Most important fit measurements?
Old 02-01-23, 05:38 PM
Lombard
Sock Puppet
Lombard's Avatar
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 760 Post(s)
Liked 663 Times in 442 Posts
That is not correct, road bike sizing is by seat tube length a 56 cm bike has a seat tube of 56 cm
Originally Posted by smd4 View Post
Wow. Just…wow.
If you scroll down to geometry specs, you will see Cannondale and Trek don't agree with you:
https://www.cannondale.com/en-us/bik...napse-carbon-4
https://www.trekbikes.com/us/en_US/b...ode=white_grey
Look carefully how long the seat tube is on both of these size 56 bikes. Hint: It's not 56cm.
Lombard is offline
Old 02-01-23, 06:02 PM
smd4
Quoted: 1790 Post(s)
Liked 1,335 Times in 841 Posts
Modern bikes with sloping top tubes would be misleading if they used the actual seat tube measurement. My 58 cm Cinelli (seat tube, c to c) has a 56 cm top tube (c to c). If that was the size of my bike it would be way too small.
If you don’t get that a bike is primarily sized using a rider’s height and inseam to determine a size based on seat tube length, rather than torso/arm length and top tube, then I really have no words.
smd4 is offline
Old 02-01-23, 06:26 PM
tomato coupe
Quoted: 2975 Post(s)
Liked 5,175 Times in 2,099 Posts
I think it's more accurate to say sizing is roughly based on the effective seat tube length, which is measured to where a hypothetical horizontal top tube would intersect the seat tube.
tomato coupe is offline
Likes For tomato coupe:
Old 02-01-23, 06:27 PM
Lombard
Sock Puppet
Lombard's Avatar
Quoted: 760 Post(s)
It sounds like Cinelli and I'm sure others size their bikes different than Cannondale or Trek do. Look again and you will see the top tube length is very close to the stated sizes, though that number skews quite a bit on the smallest sizes.
Lombard is offline
Old 02-01-23, 06:30 PM
Lombard
Sock Puppet
Lombard's Avatar
Quoted: 760 Post(s)
Possibly. Though interestingly, while you see effective top tube length posted, you never see effective seat tube.
Lombard is offline
Old 02-01-23, 06:31 PM
squirtdad
squirtdad's Avatar
Quoted: 1942 Post(s)
Liked 1,877 Times in 1,096 Posts
modern bike bikes use the equivalent sizing.... ie a sloping seat tube bike of 58 will fit like a classic bike of 58 cm
see the size chart for cervelo, it links height to size https://www.cervelo.com/en-US/bikes/caledonia
in fact the size chart for trek that you listed does the same thing , size is equivalent to classic frame size and most direct comparison is height
so to repeat, size is based on seat tube length, either actual lengths in classic designs or effective length in sloping tube designs.....
The effective seat tube length is the distance between the bottom bracket and the point at which a virtual horizontal top tube would intersect the seat tube.
(looking for Torpado Super light frame/fork or whole biked 57,58)
squirtdad is offline
Likes For squirtdad:
Old 02-01-23, 06:32 PM
squirtdad
squirtdad's Avatar
agree
Old 02-01-23, 09:41 PM
rsbob
rsbob's Avatar
Quoted: 1560 Post(s)
Liked 2,919 Times in 1,662 Posts
“Remember darling, don’t be a snook. it’s not how you feel, but how you look marvelous”. SNL
Road and Mountain 🚴🏾‍♂️
rsbob is offline
Old 02-02-23, 08:33 AM
DaveSSS
Bikes: Cinelli superstar disc, two Yoeleo R12
Quoted: 938 Post(s)
Liked 490 Times in 394 Posts
Once you understand stack and reach, frame size numbers become meaningless. A lot of brands use the length of a short seat tube on a sloping TT frame as the size. It doesn't mean a thing. I do pay attention to the seat tube angle on the smaller sizes. A 75 degree STA with a proprietary 15mm setback post we be a no go for me. I'd want 32mm of setback.
DaveSSS is offline
Likes For DaveSSS:
Old 02-02-23, 08:43 AM
Lombard
Sock Puppet
Lombard's Avatar
Quoted: 760 Post(s)
Well, OK. But a person's height also includes their torso length. Arm length is meaningful too.
Where do you see this on the Trek site?
OK, this makes some sense now. I guess I could verify this by taking a level from the front of the top tube and measuring effective seat tube from BB. What I would like to know is why you never see "effective seat tube" listed in specs?
I would agree with this. As we all know too well, a size 56 bike from one brand can be quite different from a size 56 bike from another brand.
Lombard is offline
Old 02-02-23, 10:33 AM
DaveSSS
Quoted: 938 Post(s)
Effective seat tube length was common in the early days of sloping top tube frames, before stack and reach. You don't see that much today. Stack and reach makes selecting the right size so much easier.
