My very comfy saddle is now...less comfy?
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
Of course I expect this could happen, but the saddle I've been riding for the last year seems to have gotten less comfortable in the last month or so. Nothing else has changed--my bike fit/setup, no changes to my weight or conditioning, time on the bike, terrain ridden, etc. The only real change I can positively confirm is that I'm a little...older
Anybody else experience this? It's an Ergon SR Comp, FWIW. My old fave was a WTB Volt Comp so I'll swap back to that and see if it feels better....
I have experienced what you have described with a couple of non-Brooks saddles. They were good saddles too but just started getting "uncomfortable" as you described. I switched to using only Brooks leather saddles on all my bikes except one. Problem solved...knock on wood, but it's been about 10 years now so we'll see.
Not sure what causes that. I thought it might be because the padding or underlying structure broke down, but on both of mine that doesn't seem to the the case. So I'm perplexed too.
Likes For drlogik:
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
WTB Silverado rules!
I have an old WTB Valcon that was mounted on my Allez Pro when I bought it. I believe the saddle is from 2011. I've put at least 9000 miles on it in the last 4 years, and it's perfect. I don't know how many miles were on it when I "inherited" it.
Honestly, I think WTB saddles are damn near bullet proof. I just never see or feel much in the way of wear on them.
Likes For livedarklions:
Quoted: 284 Post(s)
Liked 313 Times
Quoted: 284 Post(s)
Liked 313 Times
Likes For pbass:
Bikes: 2015 Felt Z75 Disc, 2008 Fuji Cross Comp, 2010 Trek Navigator 1.0, 1974 Raleigh Sports, 1974 Schwinn Le Tour, 1981 Schwinn Super Le Tour, Surly Cross Check, 2021 Giant Talon 2
Quoted: 202 Post(s)
Liked 71 Times
check out the Frugal Average Bicyclist
Frugal Average Bicyclist – The goal here is to help you keep cycling on a budget.
Likes For BikingViking793:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Perhaps the Ergon orthopedic foam padding + OrthoCell Inlays have expired. Foam does eventually lose its memory. But then, don't we all?
Liked 2,965 Times
So you've turned the other cheek? Time to kick some butt trying out ones in the past that didn't cush the toosh as they may now be just right. If you don't have past seat experience, try a different pitch to see if you're disturbing the nerves or rubbing the bone wrongfully.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Guest
Liked 3,270 Times
Quoted: 1218 Post(s)
Liked 298 Times
Flexibility could also play a part in a different feel. Are you more or less flexible in the hips?
My favorite saddle was no longer my favorite on a bike with greater bar to saddle drop.
And shorts will also change a saddle feel. Especially padded shorts. My favorite saddle prefers a certain pad, or no pad. Other pads will ruin it.
My other observation with saddles, shorts material will change things too. Is it sticky? Is it slippery? Maybe you are moving more in saddle and your shorts are not sliding as well? Or the opposite, maybe new shorts or old worn out shorts are allowing you to slide around more.
Again flexibility, a loss in shoulder flexibly might have you sitting 1-2 mm farther forward.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
While I'm a leather saddle guy I've always like WTB and it looks like it's called the koda because of the little dip where you sit
