For the love of English 3 speeds...
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 439 Times
Hi dweenk, the tool was only suitable for use on the left hand side cup, as there was no means of screwing a bar into the inner bush to clamp it onto the frame,
so I bored a hole and cut M8 thread in it. Now it can be used on both sides.
Here' s a quick drawing:
Enjoy,
Peter
Enjoy,
Peter
A friend of mine gave me one of these..
I rarely remove the fixed cup.
In fact, the only one I've removed was from a 1930 Hercules and it practically slipped out....
Different alloys back then.
In fact, the whole bike (including cotters) came apart without any fuss.
I finally pumped some air into my old tires on my 1948 Humber Sports and did a quick test ride since the tires are dry rotted and the brakes are hard as rocks so I disconnected them. Bike rode ok but I think that it's not for me. I really like my banana seat ride so I'll be posting up my ride for sale. The front dyno works and so do the headlight and taillight. Has a brooks saddle and the 3 speed needs some work but it kind of works. Would asking $300 be too much? I'll try to take some pics for you guys but she has ape hanger handlebars from Raleigh I think.
Also I'm just trying to post more so I can do PM's with folks.
Liked 5 Times
i'm stocking up on inspiration right now because I'm about to embark on my first rebuild. browsing all the picture threads to give me courage!
Likes For tincup:
Liked 439 Times
A show bike can be a bit overwhelming and expensive.
A lot of the bikes here are long term projects.
I like to get a bike on the road asap and then upgrade as time and money permit.
It's mostly labour to take apart clean and re assemble.
new tires, brake pads and chain are reasonable.
A nice leather saddle can be the biggest expense.
Post some photos as you progress.
Man I just looked at my bike and it's a 4 speed and not a 3 speed. I didn't know that they made those.
Likes For JoshuaTSR:
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 359 Post(s)
Liked 457 Times
Post some photos if you can of the whole bike, decals, and drive-side. A few pics of the four-speed hub would be cool as well. I have a '53 four-speed hub built into a 700c wheelset for my '70s Peugeot IGH conversion. It is a really good hub when set up correctly.
My 1948 4 speed
Wide bars
I love that this works still and lights up the front and rear lights.
4 speed glory
Wide bars
4 speed glory
Benelux deraileur
Yes I am sure 700c wheels will work OK though they will be about 26-3/4" dia overall with tyres so will require brake blocks to be about 3/8" higher than for 26" wheel, many frames can accommodate this.
I have a couple of 1950's road bikes that were designed for 27" wheels which are normally on them but I have alternative 700c wheel sets I can put in them and then I have to lower the brake block FCC s around 4mm when to align to the braking surface when using them.
If you are using a Cyclo Benelux Mk 7 derailleur, I have 4 Speed one on a 1950's Dayton Roadmaster running 27 x 1" wheels and freewheel bottom gear has 22 teeth (top gear is 16T) which it manages easily, not sure you could go more than that. I have a 46T Chainwheel.
Any thoughts or advise would help.
Sorry to horn in on the 3 speed conversation, with deraileur questions.
Location: Southport, North Carolina, USA & Pevensey, East Sussex, UK
Bikes: 1)1992 Trek 970, 2)2010 Trek 6500, 3)1973 Colnago Super, 4)1955 Freddie Grubb Meteor. 5)1993 Airborne Ti-Hag Titanium. 6)1936 BSA 602DX Roadster. 7)1957 Philips P2 Sports. 8)1955 Dayton Roadmaster. 9)1948 Humber Clubman. 10) 1949 Sunbeam WA3 Wayfarer
Quoted: 157 Post(s)
Liked 85 Times
I started to work on the hopper, and have built wheels. I went with sun cr18 590 rims. I am working on the drivetrain now. The deraileur is stamped 3/32 5 speed, 1/8 4 speed. If I buy a 4 speed freewheel do I assume it will be for 1/8 chain? The other problem I am having is the bottom bracket only protrudes 1 inch on the drive side instead of 1.25 inches. What is with that? I will need to replace it to fit a “normal” chainring.
