Must have features
Bikes: 2015 Felt Z75 Disc, 2008 Fuji Cross Comp, 2010 Trek Navigator 1.0, 1974 Raleigh Sports, 1974 Schwinn Le Tour, 1981 Schwinn Super Le Tour, Surly Cross Check, 2021 Giant Talon 2
Quoted: 202 Post(s)
Liked 71 Times
Must have features
I’m looking at upgrading and making a list of the features I want. This is the list so far:
thru axles
tubeless ready
27.5” tires (I’m shorter)
1x drivetrain
disc brakes
I have a 2010 Raleigh talus 3.0. So all that would be new to me. On the fence for full suspension. Also interested is the best budget options with all the above. Did I miss anything good? Any of the above you wouldn’t recommend?
thru axles
tubeless ready
1x drivetrain
disc brakes
Quoted: 2236 Post(s)
Liked 1,314 Times
Dropper post.
Of course, it would help if you said what kind of conditions 6ou plan to ride in. There is a world of difference between a basic trail bike and a full on technical downhill bike. Both are mountain bikes.
Likes For Happy Feet:
Quoted: 202 Post(s)
Liked 71 Times
just a modern trail bike.
check out the Frugal Average Bicyclist
Frugal Average Bicyclist – The goal here is to help you keep cycling on a budget.
Clutch rear derailleur
Slacker headtube - depending on what you ride
Airspring Fork
More than 2 bottle cage mount bolts (if you don't plan on carrying additional water on you)
Threaded BB if you're not a fan of banging on your frame for maintenance
Airspring Fork
Likes For Pactin:
Quoted: 2975 Post(s)
Liked 1,181 Times
You never stated what your budget is. Most modern bikes from the reputable manufacturers will have what is in your wish list.
However 27.5 tire size is starting to die off. Little by little the bike manufacturers have been eliminating the 27.5 tire size from their offerings. And your height is not related to which wheel size you should choose. Wheel size is based riding style more than anything else.
For instance...This is a section of my local trail. 29" tires do way better riding over this feature vs. 27.5" tires.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Without picking on any model in particular, I think that the hard tails in the $1500 range and full sus in the $2400 range are fully functional. A lot of the things I'd like to improve about them are piecemeal, taking every component three steps higher for double the price does not seem like a good deal.
Genesis 49:16-17
Genesis 49:16-17
Quoted: 202 Post(s)
Liked 71 Times
budget is as little as I can pay and still get all the things I want.
Liked 1,181 Times
What's the top dollar in your budget? It helps to know that so you can be pointed in the right direction. Current bike shortage may limit your choices if you are planning to buy something soon.
Quoted: 202 Post(s)
Liked 71 Times
Quoted: 202 Post(s)
Liked 71 Times
I'm hoping to not buy a bike I feel I need to upgrade right away. All the things I listed seem like good options, but I could be talked into more or less. I'm deep in my 40s so I am gonna try to avoid doing anything too crazy, but I enjoy riding the trails. So I'd like a more capable ride that might help me out if I do get stupid.
Disco Infiltrator
Liked 2,105 Times
I wanted to try a Roscoe but none were available in 2018 when I was shopping. The shop had an X-Caliber but it felt old fashioned that year, still having a narrower bar with no rise, longer stem, and 2x transmission. I got a Salsa Timberjack which in 2018 had a cheaper build much like this or the current Salsa Rangefinder. And I've been pretty happy with it since, upgrading the fork, adding a dropper, and much nicer tires when they were worn out.
Genesis 49:16-17
Genesis 49:16-17
Quoted: 202 Post(s)
Liked 71 Times
It needs a dropper, which you can get for a hundred bucks. The Roscoe is the same frame with a slightly more shaggy build. These two bikes have quick release rear wheels which are not as sturdy as thru axles, but the frames can mount things like standard racks, trailer hitches, and kid seats without modification if that's important to you, and besides that they are otherwise mostly compatible with any upgrades you'd like to do in the future. The fork is adequate. The tires aren't tubeless, technically, but will probably seat up with Orange Seal, and in a thousand miles you can get something better.
Liked 1,181 Times
This has thru axle both front and rear if a hard tail is what you are looking for and ~$1500 is your budget
https://www.giant-bicycles.com/us/xtc-slr-29-2-2021
Disco Infiltrator
Liked 2,105 Times
Photos: my TJ, with trailer hitch. This version is convertible to thru axle with different Alternator but hasn’t been, yet, maybe someday… and, wife's hybrid
