Where To Leave Lever?
Old 12-05-20, 02:16 PM
CanadianBiker32
CanadianBiker32's Avatar
Bikes: Maxim, Rocky Mountain, Argon 18, Cervelo S2 Team
Quoted: 165 Post(s)
Ok bike is a fat bike. Trek Farley.
On rear wheel I have those newer skewer type of things for the wheel. Not the older quick release
Where you lock the lever and you have to put the whole skewer in and out which holds the wheel.
Last ride. The skewer came loose.
I think i may had hit a rock or branch and it turned the lever
What is the safe position to leave the lever at? and to lock
should i make sure the lever is always in the up position?
this is similar to what I am referring to
CanadianBiker32 is offline
Old 12-05-20, 02:21 PM
CargoDane
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times in 199 Posts
Up. Along the upper chainstay or just behind it if it folds "deeper" (more inwards than the chainstay allows.
Edit: Or you could place the lever on the right side, pointing down or slightly back from that, which, if you hit something, will result in the lever being turned to make things tighter.
CargoDane is offline
