Powder coaters you like - post them here!
#101
If I own it, I ride it
Quoted: 591 Post(s)
Liked 662 Times
Another case of cameras and monitors not reproducing a true color. It was Red Anno, which required a base coat which I think was silver. The rims were available in red from Ambrosio.
#102
Bikes: a few..
Quoted: 82 Post(s)
Liked 146 Times
From this..
to this...
Mark Rainey @ Groody Bros. did the frame,fork,and original Jim Blackburn rack, in Prismatic Volcan Blue with clear over the decals. Mark also added downtube braze-ons,another set of water bottle mounts, and spread the rear to 128mm so I can run either freewheel or modern. Mark does great work!
#103
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 385 Post(s)
Liked 690 Times
Chris Pauley Tierra
Twinsies!
(if you ignore all but the color theme of the frame, cables, and bar wrap )
Likes For mtbikerjohn:
#105
Quoted: 359 Post(s)
Liked 582 Times
Sending sloar 's Black Lightning and a Terry and a Rossin.
I've now seen him at 3 events, and his stuff is good. Nice guy.
What's neat, is he takes bikes to ride, so he and his wife walk the walk, too.
He has an XO-1 knockoff that's as good as the original, but looks better.
#106
Bikes: a few..
Quoted: 82 Post(s)
Liked 146 Times
#107
CV-6 TullySteve Here is the result of my project, Illusion Copper Plus done by Pike Powdercoating in Allston, MA.
Likes For rsacilotto:
#108
john903
Bikes: Curtlo, CHE cos'e,
Quoted: 27 Post(s)
Liked 36 Times
I have one to add. I have used them once on a friends frame. $125.00. I have also had several parts done like racks in basic black and he just does them whenever he has a batch for others and it was $10.00. So if you are out here on the Peninsula and need powder coating your old Hotrod car, Motorcycle, C&V bike give him a call. And yes he is very careful with the frames knowing they are usually thin material. It is nice knowing he takes care of handling your frame.
Dog House Powder Coating
503 S. 3rd st. Sequim, WA. 360-681-5412.
Likes For john903:
#109
Originally Posted by rsacilotto;[url=tel:22565599
22565599[/url]]by Pike Powdercoating in Allston, MA.
#110
I've been meaning to post on this thread, finally had a sunny day off to take some pictures. This Univega Gran Sprint was done by a guy named Cameron who is friends with the owner of the LBS I work at in New Orleans. He's a former bike shop owner who has his own fabrication and paint shop. No business information as he mostly subcontracts for the film industry in town, but PM me if you'd like his phone number. He charges $150 to media blast and powdercoat a frame and fork, including acetone bath, masking, and cost of powder from powderbuythepound. He also has a dip tank for frames that have already been powdercoated. Turnaround is about two weeks depending on what else he's working on. Check out the definition on the thinned lugs.
I had him do another frame in gloss black and he wasn't happy with the finish, so he offered to redo it for free or give me half off, a deal I was happy to take on a bike I plan to flip. Excellent guy.
Can Clear coat be sprayed over powder coat?
#112
Bikes: Cannondale Synapse, LeMond Victoire, Bianchi Campione d'Italia, Kona Hei Hei, Ritchey Ultra, Schwinn "Paramount" PDG, '83 Trek 640
Quoted: 267 Post(s)
Liked 324 Times
#113
You don't, mostly because this is extremely rare, and powder coat will cover mistakes. In addition, this might be an issue if the frame was very thin walled (0.5-0.6mm wall thicknes, IMO). Something that thin would not be a production frame, and more likely to be wet painted by a reputable painter.
Personally, as long as you use someone that's used to powder coating bike frames and has a good track record, you're good.
I assume there shouldn’t be any powder coating on the threads or press fit areas like headset and bottom bracket, anywhere else like dropouts?
What about blasting media types? Are certain ones okay to remove rust on threads, seat tube inside, and bottom bracket shell?
If successful, happy to expand the OP list with new shops.
#115
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4677 Post(s)
Liked 5,790 Times
If we seek out places that advertise primarily on the automotive side, but express willingness to work with bicycle frames, what stipulations or requirements should be expressed to them?
