Tubing Mark ID
Quoted: 3807 Post(s)
Liked 3,331 Times
Tubing Mark ID
This tubing mark on the right chainstay of an unidentifed British machine which looks to date from the late 1940's is a new one for me.
A letter B can be clearly read inside an elongated diamond symbol. As I enlarged the image I kept hoping the B would become a P for an A&P mark but such was not the case...
Will be a slam dunk for our experts!
Mark is immediately above the drewed gear hanger in this image -
Thanks for looking.
[machine not in me possession]
Thanks for looking.
Quoted: 2588 Post(s)
Liked 4,824 Times
I think you are imagining things
Seriously, I zoomed in on that photo and I just see crustiness. That's not a tubing marking.
DD
DD
Liked 3,331 Times
it is there, clear as day
one needs to open the image to view it
Quoted: 3241 Post(s)
Liked 2,512 Times
The diamond looks more like a scratch to me. If, if that is a stamping, it looks like an 8 to me.
Liked 3,331 Times
the diamond is quite well defined
only the right portion of it is visible
its right end is rounded
Quoted: 1303 Post(s)
Liked 1,908 Times
J,
There is way too much corrosion for me to make more than the line out in the photo. And why is the line darker than the other paint around it? Just my observation. MH
Bikes: Indeed!
Quoted: 1506 Post(s)
Liked 3,469 Times
The reason that some may not see it is that they are looking on the dropout above the newer style derailleur hanger. As juvela stated in his original post it is on the chainstay above the drewed old-style stay-mounted hanger. It's quite small and half in the green paint and half in the crud below.
Brent
Brent
Likes For obrentharris:
Stop reading my posts!
Quoted: 1442 Post(s)
Liked 1,059 Times
can somebody circle the area that has this mark? I am not seeing anything on the chainstay that looks like a stamp
Oh NVM I see this supposed stamp now and I'd bet money it's nothing but a scratch. Sure it looks like someting much more than a scratch but....I have a miracle tortilla with the face of Christ I will gladly sell you!
Likes For unworthy1:
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Found it, no way to circle the area though. No ideas either about what it is supposed to represent. Center of hanger, circular scrape in the paint directly above center, triangle and top of the "B" or possibly a "5"/"6" is between the scrape and hanger.
And, I believe there is also a "28" just to the right of the Drewed hanger, in the long bare area/scrape.
Bill
Bill
Semper Fi, USMC, 1975-1977
Likes For qcpmsame:
Quoted: 2363 Post(s)
Liked 1,749 Times
Enlarged to show texture....
I see a single diagonal line, what might be the "northeast" edge of a diamond shape. And something resembling an alphanumeric below and to the left of the line. But where is the "northwest" edge? It doesn't look like the paint is so uneven that it would fill the "northwest" edge but leave such a crisp "northeast" edge.
Also seems like an odd place to strike such a mark, but :shrug:
Likes For madpogue:
Liked 3,331 Times
slightly surprised some readers having difficulty seeing it
am elderly with failing eyesight and must use strong reading glasses
figured that if I could see it everyone could do so easily
"should be simple for all the young whipper-snappers out there"
if the character is an eight rather than a letter B it brings up the possibility of Vitus 888 by Ateliers de la Rive but do not know if that tubeset goes back this far...
the left side of the character looks pretty straight to me, as opposed to the right side
the depth and width of the line forming the NE quadrant of the diamond appears too constant and even for it to be a scratch, at least to my eye...
thanks to all for looking
Liked 4,824 Times
DD
Likes For Drillium Dude:
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 323 Post(s)
Liked 690 Times
I see it. I would guess it’s just for marking the placement of that gear hanger. Perhaps It means something like <Braze here>. Could the diamond really be arrows saying to braze at the ends When the B is centered on the cutout? Just a guess, of course I’m an expert on nothing.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I agree. I see the marks in question, but what I see is on the surface of the paint, not under it. If you stripped the paint, I think the mark would be gone too.
www.rhmsaddles.com.
www.rhmsaddles.com.
Likes For rhm:
Quoted: 4722 Post(s)
Liked 3,036 Times
I'm not convinced that these are impressions in the chain stay itself. As stated, given the condition of the finish, it certainly wouldn't hurt to remove a little paint in the subject area, to provide a definitive answer.
Liked 6,675 Times
I think it says “Paul is dead” if read backwards.
Quoted: 4231 Post(s)
Liked 2,947 Times
It looks enough like ratted up paint to me that I had to check the date of the OP to make sure that this wasn't originally posted 9 days ago.
Likes For himespau:
Quoted: 3464 Post(s)
Liked 2,828 Times
Tube maker marks are usually at the other end.
more likely a mark for the type of derailleur mount. There were a number of brands and types of mounts back then.
Semper Fi
Liked 358 Times
To me the triangle portion looks stamped in, or rolled on, and the letter "B" (or a numeral "8", my best guess,) appears raised. Look long enough and it appears a "T" is below the "B" also.
Dammit, I never did any drugs and now I'm having hallucinations/flashbacks.
Bill
Bill
Likes For qcpmsame:
Semper Fi
Liked 358 Times
I've figured It out, same guy that did the Shroud of Turin is the frame's builder/tubing manufacturer
Bill
Likes For qcpmsame:
Quoted: 4510 Post(s)
Liked 6,377 Times
The marking is raised, not stamped/engraved as some have pointed out, the scratch distracts from the mark almost completely.
