SPD-SL cleat interference with shoes
I just bought some SPD-SL cleats for my SIDI shoes. The bolt pattern matches, but there is a bit of interference with the cleat on the back corners with a 2mm raised section of the shoe bottom. I can either file off the corners of the cleats where they hit, or I can remove the plastic area from the shoe. I'd rather remove from the cleat, but if that can cause problems with their function, then I'll go after the shoes. Which do you recommend? If I don't remove some material, the rear screws won't engage.
Fit of pedal
Interference @ back corners
~2mm step up @ corner
Fit of pedal
climber has-been
Quoted: 3427 Post(s)
Liked 3,564 Times
Likes For terrymorse:
Thanks.
Quoted: 4806 Post(s)
Liked 3,928 Times
Yeah, cut away the shoe. Your next cleat will have the same issue. (Cleats are consumables. My shoes go through a half dozen or more of those plastic ones.) Don't even think about going to longer bolts. Yes, they will get you riding but as you put weight on the cleat, the cleat will settle in and loosen the bolts. So you add a few tightening turns. And eventually bottom out on the bolt holes. But you will eventually need more and if you forget, you either seize the screw or break the socket to shoe attachment/bond.
Likes For 79pmooney:
Licensed Bike Geek
You need the SIDI piece that fits in the cavity between sole and cleat. It used to be provided when the shoes were purchased
It's been many years since the Sidi's were bought, so if I had it, it's long gone. An angle grinder took care of my problem in no time flat, and left me with even less weight than an insert.
