Interested in custom framebuilder
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
Santa Cruz has Caletti, Rock Lobster and Calfee. Unless the $3K is just for the frame and fork, this might be out of the price range, but you will get a superb bike.
Quoted: 321 Post(s)
Liked 263 Times
1. Reduce the chainstay length by about 19mm
2. Reduce the BB drop by about 19mm to have the same ground clearance
3. Reduce the head angle by a bit (about 1 degree) to keep the trail the same
Likes For guy153:
Quoted: 18 Post(s)
Liked 39 Times
I have enjoyed using the 'bike insights' website for comparisons. ( https://bikeinsights.com/ ) No, I don't design using this website. But, when doing things like comparing an old 26" MTB ride with a 29er it can be handy to understand where the BB/ground points, stem, and saddle all land even though the geometry may be totally different. Or, for instance, when comparing my 650c stretch bike with a frame in 700c wheels. It is sort of a sanity check for me. (while there is a library of bikes, I'm usually comparing custom to custom so I just input data for both bikes) To be specific, I like the 'overlay' feature of the bikes for my sanity check. Below is a picture of a 2006 specialized that fit me well and a Ti MTB frame I was building for myself. The front end height was significantly different due to the 30mm travel front for from 2006 and the 120mm travel fork from 2021. The 2006 was 26" and the 2021 was 29".
simon
Quoted: 18 Post(s)
Liked 39 Times
Standard size wheels (700C or 650B - both tires are about the same outside diameter).are a huge disadvantage for smaller people. The result is massive toe overlap with the front wheel. Some is tolerable for some people. A lot is not good for anyone. Smaller wheels is a much better solution.
I did admire the old Terry frames with the 700c rear wheel and 24" front wheel. Nice way to keep the steerer 'long', the handlebars at a reasonable/dropped height, and avoid front wheel overlap with short top tube bikes. Having to manage two different size wheels/tires/tubes/etc was the price.
Front wheel overlap is one of those 'things' that normal people don't think about until you have a bike that has it, and then you never forget. So be aware!
framebuilder
20mile/day commuting at 13mph average with 100mile on road or 30mile gravel/single track on the weekends. 3 or fewer people at any time. I’d like an all road bike so I can use it for both commuting and weekend riding. Come to think of it, a 26” gravel/all road bike might be perfect.
I’ve had good success running 650c x 25/28mm Panaracer Paselas on my old Trek WSD road bike. There’s a 3” saddle to bar drop on that one which is as far as I’d like to go. I’d raise the bars 10-20mm if I could, I don’t want to put a goofy 20mm rise stem on the bike though. I just wish there were more wide tire options in 650c.
Raising your handlebars will most likely balance your weight better over the pedals taking the weight off of your arms holding up your upper body. As they are raised, you probably will be more comfortable with your saddle going back. The 2 go together. I'd be willing to bet the seat angle on your present frame won't allow enough of that. Production frames use steep seat angles to avoid the liability of toes hitting the 700c front wheel. Their motive is to stay out of court instead of positioning you right. A custom builder can put your saddle where it is best.
A bike with smaller 26" wheels looks more proportional and balanced for shorter people. Here is a picture of a bicycle I made and painted for my 5' 4" daughter. Her handlebars are level with her seat. I prefer the looks of lugs. You can see I extended the top tube lug so her stem doesn't have to be angled drastically up, She is a go-fast rider (it is all I can do to stay on her wheel) so I made it with 650c X 28 wheels. However I carefully positioned the length of the fork and the brake bridge so by changing her 39/49mm brakes to 47/57 brakes I can use MTB size wheels (559 ERD). The difference in rim radius is 5mm. That allows me to put on a 26" MTB size of wheels so a fatter tire can be used. It is possible you might be able to do this on your present bike. If you want to explore that possibility you will have to take some measurements which I can describe.
If you are going to have your frame made out of steel, you will want your builder to use light thin-walled tubing. This isn't for weight saving so much as light tubing provides a better feeling bike. Production companies have to assume someone that weighs a billion pounds might ride and break it. Therefore they need to use heavier-than-what-you-need tubing.
The two tone gray is to compliment the color on her Dura Ace components.
Ah, yes! Starting a new frame build from an existing bike design is great! 'I like this, I don't like this'
simon
simon
Doug Fattic thats a gorgeous bike you built for your daughter. It’s awesome to see taller head tube on a small frame. I’ve yet to find a smaller frame that can also fit a frame bag and/or two bottles in the main triangle.
Also, the 3” drop is with 40mm of spacers so I’d definitely like a taller head tube.
I greatly appreciate all the advice and recommendations you all have given me! I’m getting excited to start putting together what I might want for my custom bike.
Likes For bt_bp:
Quoted: 2482 Post(s)
Liked 2,955 Times
Another vote for Franklin Frames. Met him in the mid-'80s, early in his framebuilding career---very down-to-earth, no-nonsense guy. Impeccable craftsmanship.
