Downtube shifters conversion
I have a 1980s Peugeot road bike with downtube shifters. I hate using them and I find them really finicky. I was planning on doing a bit of an overhaul anyways including a new rear derailleur, cassette, chain etc. I was wondering if it would be fairly simple to convert everything all at once or if it will still be a pain? I would probably pair the DR with the shifters anyway.
Quoted: 3426 Post(s)
Liked 2,816 Times
Do you want to use integrated shift/brake levers (what are found on most road bikes today), or bar-end shifters?
Quoted: 835 Post(s)
Liked 1,053 Times
If you're asking about the downtube cable stops for brake/shifters, bar ends, then there are a few options. I like the Shimano ones the best and this is one of the cheaper sets. SHIMANO STI Road Bike Downtube Shifter Housing Stops Barrel Adjuster Concave Set | eBay They also make a more expensive version that's marginally better and make sure you get the correct version..flat or concave to fit your frame and bosses.
Likes For Crankycrank:
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4310 Post(s)
Liked 2,953 Times
You're looking at a lot of compatibility issues you don't even know about yet.
Likes For DiabloScott:
Just Pedaling
Bikes: YEP!
Quoted: 313 Post(s)
Liked 491 Times
Like Diablo said, you're looking at opening a can of worms. I have a vintage Giant that I really like with stem shifters that I've been threatening to convert to STI Brifters for a long time. There's too many reasons for not having done it (yet). With that said, lots of people have done it. Depends on how deep your pockets and how determined you are. Sometimes it makes more sense to look at a newer used bike (got those too) Good luck,
Likes For SpedFast:
Quoted: 1106 Post(s)
Liked 1,197 Times
I don't know about compatibility issues. Does an 80s Puegeot have French threaded parts still? If they're English treaded, other than a possible need to spread the rear triangle to 130mm from whatever it is to accommodate 8+ speed wheel hubs and cassettes, there won't be any compatibility issues, just cost of new parts and every "modern" component can be fitted.
If French treaded, both headsets and bottom brackets are available from places, Velo Orange for one. A 1" threaded headset and quill stem can be easily changed to modern threadless stems if needed - or left as is with the current handlebars or any number of good 1" handlebars that are still available.
A new French bottom bracket will probably be square taper, but there are plenty good cranksets of various gearing, that are square taper and the "disadvantages" of the older bottom brackets and cranksets are generally not a factor at all for the recreational cyclist. Or even racers in fairly recent times past.
If the BB is English treaded, practically any current crank and its threaded bottom bracket can be fitted. If the current BB is ok and the gearing of the current crankset works for the rider, no need to change them at all. They will work fine with new shifters and derailleur.
I don't mean to trivialize about the cost of new parts. A complete upgrade, is a complete upgrade whether it's a 20 year old bike or a 40 year old bike, the cost would be the same. I was addressing compatibility which might or might not need to be addressed, but it is easily addressed either way.
As to the original post - adapting downtube shifter bosses to cable stops is easy, they're readily available.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3846 Post(s)
Liked 6,437 Times
