Good deal on a bike with a problem
Hello everyone,
I spotted a very good deal on a roadbike. The thing is that the adverts says there is one spoke missing from the back wheel. And that the shifting needs to be adjusted. Are these big problems that i should avoid. Or is this easily fixable
got a friend that could help?
The description indicates the current owner can't fix it himself and has discovered a couple hours work by a shop mechanic not worth it. Unless the bike is worth over $300 I would steer clear unless you have someone with more experience who can give you some help. Learning to work on bikes is actually fun but the self-taught early lessons care not cheap!
Regarding the shifting, as long as it's misadjusted and nothing is broken or needs replacing, you can do it yourself for free in a few minutes.
If the rim is not bent, a missing spoke is not a big issue and extremely cheap to replace if you do it by yourself and it's a normal spoke. If it's a special type of spoke it probably is a bit more expensive but shouldn't be a deal breaker.
Although the OP has made a decision, I need to interject a thought about the missing spoke. Why is the spoke missing? Was it removed after it broke? If that is the case this is a good indication of more to come as the spokes are reaching fatigue limits. A new wheel may be in the near future.
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
I would budget around $80 for one of these, to be purchased along with the replacement spoke. This device will allow you to even out the tension on the wheel so that hopefully no more spokes break.
https://www.competitivecyclist.com/p...ion-meter-tm-1
Expired Member
Quoted: 3669 Post(s)
Liked 5,420 Times
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Not enough description to determine if it would be a good deal or a money-pit. A simple broken spoke is easy to fix — if that's really all it is. Are the other spokes on the verge of failure as well? Is the rim warped beyond redemption? A simple cable tension adjustment will fix many shifting problems, but that might not be the root of the issue. Are the shifters worn out or broken? Are the derailleurs damaged?
Bottom line: how competent are you at diagnosing the problems and fixing them yourself? If it's such an easy fix, why is the current owner selling the bike with those problems unaddressed?
Likes For Amt0571:
Quoted: 1819 Post(s)
Liked 1,693 Times
That does not mean that this one is "worth" 850 euros. Bicycles depreciate fairly quickly and second hand ones do not have any warranty. Given the defects, I would say that 500 euros is too high a price for this bike
Likes For alcjphil:
Quoted: 836 Post(s)
Liked 1,061 Times
If the bike hasn't been purchased yet a wise move would be to take someone with you that has some bike knowledge. I would be suspicious of someone selling a bike that in the best case scenario would be an easy fix (new spoke, shifting adjustment) that would raise the selling price a bit for the seller. Rim could have a crack at the spoke hole not prominent with spoke removed, shifting just needs adjustment or is something damaged? Could be perfectly fine and an easy fix but it's a gamble unless you have someone with experience to check it out.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
It's likely the broken spoke is on the drive side of the rear wheel. If so, you'll need the tools and skills to remove the rear cassette. The tools are inexpensive and most home mechanics will have them.
And if so, check the rest of the spokes on the outside of that flange for damage from the chain shifting into the spokes. It's easy enough and minimal extra cost to replace multiple spokes. (And that could be a symptom of the shifting problem as well.)
One possible cause of the shifting issue could be a bent rear derailleur hanger. That's another special tool for diagnosis and fix, which most home mechanics don't have.
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
I'd budget $30 for the LBS to replace the spoke, tension and true the wheel.
Likes For dedhed:
Quoted: 668 Post(s)
Liked 529 Times
Have to wonder if BF shouldn't have a Ritalin detector attached to the keyboard that would prevent people from posting if their levels are low.
Quoted: 252 Post(s)
Liked 67 Times
I'd go to view the bike and see who is selling it. It can be a pointer sometimes. You look at the person, at the place they are selling it from and what their explanation for their selling unfixed bike is (you will hear more lengthy explanation face to face), and you might have your suspicions alleviated or raised. Like if you see a garage with tools, even if they are for car fixing, you know that that's somebody who fixes their stuff to forgo expensive outside service and with such people I'd be more careful.
And having someone with you is always better, even if it is not any bike expert but if it is, so much the better.
Been wrenching in a bike shop since 1982. My experience with a broken spoke is the same with a deer crossing the road. Where's there one, there are more to come. I guarantee more spokes will break sooner than later. Spoke tension is one thing, but that is unlikely the issue.
Quoted: 283 Post(s)
Liked 262 Times
When someone says "simple fix", I think "then why didn't you do it?". I think all of the fixes I've done on used bikes ended up about 5x the "simple fix" estimate. Repack hub ends up scored bearing cup so replace wheel, etc. I'm a good wrench so I'm just talking parts. I now offer pretty low and will happily walk away from a bike needing work. 15x estimate for a french bike, in fact I won't even bother with those anymore. Live and learn.
Likes For grizzly59:
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times
OP,
Very hard to evaluate anything without some pictures....
Why not post a few of them?
Best, Ben
Best, Ben