Cuius summa inventa
Cuius summa inventa
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,047 Times
Quoted: 86 Post(s)
Liked 78 Times
grease AW bearings
I've got a '69 AW on my Raleigh Twenty. When coasting it sounds a little loud, so I added quite a bit of oil. The sound has gone down a bit, but I realized it might need grease in the bearings instead of oil in the gears as my '74 AW on my Tourist is much smoother/quieter.
Does anyone know how easy it is to just grease the bearings & not overhaul the whole hub? Shifting is smooth & accurate.
No I didn't add it. Most of these bikes have a chain guard that covers everything so you don't see it. I like the way it looks, like people holding hands in peace.
The tires are old schwinn breeze 26 x 1 1/4 though, does anyone have a good line on tires for these bikes?
Ok guys what's the correct tire size? My rear tire is a uniroyal straight side that says 26x1 3/8 but it also says fits EA-1 and schwinn s-6 times while my front tire is a schwinn breeze sports touring 26x1 1/4.
If I can do the 1 3/8's then I'll just grab some cheap Walmart tires just so I can ride. What do you think?
Liked 439 Times
You want to order the Schwinn specific tires they're the only ones that fit and are reasonably priced.
https://www.amazon.ca/Kenda-Schwinn-...6309555&sr=8-8
It's a somewhat obsolete tire size but these fit EA1 rims nicely.
Those rims indicate yours was probably a Club Bike
Liked 439 Times
The chain ring has been swapped out at some point in the last 72 years...
Your bike would make a good Scorcher.
Add some inverted low bars , or upright bars for a Semi Scorcher.
Quoted: 457 Post(s)
Liked 462 Times
Remove the cog to start and looses the non drive side lock nut and conea half turn or so.
I start with the drive side sticking up, remove the locknut, then the locking washer that keeps the cone from rotating, then remove the cone, there is a spring that will extend out of the hub as you unscrew the cone, that can stay on the axle. With the cone off you can pull the driver out, and you'll see a bunch of 1/8" (I think) bearings that the driver spins on there are dust shields on the axle bearing and the driver bearings that can be pried off with a medium sized flat blade screwdriver, the larger diameter dust shield for the driver bearings should be pried off arond the outside edge, not by rying across the whole things as that tends to bend them.
Clean both cup and cones regrease and reassemble, BUT when you reassemble the axle bearing should be screwed down hand tight, then backed off 1/4 turn then the cone lock washer gets installed, then instal/tighten the lock nut, you are now done on the drive side.
Flip the wheel and remove the locknut and cone from the non drive side, the dust shield will pry off like the drive side, clean and regrease then reinstall the cone and lock nut, NOTE: the hub adjustment is atypical, the hub should be the tiniest bit loose when adjusted correctly.
That should do it.
Quoted: 86 Post(s)
Liked 78 Times
Thanks for the detailed response. Now I'll have to get up the courage to dig in! Messing with these internal hubs make me nervous!
Quoted: 457 Post(s)
Liked 462 Times
For anything inside the hub to move/come apart you have to unscrew the planetary "cassette" as a unit from the drive side of the hub, just regreasing bearings is pretty straightforward :-)
Likes For jackbombay:
Quoted: 1854 Post(s)
Liked 663 Times
Phyllo-buster
Liked 2,047 Times
Liked 439 Times
Yes it's a Humber chainring, those are usually referred to dancing people. Regarding price, it depends on your market. An incomplete bike certainly won't get $300 anywhere. The lack of original chainring doesn't help either. As gster suggests, those are tough tires to find. The 26 x 1 3/8 - EA1 -S6 is a US sizing and you'll have to find the Schwinn specific tires I think. There were a few Dunlops that had the same markings that you refer to but they're not common. You want a 597 mm bead, NOT a 590.
It has the maypole chainring.
here's Clubman's sizing chart.
Quoted: 86 Post(s)
Liked 78 Times
That is a nice looking bike! Between the color, the chain ring, long chain stays, and the double fork blades - wow! Looks like it would be a fun ride!
Liked 439 Times
Truth is , I can't really ride a bike with drop bars.
I need to sit up reasonably straight....
