Fire as paint remover?
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
i wouldn't apologize. people around here like to trip out...haha
Quoted: 1814 Post(s)
Liked 923 Times
Let me clarify. The frame was above the fire, not in the coals. I heated one section at a time for about 1 minute, then removed it to scrape the paint in that section. Each section worked was roughly 6 inches long. The total process, section by section, took about an hour.
"made a fire in the fire pit and threw it in"
Likes For woodcraft:
Quoted: 1557 Post(s)
Liked 1,733 Times
I’ve never heard of anyone using flame to strip paint but lots of people use heat guns to do it. Ive used it on small parts.
Also- what paint stripper were you using? I found the spray-on stripper works way better than the brush on type. No idea why. It just did.
Quoted: 4559 Post(s)
Liked 2,802 Times
A heat gun is affordable, works quickly with little or no damage to the matrix under the paint, including most woods when used carefully.
Years ago when I lived in a rural home on 3 acres I went through a phase of experimenting with all kinds of primitive techniques for woodworking, etc., including metallurgy I experimented with old school heat treating to make knives from worn out files, and to make simple flat sprints from metal stock. It's possible to do pretty decent work with just a hot wood coal fire in a garden, both softening and hardening, including case hardening with bone.
But I'd hesitate to use an open flame or coal pit like that for removing paint. A heat gun would be easier and safer.
I'd also want to get an idea of the frame joinery and minimize heat time on joints.
Likes For canklecat:
Likes For polymorphself:
Quoted: 2588 Post(s)
Liked 4,824 Times
DD
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
try browsing montana brand "hard core" paints. i dunno. maybe. they have a lot of specialty colors i'd never seen before
Bikes: Trek 400 Elance, Losa Winner, 1994 Schwinn Paramount, Specialized Tarmac Pro, Miele SLX, Ibis Ripley, Colnago Oval CX, 84 Masi GC, 1986 Schwinn Voyageur, 1988 Schwinn Tempo, 1998 Schwinn Peloton, 1991 Paramount Ser3
Quoted: 150 Post(s)
Liked 90 Times
Next time pay the powdercoat guy 125 bucks to strip it clean as a whistle and cover it with almost any color you like.
Likes For AngryFrankie:
Insane Bicycle Mechanic
Quoted: 802 Post(s)
Liked 703 Times
https://www.prismaticpowders.com/sho...osebud-sparkle
Jeff Wills
Jeff Wills
Space Ghost
Bikes: Bridgestone, Fuji, Iro, Jamis, Gary Fisher, GT, Scott, Specialized and more
Quoted: 292 Post(s)
Liked 412 Times
I’ve used citristrip on a couple frames with great success. Doesn’t require much effort either.
Mad bike riding scientist
Quoted: 6214 Post(s)
Liked 4,212 Times
The main point is that there is little to no control over how hot the fire gets.
Stuart Black
Stuart Black
www.theheadbadge.com
Quoted: 2421 Post(s)
Liked 4,390 Times
Or rather, is 350-450 degrees worthy of concern when powdercoating is so regularly accepted as a frame finish?
(Yes, fully aware the OP didn't bake the frame - I read that post. Just thinking out loud).
-Kurt
Quoted: 1106 Post(s)
Liked 1,326 Times
Which brings up the tantalizing question - what kind of damage can the 350-450 degree Fahrenheit of powdercoating do?
-Kurt
-Kurt
Likes For oneclick:
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
I do sincerely hope the build goes great for you.
Also, I will agree with cb400bill, that original colourway is very nice looking. (Coming from a Marine guy that proudly owns and rides a pearlescent pink Tomassini Prestige😉
Bill
Semper Fi, USMC, 1975-1977
Likes For qcpmsame:
Quoted: 2337 Post(s)
Liked 2,818 Times
Anyone who has thrown a tin can into a campfire knows that a wood fire can get hot enough to seriously deform thin steel. I remember from my wood stove days that wood starts to combusts at about 500f and that the target for a clean fire without visible smoke is around 1,100f. Some air control was generally needed to reach that temperature so I doubt that an open wood fire would get quite that hot very easily.
Brent
Brent
Likes For squirtdad:
Liked 2,818 Times
also a heat gun might be a little more controllable than treating the frame like a marshmallow
Quoted: 150 Post(s)
Liked 90 Times
Ugghh. Maybe try to find someone a little out of the city. 125 is actually frame and fork in suburban Atlanta. I had an 853 Peloton done for 100.00, no fork, pretty recently, and it came out very nicely.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,793 Times
All this talk about heat damaging steel frames is interesting. Bronze brazed frames are heated up to glowing orange at the joints with no structural issues (proviso that you're using the right tubing that will take the heat, yada yada...) They get reheated in small areas when brazing on tiddly bits (my new favorite term). Tubing properties are designed around construction methods, to some degree, and brazed, steel frames wouldn't be possible to construct if you couldn't heat them up brazing temperatures without damage.
The problem is heat control - any framebuilder will tell you that. If you're throwing a frame into a fire pit, it's hard to tell if small areas get heated up to the point where damage to the frame would occur. Others much more knowledgable in the blue flame arts might chime in here.
However, I wouldn't strip frame paint using heat for a different reason. If you're burning off the paint there could be nasty chemicals coming off that I certainly wouldn't want to breath in.
@Drillium Dude, if your heat gun softens the paint enough, I'd say go for it. I highly doubt that the hot air coming off of them will damage your frame.
Quoted: 3807 Post(s)
Liked 6,675 Times
Liked 5,793 Times
That was the name of the song we all stood up and sang before they kicked us out.
Likes For gugie:
Liked 6,675 Times
Likes For nlerner:
