Garmin Edge Explore 2 (based on 1040)
Quoted: 18883 Post(s)
Liked 10,645 Times
https://www.garmin.com/en-US/p/802162
Sounds like an update to the previous Explore model, not surprisingly. You get maps but not power or workouts. This has the new UI from the 1040 which is reported to be easier and have less learning curve.
ignominious poltroon
Quoted: 2184 Post(s)
Liked 3,336 Times
The mount that allows you to recharge it in situ looks new as well. That could be useful for long hauls. The thing looks as big as a 1040.
It also is touted as being e-bike compatible, but I can't seem to find out what the compatibility criteria are. (Wife has an e-bike now.)
Edit:
Edit:
compatible with Shimano Steps or ANT+® technology,
Quoted: 3185 Post(s)
Liked 2,020 Times
Slightly improved battery life, up to 16 hrs. from 12 on the older Explore. A buddy has the older version, its about the same size as my 1030.
Liked 10,645 Times
This controls smart trainers and works with power meters after all.
At $300 this looks like a better buy than the 1030+ was at $450?
Quoted: 2575 Post(s)
Liked 1,900 Times
Liked 3,336 Times
My wife has an e-bike (Bosch-motor based). It is remarkably incompatible with everything (supposedly using a Garmin will mess up its own sensors), and has been a source of frustration. It looks like all this does is display battery content and projected distance to empty, and other stuff already displayed on the e-bike head unit.
Quoted: 679 Post(s)
Liked 945 Times
Liked 3,336 Times
Her Bosch head unit displays a warning that a Garmin might interfere (I assume if it hogs the ANT+ sensor connections).
Liked 2,020 Times
Likes For Steve B.:
Liked 3,336 Times
I cannot think of anything a Garmin cycling computer could do to mess up an e-bike. It can transmit data vis BlueTooth and WiFi but if thats whats causing problems with the E-bike, you've got bigger problems as a lot of things like cell phones do that as well. The Garmin, when not trying to communicate with another device is only listening to satellite signals.
Likes For Polaris OBark:
DCRAINMAKER did a review
https://www.dcrainmaker.com/2022/07/...th-review.html
I really like it except that it doesn’t have DI2 integration. Still going to think about it
Likes For hammond9705:
Quoted: 679 Post(s)
Liked 945 Times
no only bluetooth. is the smartphone hub? no ant+ on bosch I wish it had it. bosch is all wired too no wireless sensors till their new systems come out.
Liked 3,336 Times
Liked 10,645 Times
I think what Bosch has in mind is that if you add the cadence, speed etc. ANT+ sensors to the Garmin, they might not be available to the Bosch unit. I don't know if this is true (i.e., that a Garmin would "hog" the device connection), having never tried it, but I think that is what the Bosch head unit is warning against. Ideally, it would be nice if the user could use both simultaneously.
Liked 3,336 Times
You are right that the speed/cadence is wired. There is some object that says "Cannondale" [correction] on the front spokes near the hub that isn't.
Liked 3,336 Times
ANT+ is many to many but BT is one to one. Or at least has historically been. I agree with @Steve B. that it shouldn't be an issue. I've seen as it of cases where computers do things people weren't expecting. And I've also seen overly cautious people trying to avoid having to support more than they're capable of.
Quoted: 679 Post(s)
Liked 945 Times
It is this: https://www.cannondale.com/en-us/bik.../synapse-neo-1
You are right that the speed/cadence is wired. There is some object that says "Garmin" on the front spokes near the hub that isn't.
Liked 3,336 Times
Sorry, I mis-typed. It should say "Cannondale" for the branding on the front wheel. The website calls it the "Cannondale wheel sensor" and now that I think of it, it MUST be Bluetooth, because it is what communicates (wirelessly) to the Cannondale app on her phone. In fact, you can spin the front wheel to activate it. It transfers all the info from the ride (except it has no GPS) to the phone app. So why the head unit *****es about the Garmin's presence is beyond me.
