mullet a 26 to 27.5 front?
Quoted: 722 Post(s)
Liked 353 Times
mulleting of 26 incher to 27.5 as i could use a better longer shock...80 mm now old pilot RS...need new front wheel but curious if more travel bigger tire will ruin the bike.
Habitual User
Quoted: 4929 Post(s)
Liked 8,062 Times
Ruin it how? It will change the geometry, which may or may not be better for the kind of riding you do.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
If you do this it's definitely going to effect how your bike handles. It was designed around an 80mm fork w/ a 26" wheel. What you want to do is a huge change, I was say a negative change. I went from 33mm tires on my cross bike to 40mm tires. That change alone messed up the steering.
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
Longer fork = longer atc, plus larger diameter wheel and tire? Horrible, horrible idea.
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
Longer fork will slacken the headtube and increase the leverage on the frame. If you ride hard you may snap the headtube off, it used to happen quite a bit.
Quoted: 722 Post(s)
Liked 353 Times
that would sux....what about a 26 inch fork but with longet modern travel...new stuff is 120 or more am i screwed
Quoted: 186 Post(s)
Liked 234 Times
I'm not an engineer. Just telling you what I have witnessed. If it breaks, take pictures.
Drip, Drip.
Liked 193 Times
You would need to be using a fork like 10cm longer, weight 275lb and be doing jumps to snap a head tube.
op, don't do it. Your bike is designed for 26 and 80mm. You won't be happy with the changes you are proposing. Save yourself the trouble.
26" 100mm is relatively commonplace, and would probably be just fine. https://hayesbicycle.com/products/ma...32139633393709 is a pretty nice one. +20mm of travel will probably not be too much on your headtube and won't weird out your handling too much.
Increasing travel AND wheel size is probably a bad idea.
