Electronic vs Mechanical shifting
Old 02-04-23, 02:14 PM
  #76
Steve B.
Quoted: 2749 Post(s)
Liked 1,480 Times in 860 Posts
Originally Posted by Amt0571 View Post
Buy good quality cables and outers and they won't gum up.
I g.
Nonsense. Housings can always get dirt in them, is likely the single biggest reason for deteriorating shifting performance, mt. bikes more than road, but it happens to both. Its usually the first thing recommended as a fix when a newbie on here complains about poor shifting performance. Mechanical is also a slow process, you don't realize sometimes that your shifting sucks as it happens slowly over time. Then you switch housing and cables and are like "I should have done that a while ago".
Steve B. is offline
Old 02-04-23, 02:29 PM
  #77
Amt0571
Bikes: Canyon Grand Canyon AL SL 8.0, Triban RC520 Gravel Ltd, Btwin Ultra 520 AF GF, Dahon Mu P27, Triban Road 7, Benotto 850
Quoted: 392 Post(s)
Liked 188 Times in 124 Posts
Quality housings have rubber pieces that prevent dirt ingress where the cable exits the outer.
Apart from this, lots of mountain bikes use a one piece outer from the shifter to the RD, which also helps.
Then there's the big mistake done people make: lubing the cables. That only attracts dirt and is totally useless when using quality cables and outers.
Amt0571 is offline
Old 02-04-23, 02:38 PM
  #78
wolfchild
wolfchild's Avatar
Quoted: 3580 Post(s)
Liked 2,051 Times in 1,046 Posts
I don't get what's so good with electronics.
Electronics do have their place, just not on a bicycle.
wolfchild is offline
Likes For wolfchild:
Old 02-04-23, 02:50 PM
  #79
GhostRider62
Quoted: 2047 Post(s)
Liked 1,708 Times in 1,093 Posts
Originally Posted by smd4 View Post
If people are having to adjust and tinker with their mechanical derailleurs or cables with the frequency suggested here, they’re doing something wrong.
Once properly adjusted, mechanical derailleurs are also “set and forget.”
Nobody is saying that.
But are you honestly going to say there were not two generations of Shimano shifters that did not chew up cables in 4-5,000 miles?
Or that new cables, housings, and ferrules do not require time to seat and/or stretch? After which one has to adjust.
Or that barrel adjusters aren't pretty much standard equipment, why is that
I think what I hear is electronic is set and forget. I have never had a mechanical shifter setup that was set and forget unless I go back to my 70's downtube campy friction levers.
GhostRider62 is offline
Old 02-04-23, 03:03 PM
  #80
tomato coupe
Quoted: 2993 Post(s)
Liked 5,193 Times in 2,109 Posts
Originally Posted by terrymorse View Post
Electronic shifting is a spiffy technology, to be sure, but it's a "tech bro" technology. It is not solving any problems.
You can make that argument about almost every development in bicycles in the last 100 years, but that doesn't mean those developments don't offer advantages.
tomato coupe is offline
Old 02-04-23, 03:15 PM
  #81
smd4
Quoted: 1805 Post(s)
Liked 1,356 Times in 854 Posts
Did you not read the part I wrote about “once properly adjusted?” I use downtube shifters and have never once worried about frayed cables, gummed up cables, or any additional adjustments once properly set.
I’d much rather have my Seiko automatic than any digital watch.
smd4 is online now
Likes For smd4:
Old 02-04-23, 03:31 PM
  #82
georges1
Steel is real
georges1's Avatar
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1997KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon(to be built),1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 197 Post(s)
Liked 327 Times in 205 Posts
I have always used mechanical shifting even the 1992 Altus c10 Transmission on my Giant Tourer works like a swiss watch, same with my 1991 raleigh with its campy record synchro II 7speed down tube shifters to be upgraded and even my 1992 Peugeot with its sl 7700 dura ace 9 speed shifters to be upgraded . Even with the fully XT780-T transmission on my mountain bikes ,it shifts amazingly fast. I have tested the mavic mektronic and the ZMS but wasn't convinced back then. Quality cabling is a mandatory with mechanical derailleurs
georges1 is offline
Old 02-04-23, 03:52 PM
  #83
DaveSSS
Bikes: Cinelli superstar disc, two Yoeleo R12
Quoted: 946 Post(s)
Liked 494 Times in 398 Posts
The above belongs in the vintage forum. No one here cares.
DaveSSS is offline
Likes For DaveSSS:
Old 02-04-23, 03:59 PM
  #84
tomato coupe
If they're friction shifters, aren't you essentially adjusting them every time you shift?