As far as blasting media goes, I've used a half dozen powder coaters, and I always ask that question. They seem to be all over the place, but I can tell you that none of them use crushed walnut shells or other organic material as it can leave an oily residue, which would then require a solvent to remove. From what I gather, I think it's more important to control how you're media blasting. Pressure, distance and angle are things to consider. Note that I'm not an expert on it, just feeding you what I've heard from various powder coaters. And no, I don't know what pressure, distance and angle that should be used.
I would not media blast inside the tubes, and definitely not media blast threads. All threaded surfaces should be masked, but again, it's easy to run a tap to clean these up if your coater misses some. I always face and chase BB's and head tubes, and run taps through all threads before rebuilding from a raw frame, regardless of whether there's new powder coat or not.
If anybody's willing to try a powder coater that hasn't done bicycles in the past, let me know how it turns out and I'll add them to the list.
Likes For gugie:
#116
Liked 5,790 Times
Yes it can, but most powder coaters aren't set up to do so. One I know farms it out, I think Groody Bros. does it in house. If you're decaling after powder coat it's worth the extra cost to clear coat over them.
This one has a clear coat over decals
#117
Quoted: 1391 Post(s)
Liked 1,852 Times
Color Factory / Bruce Riseley
I believe he is in New Jersey
he did a number of frames for a friend
#118
Quoted: 346 Post(s)
Liked 394 Times
https://www.jrpwracing.net/powdercoating/
https://www.jrpwracing.net/speed-shop-scholar/
phone 706-863-1206 , fax 706-863-1928, contact person: Jimmy Rivers
one of the e-mail contacts there: jrpracing@gmail.com
business is located at: 200 ROSE STREET, MARTINEZ, GEORGIA 30907
( they are located approximately 7 miles WEST of Augusta National Golf Club.....JRPW (Rose Street) is just off Washington Road, behind CSRA CAMPERLAND RV SALES, near CAROLINA POTTERY before you get to Bobby Jones Expressway....... in the area between Davis Road and Bobby Jones Expressway, just about a 1/2 block south off of Washington Road in Martinez GA, where you'd be 7 miles WEST of AUGUSTA NATIONAL GOLF CLUB which is at 2500 Washington Rd, Augusta GA 30904)
#119
Thanks. I thought about having it powder coated and then put my decals on and clear coating it myself or having a body shop clear coat it. The issue is the prep work, I believe I have found a powdercoater that will strip the frame, the body shop will not. I'm going to be moving soon so everything is being put on hold and my bike stuff is getting packed away.
#122
Quoted: 174 Post(s)
Liked 243 Times
As an update, Santiam Powder Coating is done for. They closed shop about a year ago and since then, I've been trying and trying to get Roy to do one, single frame for me even though his phone messages says, "we are NOT doing business any longer". He strung me along for a few months, then after 3 or 4 messages and emails without replies, he stopped. And so did I. Maybe he'll be back one day but as of right now, this is not a viable powder coating solution.
The Simplicity of Vintage Cycles
#123
Bikes: 2000 Serotta Hors Categorie, 1990s Lennard Zinn, 1985 Guerciotti Jet, 1975 Peugeot PX-10,
Quoted: 44 Post(s)
Liked 118 Times
Forever Powdercoat, Olympia Washington
Investment cast seat lug with fastback seatstays.
Mark added René Herse Cycles mounts for Mafac centerpull brakes.
Overall view of the frame. The fork is still wrapped up!
Cast dropouts with internal rear derailleur cable routing retained.
I got my 1985 65cm Trek 660 Rando project back from Forever Powdercoat 3 weeks ago. Purchased from RiddleofSteel and modified by Gugie.
Single color powdercoat for $337. It would have been cheaper but I lost the powder I bought and had intended to supply myself…🙄
#124
Liked 5,790 Times
A viable option for you maybe to drive up to Portland and have Jason at CC Coatings do it for you. Page 1 of this thread has the link.
Likes For gugie:
#125
Quoted: 174 Post(s)
Liked 243 Times
Thanks, @gugie. I went a different direction with the build, which I think is a better fit.
As for CC Coatings, (Formerly Class Act), back when I was living in Portland, I got mixed reviews. Norther Cycles said they "were good but quality control dropped so we sourced elsewhere". But then Cooper Cycles stated he used them for solid, straightforward work and had excellent results. I did hear that they had a powder + clear option and were able to mask decal areas, which is fascinating if true. Though I'm not sure the validity of any of this.
Nice to know this is an option for a short drive!
