how do you measure spoke nipples?
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Okay, first of all, pardon me for being a cheapskate! I take recycling seriously, that's all.
Short version: how can I measure spoke nipples to figure out whether they will fit the spokes I'm using to rebuild a wheel? I have a lot of nipples in the bin, and I can't tell if they're all the same size or not.
Long version:
A few years ago I built a wheel, using a Sturmey Archer AW hub (alloy shell, 36h, very nice) and an unremarkable recycled 27" rim. And apparently I didn't tension the spokes right; after a couple years of commuting I broke a spoke. A couple months later I broke another one. Then I broke two. And I concluded, time to replace all the spokes.
Fortunately, I had 36 spokes of the same length in my spoke drawer, so I just rebuilt the wheel. Or so I thought.
But no. Now the nipples pop off the end of the spoke just before I get them up to tension.
I presume I have the wrong size nipples on the spokes.
Obviously I could just buy new spokes with matching nipples. In fact it will probably come to that. But if there's a way to measure the nipples in the bin, and find the correct ones for the spokes I'm using, that would be my first choice. Suggestions?
Long version:
www.rhmsaddles.com.
www.rhmsaddles.com.
30 YR Wrench
Bikes: Waterford R-33, Madone 6.5, Trek 520
Quoted: 6556 Post(s)
Liked 58 Times
Yeah, you seem to have 1.8 mm spoke threads and 2.0 mm nipples. You can't check them on a 1.8 mm spoke, because they fool you until you get up to near end point tension. So you need a 2.0 mm spoke to test them. The ones that thread on are 2.0, the ones that don't are 1.8 and will fit the spokes you are trying to use to rebuild the wheel.
Really Old Senior Member
I'd just get a drill bit that will barely slide into a 2.0mm nipple but not a 1.8mm.
Probably a 49
Probably a 49
Quoted: 5779 Post(s)
Liked 2,576 Times
Faster way to check.
Cut the threads off a 15g spoke (or cut a 14/15g spoke in the middle). The bare 15g (1.8mm) wire will not slip through a 15g nipple, but will pass through a 14g nipple. So you hnw have a fast reliable go-nogo gauge for spoke nipple classification.
FB
Chain-L site
FB
Chain-L site
multimodal commuter
Liked 574 Times
Thanks for all the suggestions! I should have thought of this myself!
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 7348 Post(s)
Liked 2,465 Times
I have a box of brand new DT 15g nipples, if you want some.
agmetal
Bicycle Mechanics
7
09-21-17 01:46 PM
totalnewbie
Bicycle Mechanics
2
06-28-15 02:21 PM
