just wait longer!"
dmwill is offline
Old 07-27-22, 10:46 AM
njkayaker
This is another example of "not Garmin's problem".
Garmin won't fix it. It's not really Garmin's responsibility.
Understanding why is kind of important for using these devices for navigation effectively.
I removed the "path" and added the fence.
Next time, include the Google map link!
Keep in mind that the routing favors the shortest distance.
The maps that come with the current Garmin units are Openstreetmap (OSM) maps. Openstreetmap is a publicly-maintained map database. One reason Garmin uses OSM maps is because they are cheap (free) and Garmin doesn't have to deal with the expense of maintaining them. Another reason to use OSM is that the OSM maps contain cycling-specific features that commercial maps don't have. Google has some of these but other companies can't really use Google's maps (outside of a limited way).
As far as the OSM data is, that route looks OK (as far as the world the map knows about, there is no fence or ditch).
The problem is that the map doesn't match the reality as accurately as it should. This a fundamental problem with maps: maps can't match reality exactly.
No one would be able to determine the quality of that "cheat route" unless they went and physically surveyed it. No commercial company is going to do that (it's way too expensive). People who live in the area and update OSM might.
The commercial maps ("City navigator") that Garmin sells wouldn't have the bike path (or the ditch or the fence).
The "track" (the path) is shown on OSM but not on Google maps. That Google maps doesn't have it might not be a good thing either: people might have legitimate reasons to want to get to a road at that location.
Openstreetmap
https://www.openstreetmap.org/#map=1...5986/-82.43200
Google
Old 07-27-22, 11:02 AM
njkayaker
Here's an interesting example of the issue.
If you click on the Google map, there's no direct way to get from Orchard Street (at the north) to Twinbrook (at the south):
Google Streetview shows a completely fine path to use:
https://www.google.com/maps/@41.0487...=en&authuser=0
OSM has the path. As a result, the routing (for cyclists) at this spot will be better than Google maps.
https://www.openstreetmap.org/#map=1...4820/-74.14594
Old 07-27-22, 12:00 PM
Daniel4
Tools and utilities for Windows
I found another website that BaseCamp can read.
https://www.openmapchest.org
Daniel4 is offline
Old 07-27-22, 12:21 PM
Daniel4
What's the map and the format that only cost $20? The City Navigator Europe map will cost me over $100 CAD. Even from Amazon, the card will cost about 60CAD.
Daniel4 is offline
Old 07-27-22, 12:23 PM
Atlas Shrugged
https://www.garmin.com/en-CA/p/155338
Old 07-27-22, 02:34 PM
njkayaker
Garmin has OSM (Garmin Cycle Maps) for sale too.
https://www.garmin.com/en-US/c/outdoor-maps/cycling-maps/
Downloaded Garmin Cycle Maps cost $20. They are $50 on a microSD card.
The source for OSM data is free. So the OSM maps are cheaper than the City Navigator maps (which are more tailored for cars, anyway).