DaveSSS is offline
Likes For DaveSSS:
Old 02-02-23, 10:36 AM
smd4
Man, glad I don't have to deal with any of that nonsense!
smd4 is offline
Old 02-02-23, 11:58 AM
Jrasero
Bikes: Scott Foil RC 20, Winspace T1500, Litespeed Cherohala City
Quoted: 98 Post(s)
Liked 85 Times in 51 Posts
Originally Posted by spelger View Post
Looking to buy a new ride and am happy with the fit of my current ride so i'd like to keep the fit as similar as possible. in comparing the geometry of my current ride i find that naturally i am one of those in betweeners. i have this unfounded impression that the two most important measurements would be stack and reach. would that be a correct assessment? or are there other considerations i should also add emphasis to like tube angles or tube lengths?
For smaller riders like myself 5'5", it's simply stand over height, granted SOH doesn't dictate overall fit but if I can't clear the bike then usually the bike's reach and other elements are too big for me either way. For normal sized or taller riders reach probably
Jrasero is offline
Old 02-02-23, 12:40 PM
Calsun
Quoted: 297 Post(s)
Liked 152 Times in 117 Posts
My first consideration is the amount of fork rake with a bike. Chainstay length is also important for climbing. Bikes like the Trek Domane and Specialized Roubaix are excellent in this regard and provide a lot more control at speed on steep down hill roads. After deciding on the bike then I evaluate the size overall. For touring I would go with the larger frame but for general riding the smaller frame if on the fence.
Calsun is offline
Old 02-02-23, 12:56 PM
urbanknight
Over the hill
urbanknight's Avatar
Quoted: 715 Post(s)
Liked 789 Times in 471 Posts
It's my opinion that the most crucial measurements are whichever ones you are close to the limits of. For example, my long femur and religious following of KOPS has me with a saddle slammed almost all the way back on a 25mm setback post and a 73.5 STA, so I simply won't buy a bike with a 74 or greater STA. Others may want a shorter reach to avoid needing a super short stem, or a low stack height for a super aero position. If you are really an in betweener on all those measurements, you're golden and have a lot of wiggle room. At that point you can focus on other aspects, like how the various dimensions affect handling or comfort
It's like riding a bicycle
urbanknight is offline
Old 02-02-23, 01:00 PM
DaveSSS
Quoted: 938 Post(s)
Fork rake (offset) doesn't mean anything without a head tube angle to go with it and a calculation of the resulting trail. You could have 40 or 50mm of offset and the same trail.
DaveSSS is offline
Old 02-02-23, 05:16 PM
urbanknight
Over the hill
Quoted: 715 Post(s)
In other words, the sizing is nominal.
Old 02-02-23, 06:42 PM
rm -rf
don't try this at home.
rm -rf's Avatar
Quoted: 859 Post(s)
Liked 290 Times in 209 Posts
Stack and Reach worked for me when I got a new road bike. I wanted a similar fit to my older bike.
Got an older bike without stack and reach measurements? Here's an easy method -- see this 2017 post.
Using simple measurements with the rear tire against a wall:
rm -rf is offline
Old 02-02-23, 09:32 PM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2612 Post(s)
Liked 2,332 Times in 1,316 Posts
For fit? Stack and Reach.
Kapusta is offline
Old 02-03-23, 08:17 AM
smd4
There used to be a time when sizing a bike wasn't a pain in the ass.
smd4 is offline
Likes For smd4:
Old 02-03-23, 10:18 AM
Kapusta
Advanced Slacker
Kapusta's Avatar
If you want to use the old "X number of inches of standover" or "handful of exposed seatpost" you are still welcome to do that.
Kapusta is offline
Old 02-03-23, 10:24 AM
smd4
Oh. Thanks.
smd4 is offline
Old 02-03-23, 11:07 AM
terrymorse
climber has-been
terrymorse's Avatar
Bikes: Scott Addict R1
Quoted: 1929 Post(s)
Liked 1,858 Times in 974 Posts
If you add an imaginary horizontal top tube to the frame, that old "fist full of seatpost" method still works pretty well. My bike (56cm), fit to me (5'11"), with a fat fist full of seatpost above the imaginary top tube:
Ride, Rest, Repeat
terrymorse is offline
Old 02-03-23, 11:13 AM
GhostRider62
Quoted: 2047 Post(s)
Liked 1,708 Times in 1,093 Posts
will 30mm gp5000 fit with 4mm clearance is key
GhostRider62 is offline
Old 02-03-23, 11:27 AM
Kapusta
Advanced Slacker
Kapusta's Avatar
Well if it works on one person for one bike then it must be reliable
Kapusta is offline
