Removing SRAM X01 DH Crank to adjust spacing on MRP G3 Chainguide Spacing
Bikes: Canyon Ultimate CF SL Disc, Canyon Spectral
Quoted: 73 Post(s)
Liked 24 Times
I'm trying to remove my cranks (2015 SRAM X01 DH ) in order to adjust the spacers behind chainguide (MRP G3 Mini Carbon). I don't think I can get to the spacers without removing the crank. I undid the non-drive side cranks 10mm and 8mm hex. I cant pull the crank arm off.
Any suggestions?
I took the upper chainguide off a few years ago, b/c it was never spaced out correctly by Giant. I haven't ridden the bike in a few years. And I'd like to get the upper guide back on.
As you can see from the pics, the upper guide doesn't sit properly above the chainring.
Thanks
Any suggestions?
Thanks
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Put the crank bolt (8mm hex) back on, cinch but no need to torque it. Put the cover nut with the 10mm hex back on and torque it to spec. You weren't supposed to take that one off. Unscrew the bolt with the 8mm hex and it will ride up on the inside of the nut and extract the crank.
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Quoted: 73 Post(s)
Liked 24 Times
Quoted: 73 Post(s)
Liked 24 Times
I pulled the spacers off the chainguide and now the chain runs in a straighter line. However even when I rotate the bottom of the chain guide away from the chainstays the chainstay is 1-2mm away from the frame. That doesn't seem right. I pulled up Giant's stock picture of the 2015 Glory Advanced 0 and there's a decent amount of space from the chainguide and the chainstay.
I think the thing the chainguide bolts into wasn't set correct at the factory. Can I just pull the drive side crank and move the chainguide mount tab to a more suitable location? Or do I need special tools.
Here's picture of how it should look and what my guide looks like:
Disco Infiltrator
Liked 2,105 Times
I'm not a mechanic but I can help Google! I found this old thread on Pinkbike that says 2005 Glory uses original ISCG in a wide angle version and not ISCG-05, so that's something to check, if you have the right one for your bike
https://www.pinkbike.com/forum/listc...1152&pagenum=2
Genesis 49:16-17
Genesis 49:16-17
Quoted: 73 Post(s)
Liked 24 Times
