How to reach PSI 110 with a floor pump
Bikes: A2b Metro, Eneloop, Alley Way, Haul 2
I bought a pair Hutchinson Atom Comp tires and installed them on to the Ksyrium SL, pump the wheel with a floor pump, when it gets to PSI 80, it stops, I can hear the air is leaking out from the pump nozzle and tube valve, does that mean the pump is no good or the valve on the tube is no good, or maybe both. The pump is Serfas FP
-55 and the tube is sunlite 19-23. Any suggestion? Thanks
moth -----> flame
Bikes: 11 CAAD 10-4, 07 Specialized Roubaix Comp, 98 Peugeot Horizon
Sounds like you haven't made a good seal with the valve and the pump head. I don't know the specific model you have, but maybe try making sure you "blip" the presta valve before pumping, push the pump head all the way on before locking it, and then pay attention to where the valve is when you pump - i.e. my current tubes seem to prefer being inflated at 6o'clock, others are 12, etc.
BF, in a nutshell
BF, in a nutshell
Is that what it is?
This is the pump I have
https://www.rei.com/product/799193/se...-55-floor-pump
I thought all pumps are made the same.
Quoted: 630 Post(s)
Liked 369 Times
Is that what it is?
https://www.serfas.com/product_details.asp?ID=220
I have it, been using it perfectly for a year.
Return it and get this one:
Is that what it is?
moth -----> flame
The pump the OP already has is rated to 140psi
BF, in a nutshell
BF, in a nutshell
Quoted: 551 Post(s)
Liked 277 Times
When you connect the head to the valve...do you pull the sealing lever up after you connect it to the valve or do you flip it up and then flip it back down after you connect it to the valve?
There are some pumps that work in this manner and totally ass backwards/counter intuitive! Check that first, because that is a common error.
Bicycle Repair Man !!!
Not all pumps are created equal... my floor pump is a cheap $25.00 BETO that has been in service for 3-4 years and it has no issue inflating tyres to 140 psi and all it has needed was a new head and hose.
I second the Lezyne Floor Drive pump. Just 21 pumps will easily reach 110psi. Add four more strokes and you'll get 140psi. Best pump money can buy...just like the old Silca Track pump.
CAADdict
Bikes: 2009 Cannondale CAAD9-?
Liked 5 Times
What I'm using now (2 years and it's serving me flawlessly):
Topeak Joe Blow Pro
My next pump (the Topeak will be used as a 2nd site pump):
Lezyne CNC or Alloy Floor Drive
But DAMN this new Topeak is attracting me too!:
Joe Blow X.O.
In my Camelbak for MTBing:
Topeak Master Blaster DX
And "on" my Road Bike:
Topeak Micro Rocket Carbon
But I also have my eye on this...
Lezyne Pressure Carbon Drive 2:
Topeak Joe Blow Pro
Joe Blow X.O.
Quoted: 86 Post(s)
weigh yourself. you will lift yourself off the ground when your tire pressure equals your weight.
if i have to pump up a tire above 155 i call my neighbor over. she sits on my shoulders THEN i pump.
to be honest, i've let the air out of my tires on purpose a couple of times, just so we can do this. she seems to enjoy it so... what the heck.
My last try worked , I have to press the pump nozzle all the way in to the valve, and pump the **** out of my ass, finally got up to 110, the last few pumps were like....... I have to lean my whole body on to the pump handle, then the nozzle got stuck with the valve, I pull pull pull..... it came out, but I got my hand cut with the spokes, damn it hurts. I will exchange the pump tomorrow, most likely I will get the Lezyne floor pump.
weight yourself. you will lift yourself off the ground when your tire pressure equals your weight.
CAADdict
Liked 5 Times
It only takes me a good 6-7 pumps to easily get my tires up to 120psi with the Topeak.
I'm sure the Lezyne will be great (I make it a point to put Lezyne products first on my
list of accessories; some of the best products you can buy).
Whatever the manufacturer recommends.
Another thing I notice is , with the same specs, 700 23, the Hutchinson tire is slimmer than my Schwalbe Lugano and Michelin Lithion,
noticeably slimmer, it is more like a 700 20, anyone knows why? Could this be the tube? The tube is for 19-23 width tires.
"Florida Man"
Quoted: 1571 Post(s)
Liked 1,706 Times
www.bikequarterly.com/images/TireDrop.pdf
Yes, there is a best pressure based on your weight and tire size for performance. For your weight, assuming you are using 700/23 tires, the 110 is about perfect in the back, but you might want to stay closer to 80 in the front. See the chart at the end of the article, keeping in mind that your weight is likely distributed about 60/40 back/front.
"Florida Man"
Liked 1,706 Times
Doh! I forgot to add in the weight of the bike. Maybe your best pressure would be more like 120/85 on 700/23's.
Medicinal Cyclist
Bikes: 2003 Klein Q Carbon Race; 2009 Giant OCR-1
The thing I really like about the Lezyne floor pump (I've got the steel model) is that you screw the nozzle onto the valve stem. You can pump up short stems in deep dish wheels that other, clip-on pumps (like the Joe Blow Pro, which I also have) can't touch because they can't get a good bite.
Bikes: Miyata 610 , Schwinn circuit, Bianchi C2C, Quattro Assi , 87 Trek 1500, Felt F1X, Burley duet, LHT and a few more
Quoted: 10 Post(s)
I had a specialized Air Force that worked poorly until I removed the top and lubed the plunger and shaft . Worked great until the valve crapped out for the second time. Got a Joe Blow Pro.
