Addiction 2022.3
#601
Quoted: 1391 Post(s)
Liked 1,852 Times
I should've jumped on this full squish. These bikes are super fast. I guess I'll have to keep living with my heavier, more metal full squish for now though
https://m.facebook.com/groups/183937...6852838122188/
#602
Liked 1,852 Times
Oh, you'll like it. I recommend avoiding elastomer forks and go with an air sprung or even a coil sprung fork. I had an elastomer fork one time and I put a coil spring kit in it. So much better. Came with a damper, too.
Of course an air fork will need a pump to set the pressure. The ones I've used don't seem to leak, though.
An elastomer fork will be better than a rigid fork, despite my prejudice against them.
but unless / until the elastomers turn to goo and then harden into a solid mass
I'm living that dream now - have an old / early Manitou forks that need some TLC
prefer to replace it with the original rigid fork - but unfortunately so far have not been able to track down the original rigid fork
#603
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3164 Post(s)
Liked 1,818 Times
I woke up at 5:30, drank half a cup of coffee and went back to sleep until 7:30. Still trying to wake up.
#604
Liked 1,852 Times
#605
Liked 1,818 Times
I'm using up the various coffees around the house. Some not very good espresso, some light roast from a snowbird going back North, some Italian roast, Columbian. Mixing it all in the same cannisters. When that is gone I'll settle into something I actually like. There's always instant too. And I actually like that.
#606
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,850 Times
As Trsnrtr sez, tubeless ain't for everything. That said, 5mm is borderline for a good sealant by itself. These look to be close to that - with some plugs, you probably would have made it home without the call of shame. Supposedly, Silca's new sealant takes this up a notch or three, as well.
#607
Quoted: 8259 Post(s)
Liked 8,991 Times
Depends on what you want, long travel or short, and money. You can get XC bikes under 25 pounds, some even under 23, if you want to pay. Longer travel trail bikes tend to be 28+ and enduro types are usually over 30. Mine is 32 pounds but could be made lighter with an infusion of cash.
#608
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,950 Times
Don't think food was an issue, I didn't feel that hungry. But I definitely need a better water plan next year...or better self control.
#609
he said member
Bikes: yes please
Liked 1,950 Times
#610
he said member
Bikes: yes please
Liked 1,950 Times
I was feeling less than stellar on the bike, possibly still a little under the weather from the double vax, though my HR seemed pretty much what I'd expect. So I decided on a leisurely ride, to cap off what I had decided would be a recovery week. So, there I was, at about mile 31, just starting down a short drop that leads to a 180 degree sweeper, when suddenly *PFFFFff!!* and my back tire is instantly flat. I stop, and start spinning the wheel to look for the little piece of glass I expect to find, so I can pop it out, replace the tube and be on my way, when I saw this...
No way I was gonna ride that 25 miles home, not even with a boot. So, I made the Call Of Shame. This time, Mrs. GJ had figured out how to use "Find Phone" and Siri to navigate, rather than having to remember or write down my simple directions.
As it turns out, I JUST bought a new one of those (GP5K in 25mm), because I hate not having a spare tire, in case - well, in case THIS happens.
So, an abrupt end to what had been a nice, relaxing ride. I guess Rango will get a walk today, which he usually doesn't on Sundays. Lucky bastard.
EDIT: Because the tire DEflated so completely all at once, I didn't travel far after. So I was able to walk back along my path and find what I think was the culprit. A piece of glass, with a curve that roughly matches the deeper cut about 1.5 cm long by 4 mm wide. I should have taken a picture, but I did toss it over the guard rail and into the grass.
get a couple of the Park tire boots. You'd still be riding that tire. I have one on the front wheel of the 09 Tarmac. Same situation. Brand new tire. Hit a shard of glass that put a sizable slice in the casing of the tire tread. Still works just fine. I will eventually move it to a rear for safety.
#611
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12736 Post(s)
Liked 7,646 Times
Finally back home after two long days of driving; 600 - 700 mile days, family on-board, can be grueling, even more so when dealing with rain a significant portion of each day. It's funny - it was supposed to rain almost every day that we were in VA, but it never did until we packed up and left. I guess that we should be thankful for that.
Oh, the longer of the two days brought us within ~25 miles of the Buc-ee's outside of Lexintington, KY, but I wasn't about to add another hour of driving just to make a gits-and-shiggles detour.
#612
Bikes: everywhere
Liked 7,646 Times
Might have to drop by the brewery and do some trainspotting a little later. Had two pints there yesterday afternoon and watched a dozen trains go by, probably 80 locos or so but they were all BNSF pumpkins. I was reduced to noting whether they were black letter pumpkins, yellow letter pumpkins or wedge logo pumpkins
I can also partake in trainspotting from my hotel bed, first train by upon opening the curtains this morning had a spicier lash-up in front: a pumpkin, a big black Norfolk Southern, and a War Bonnet.
#613
Liked 11,850 Times
Actually, I realize I was thinking of the holes in the tube. In the tire, the cuts are more like 7mm and 1 cm on the inside of the casing. Others may feel differently, but I would NOT trust a boot to hold that tire together, even to get home. It's 23 miles and several 6% descents.
#614
Liked 11,850 Times
As I think about it, if I had been in an area with no or poor cell reception, I might have booted the tire and nursed it along to someplace with cell reception and a convenient pickup point. In this case, there's a nice shady spot about 200 yards from a major freeway offramp, so it was easy for Mrs. GeneJockey to find me. And if I had booted the tire and then that failed somewhere between there and home, it might not have been as convenient a spot for pickup. Or it might be in a spot with no cell!
#615
Habitual User
Quoted: 4926 Post(s)
Liked 8,048 Times
Likes For Eric F:
#616
Liked 8,991 Times
#617
Quoted: 9648 Post(s)
Liked 6,363 Times
Likes For Mojo31:
#618
Habitual User
Liked 8,048 Times
EDIT: There's a guy on the MTBR forum who has a detailed thread about his lightweight build of a Specialized S-Works full-squish bike. It weighs about 1/2 a pound less than my hardtail, but he's into it for a LOT more money than I am.
#619
Liked 1,818 Times
Likes For seedsbelize2:
#620
Liked 8,991 Times
It's light - 21.0lbs. That includes the dropper post I added, so it could easily be lighter. It has Stan's Podium SRD carbon wheels, which are bumping up against "stupid light" (1300g), and I'm pretty much at the manufacturer's recommended weight limit for them. I need to change the crankset (different length), and found a reasonable deal on a set of XX1s that will drop about 100g (1/4lb). Although losing weight off my fat ass would be a cheaper option (working on it...kinda), a light bike is always fun.
#621
Should Be More Popular
Quoted: 22571 Post(s)
Liked 8,918 Times
Likes For datlas:
#622
Habitual User
Liked 8,048 Times
The Enve 3.4s on my 16lb road bike are heavier than the wheels on my hardtail MTB. Like I said...stupid light. I doubt I would have ever bought these wheels separately, but they were on the bike, so I'm sticking with them.
Likes For Eric F:
#623
Quoted: 20808 Post(s)
Liked 9,450 Times
Likes For WhyFi:
#624
Liked 11,850 Times
#625
Liked 8,991 Times
I hear a lot of the cf wheels come with a lifetime warranty now.
Likes For big john:
