Grease for cup&cone hubs
I only had a bike which used cup&cones, which was my beater bike. It does a low mileage and I didn't care a lot about it being perfect, so from time to time I repacked the hubs with whatever grease I had at hand. Last time I used Weldtite TF2 teflon grease.
However, I now have a bike with more expensive hubs (XT) and which does way more mileage in muddy and wet conditions and was wondering what grease should I use on it. Is the Weldtite TF2 ok? or should I buy something specific?
Quoted: 2601 Post(s)
Liked 1,925 Times
And send me $10 to assuage any guilt you might feel about using the same grease on your less expensive and more expensive bearings.
Likes For pdlamb:
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
Making sure to set an optimal preload, and do regular service (every year, or each 5000 km, whichever comes first) is a lot more important than the type of grease.
It's similar to bathing: no matter how expensive, or cheap soap you use: as long as you wash regularly, all's good. If you don't, then even the most expensive soap doesn't cut it.
Likes For Bike Gremlin:
Quoted: 6950 Post(s)
Liked 10,958 Times
Buy grade 25 bearings in quantity, in the correct sizes, and replace those when doing the service.
I've found that, with good bearings and good grease (and plenty of it), cheapie hubs spin beautifully.
to 20k rpm.
Is there any grease expert here?
Likes For Amt0571:
Clark W. Griswold
Quoted: 4342 Post(s)
Liked 3,978 Times
I would use Phil Wood grease personally. If not that then probably the ceramic grease from Finish Line.
Bikes: 1988 Bottecchia Professional (for Eroica), 2011 Ridley Noah ISP (retired), 2020 Soma Fog Cutter (daily commuter), 2021 Ridley Kanzo Adventure (gravel), 2022 Tideace Aero (main road bike).
Quoted: 77 Post(s)
Liked 76 Times
I still have an old tub of Campagnolo Special Grease that I use all the time. Still works great!
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
I am not a grease expert, but I play one on the internet. My Campy grease dried out so I threw it away. I've been using Phil Wood grease because I have it.
It's a little on the light side, but really good. If you live in PNW or east coast or really wet climate, you might use trailer marine grease... it's heavier.
The Slick Honey or SRAM butter... I have that, but it's really for forks....might be too light.
Quoted: 241 Post(s)
Liked 232 Times
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
frequency of service is more important than grease, assuming reasonable quality of the grease used.
