Electronic vs Mechanical shifting
Likes For smd4:
#102
Quoted: 759 Post(s)
Liked 867 Times
People with vintage cars feel the same way about carburetors, points, bias ply tires, manual transmissions and am radios. Interesting but obsolete. There is a reason there are no manufactures selling down tube shifting bikes it is a vestige of a time gone by.
#103
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1997KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon(to be built),1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 199 Post(s)
Liked 329 Times
They do since the title of the thread is comparing Electronic vs Mechanical shifting. So modern mechanical non DI2 SL 7900,9000, 9100, 6600, 6700,6800 and 8000 shifting levers are archaic according to your definition??? Very interesting to know...
Likes For smd4:
#105
Quoted: 2998 Post(s)
Liked 5,204 Times
#106
Steel is real
Quoted: 199 Post(s)
Liked 329 Times
Yet there are still brands some who are selling frames where you can install down tube shifters. Though shimano doesn't make the down tube sl for 11 or 12 speeds, other brands do and some people use down tube shifters.
#107
Steel is real
Quoted: 199 Post(s)
Liked 329 Times
Likes For georges1:
#108
Quoted: 1579 Post(s)
Liked 2,952 Times
I have one of Campy’s first indexed down tube shifters and it works great after all these years. Still prefer it to friction. But then, I prefer my Campy Gen 1 Ergos to that. Can’t say that my latest and greatest Shimano brifters (manual) are much of an improvement over the Gen 1 Ergos.
Road and Mountain 🚴🏾♂️
#109
climber has-been
Bikes: Scott Addict R1
Quoted: 1985 Post(s)
Liked 1,931 Times
Actual problems solved:
- high pressure clinchers - fussy and expensive tubulars
- indexed shifting - user errors and steep learning curve with friction shifting
- integrated brake/shift levers - must move hands away from brake levers to shift
- carbon frames - corrosion, fatigue failure (and others)
- disk brakes - poor wet weather braking, friction-induced blow offs
- low pressure tubeless tires - pinch flats
Ride, Rest, Repeat
Ride, Rest, Repeat
#111
Liked 5,204 Times
Challenge accepted.
#112
climber has-been
Liked 1,931 Times
#113
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 785 Post(s)
Liked 684 Times
Yes, the problem started when Shimano went to under bar tape routing which was 5700/6700/7900. AFAIK, all the generations after this have the problem. I had the problem on 5700, 5800 and 6800.
Likes For Lombard:
#114
Quoted: 2566 Post(s)
Liked 2,755 Times
another question related to a new bike i am looking at. for those of you that ride with electronic shifting do you think you would ever or never go back to mechanical? its an option for me that brings up the price a bit and am a bit on the fence about it. my accountant says its in my budget so am leaning toward it. in my reading up about it though it really sounds cool.
#115
Bikes: yes, i have one
Quoted: 886 Post(s)
Liked 938 Times
Plenty of innovations have solved real problems. A few from memory:
Not on that list:
- high pressure clinchers with hooked rims
- indexed shifting
- carbon fiber for frames, rims, components
- disc brakes
Not on that list:
- electronic shifting
Likes For spelger:
#116
Liked 5,204 Times
Friction shifter: "Push the right lever up to shift to a higher gear in back."
You're right, friction shifting is a lot harder.
#117
Liked 5,204 Times
Likes For tomato coupe:
#119
Quoted: 758 Post(s)
Liked 385 Times
Yeah, indexing became all the rage in order to get more newbies into cycling and make it less intimidating to work "all those gears". Electronic shifting just takes it to the next level. Now anyone can use the gears on their bike - no skills or practice necessary. I'm partial to friction shifting myself.
#120
Liked 2,755 Times
I thought your original question might put them off as they didn’t qualify, but they just can’t help themselves.
#121
Quoted: 2845 Post(s)
Liked 2,007 Times
Likes For seypat:
Likes For smd4:
Likes For smd4:
#124
Liked 5,204 Times