Likes For tomato coupe:
Old 02-04-23, 04:00 PM
  #85
georges1
Steel is real
georges1's Avatar
Quoted: 197 Post(s)
Not everyone likes electronic shifting Dave whether it is from SRAM or Shimano. What do you do in case your electronic derailleurs have their battery dead and that you are climbing a hill ??
georges1 is offline
Old 02-04-23, 04:06 PM
  #86
Lombard
Sock Puppet
Lombard's Avatar
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 777 Post(s)
Liked 677 Times in 449 Posts
I used to swear up and down that I would never get electronic shifting because mechanical shifting has gotten so good. I am warming to it for my next bike since everyone I know who has Di2 loves it. I am also sick of changing internally routed cables and Shimano shifters eat through a lot of those.
If I were to go electronic, I would go with Shimano Di2. I have heard too many stories of broken battery tabs on SRAM eTap.
If I were to go mechanical, I would go with SRAM as I am sick of how often Shimano shifters eat cables. I now have SRAM Force 22 on my road bike.
Lombard is offline
Old 02-04-23, 04:08 PM
  #87
DaveSSS
Quoted: 946 Post(s)
It will never happen with SRAM AXS because I pay attention to my battery charge level. If you make a shift before the start of a ride and get a green light, you're good for 100 miles or more. I carry a spare battery for shifters and derailleurs, so it might take a minute to change, then continue riding. Only a dummy gets stranded.
It's like breaking a shift cable, but I'm back in business a lot quicker.
DaveSSS is offline
Likes For DaveSSS:
Old 02-04-23, 04:20 PM
  #88
georges1
Steel is real
georges1's Avatar
Quoted: 197 Post(s)
the cable eating shifters from shimano were and are the 7900,9000 and 9100 series regarding mechanical shifters . But always value good cables when installing those
georges1 is offline
Old 02-04-23, 04:22 PM
  #89
tomato coupe
the cable eating shifters from shimano were and are the 7900,9000 and 9100 series .
How does that translate for the Shimano-impaired? 10 speed? 11 speed? 90s era? 00s era?
Old 02-04-23, 04:30 PM
  #90
terrymorse
climber has-been
terrymorse's Avatar
Bikes: Scott Addict R1
Quoted: 1962 Post(s)
Liked 1,907 Times in 1,001 Posts
Plenty of innovations have solved real problems. A few from memory:
  • high pressure clinchers with hooked rims
  • indexed shifting
  • integrated brake/shift levers
  • carbon fiber for frames, rims, components
  • disc brakes
  • low pressure tubeless tires
Not on that list:
  • electronic shifting
Ride, Rest, Repeat
terrymorse is offline
Old 02-04-23, 04:37 PM
  #91
tomato coupe
  • indexed shifting
  • disc brakes
Not on that list:
No, you've just drawn a fuzzy grey line and declared that those things are on the side of "solved real problems" and electronic shifting not.
Old 02-04-23, 04:41 PM
  #92
georges1
Steel is real
georges1's Avatar
Quoted: 197 Post(s)
It is mostly to the 00's era from2006-2007 and with10 speed and11 speed groupsets .
georges1 is offline
Likes For georges1:
Old 02-04-23, 04:46 PM
  #93
Jeff Neese
Quoted: 755 Post(s)
Liked 381 Times in 256 Posts
Originally Posted by jaxgtr View Post
I think one of the biggest benefits is the set it and forget it. Unless you bang it out of alignment, once you set it up, you rarely if ever, have to adjust it.
I rarely have to touch the cable-operated gearing on any of my bikes. I've gone years without adjusting anything.
Jeff Neese is offline
Likes For Jeff Neese:
Old 02-04-23, 05:47 PM
  #94
smd4
I guess, if they were friction…
smd4 is online now
Old 02-04-23, 05:49 PM
  #95
tomato coupe
Are they indexed?
Old 02-04-23, 05:50 PM
  #96
smd4
Are they indexed?
Definitely.
smd4 is online now
Old 02-04-23, 05:53 PM
  #97
Atlas Shrugged
Quoted: 759 Post(s)
Liked 867 Times in 426 Posts
Since you are climbing a hill you would continue.
Atlas Shrugged is offline
Old 02-04-23, 05:54 PM
  #98
tomato coupe
Definitely.
I would have thought that most fans of down tube shifters would opt for friction, to attain the ultimate in simplicity.
Old 02-04-23, 05:56 PM
  #99
Atlas Shrugged
Quoted: 759 Post(s)
The would has moved on decades ago from these archaic systems. Glad you enjoy them but they play no role in modern cycling or this discussion.
Old 02-04-23, 05:57 PM
  #100
smd4
Guess you thought wrong. Of course, if something happens to screw up the indexing, I can always switch to friction with the turn of a D ring.
smd4 is online now
Likes For smd4:
