8-speed Record shifting issues
So, I've done a complete restoration/overhaul on a mid 90's Colnago Master with 8-speed Record. Everything works great except for some minor issues with the rear derailleur that bugs me. Something like a third of the time, when shifting from the smallest cog to the next, and in particular, from the second smallest to the third cog, the chain won't shift, it just stays in a noisy middle position. It only happens when making single shifts, two or three gears at a time works perfectly. I've obviously tried putting a tad more tension on the cable but this only results in noise and overshifts, so it doesn't seem like cable tension is the issue?
The cassette, cabling, chain and pulleys are all brand new so shouldn't be a wear issue either.
Any ideas?
Any ideas?
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,195 Times
Have you checked that the hanger is straight?
Barry
Barry
Likes For Barry2:
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,195 Times
So I’m guessing this is not Friction shifting but is Indexed.
Assuming chain length is correct, it starts to look like poor indexing.
Any chance you have a spacer in the cassette incorrectly sized?
or an incompatible brand?
Barry
Barry
Quoted: 836 Post(s)
Liked 1,058 Times
Is the B-tension screw adjusted properly, proper chain length, shifter worn, cassette spacers in proper position (if they are not all the same)?
Bikes: 2013 Wilier Gran Turismo, 1983 Trek 760, 80's Colnago Super, 90's De Rosa SLX, 2009 Waterford 22 Series Singlespeed, 85 Medici Pro Strada, De Rosa Alumino frameset, Dave Molten Fuso frameset, 70's beater Peugeot PX10, Zizzo Liberte, 2022 Yoeleo R12
Quoted: 122 Post(s)
Liked 199 Times
Here's an old thread that discussed Campy indexed shifting: https://www.bikeforums.net/classic-v...hifting-4.html
There's some useful info there that may help you fine tune your setup.
Ergos? Could be a frayed cable at the shifter, but I'm guessing you replaced all cables with the overhaul. Could be a broken spring carrier.
-I'm quite certain the chain is correctly sized (106 links in this case).
-I've tried all kinds of B-screw settings with the same result.
-The cassette is a NIB Record 8-speed cassette. I've tried a different lightly used cassette before with the same result.
-The Ergos was serviced with all new G-springs and spring carriers.
I've spent a lot of time and money on trying to get everything "perfect" on this bike, so this problem, although minor, bugs me quite a bit. Almost leaning towards getting a brand new 12 speed Chorus groupset instead, but it would be nicer to keep the original components.
Quoted: 122 Post(s)
Liked 199 Times
Did you use cable ferrules inside the Ergo handles? The newer Ergo handles specify to not use ferrules but the older ones may use them.
Did you cut all your cables squarely and use ferrules where they should be used?
Was the Ergo handle rebuilt properly? When I assembled my downtube Syncro shifters I put in one of the washers flipped the wrong way. It shifted fine for weeks, then completely failed to hold any gear suddenly on a ride. Apparently everything was tight when I put it all together but eventually some extra play in the assembly resulted in the ratcheting mechanism no longer working.
I suppose I could dismantle the Ergo again and have a look.
Let your bike be the tool
Bikes: '66 Raleigh Carlton, '70 Ron Cooper, '95 Bianchi CD'I, Zonal Frame with Xenon gruppo, Carbon Frame with Record Gruppo, Columbia Twosome, Terry Classic, Bianchi SX, Gravity SS/FG
Quoted: 336 Post(s)
Liked 313 Times
Been a while since I've looked at my 8 speed. Am I remembering correctly that the splines on the cogs are all the same size and it's important to observe that the triangles on each sprocket are aligned? Am I also remembering that different same toothed cogs (e.g. 15,18, etc.) are necessary for different 1-8 positions?
Never try to teach a pig to sing...
