Has this been done, I wonder?
Old 12-02-22, 05:16 PM
67tony
67tony's Avatar
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 199 Post(s)
Liked 153 Times in 84 Posts
I put my '87 Ironman firmly in my benchtop stand, shifted to 12th gear, carefully gripped the seat stay, and hand-pedaled like crazy.
Then, I started my stopwatch to see how long the wheel would spin.
In both trials the time was about 2 minutes, 15 seconds.
(I have a significant hub wobble, likely decreasing my time.)
It's kind of a goofy bench test, but I had nothing better to do!
Like a KOM challenge, I'm certain someone will top this oddball record.
67tony is offline
Likes For 67tony:
Old 12-02-22, 05:28 PM
clubman
Phyllo-buster
clubman's Avatar
Quoted: 2188 Post(s)
Liked 1,723 Times in 1,070 Posts
Front wheels go longer. I 'threw' a Mavic 501 front wheel that must have gone for at least a few minutes. As far as rears are concerned, I suspect the quiet freehubs are better...Shimano 105, RSX etc. Noise = friction.
Heavy rims and tires would also help.
clubman is offline
Old 12-02-22, 05:35 PM
67tony
67tony's Avatar
Quoted: 199 Post(s)
Good point.
I also have a rope hub-polishing loop slowing me down!
67tony is offline
Old 12-02-22, 05:41 PM
Wildwood
Veteran, Pacifist
Wildwood's Avatar
Quoted: 3367 Post(s)
Liked 3,255 Times in 1,589 Posts
Needs better rules.
My best spinner is a tandem front wheel 40 spokes with heavy rim and heavy Schwalbe tires.
edit: Oooops missed #2&#3
Wildwood is online now
Old 12-02-22, 06:00 PM
pastorbobnlnh
Freewheel Medic
pastorbobnlnh's Avatar
Bikes: Snazzy* Schwinns, Classy Cannondales, Aero Lotus & a Lonely '83 Santana Tandem (* Ed.)
Quoted: 1107 Post(s)
Liked 1,175 Times in 568 Posts
...I suspect the quiet freehubs are better... Noise = friction....
Clubman, not to be contrary or disagreeable, as far as freewheels are concerned, I'd say noise = appropriate lubrication. Too much lube, whether grease or oil in the pawl and ratchet teeth region, causes less noise at the cost of extra friction. I've worked on silent freewheels which were gummed up with excessive lubrication. Just my two cents.
Bob
pastorbobnlnh is offline
Likes For pastorbobnlnh:
Old 12-02-22, 06:56 PM
juvela
juvela's Avatar
Quoted: 3106 Post(s)
Liked 1,878 Times in 1,333 Posts
Just look at that clear workbench!
I am envious.
Often do a similar action on cycles with five-piece rear hubs.
Lay the machine down on its non-drive side and spin the rear wheel like a roulette wheel.
Watch gear block for wobble.
Swaged on drive side flange often works loose with time.
When it does the gear block is permitted to wobble about.
Happily, flange can't go anywhere so there is no danger...
juvela is offline
Old 12-02-22, 07:06 PM
WGB
WGB
WGB's Avatar
Bikes: Panasonic PT-4500
Quoted: 1519 Post(s)
Liked 1,515 Times in 1,003 Posts
Please - come to my house and organize my work space...👍
WGB is offline
Likes For WGB:
Old 12-02-22, 07:43 PM
streetsurfer
streetsurfer's Avatar
Bikes: ‘95 Le Tour, 80’s Nishiki Competition, Coda F900, Diamondback Response Trail, several schwinns-contis, suburban, letour lux, supersport? (repaint)
Quoted: 58 Post(s)
Liked 168 Times in 94 Posts
If I remember correctly , this test requires two wooden clothes pins and two Bicycle Playing Cards.
streetsurfer is offline
Likes For streetsurfer:
Old 12-02-22, 08:09 PM
plonz
plonz's Avatar
Quoted: 588 Post(s)
Liked 305 Times in 208 Posts
Jan Heine found that 32s will spin longer than 23s.
plonz is offline
Old 12-02-22, 08:40 PM
merziac
merziac's Avatar
Quoted: 3690 Post(s)
Liked 4,248 Times in 2,539 Posts
How would you ever find anything if that happened?
merziac is offline
Likes For merziac:
Old 12-02-22, 08:48 PM
RustyJames
RustyJames's Avatar
Quoted: 429 Post(s)
Liked 654 Times in 368 Posts
I have 1960-ish wheel - Campy hub and I can’t remember the spoke count or rim brand but the front wheel is a perpetual motion machine. First time I spun it and walked away for at least 4 or 5 minutes and it was still spinning. I give credit to the white lith-grease and the fabulous Campy hub.
RustyJames is offline
Likes For RustyJames:
Old 12-02-22, 08:49 PM
stardognine
Partially Sane.
stardognine's Avatar
Bikes: Soma Saga, pre-disc
Quoted: 968 Post(s)
Liked 637 Times in 462 Posts
So true, I hate when people criticize a messy work area. That just means you have a lot going on. 🤨😉
stardognine is offline
Likes For stardognine:
Old 12-02-22, 09:16 PM
merziac
merziac's Avatar
Yep, I usually have a pretty good idea where things are and even when I don't i usually find inspiration that drives the project in a better direction than I was headed.
I love the process of digging for treasure and finding more treasure along the way. I'm not that creative in general so I regularly benefit from the contained chaos that is often my process.
merziac is offline
Likes For merziac:
Old 12-03-22, 05:39 AM
clubman
Phyllo-buster
clubman's Avatar
You would know! Just splitting hairs...my point, I think is that a freewheel/hub is going to inherently have more friction than a front hub.
But there was a generation of very quiet freehubs if I'm not mistaken?
clubman is offline
Likes For clubman:
Old 12-03-22, 08:47 AM
cudak888
www.theheadbadge.com
cudak888's Avatar
Quoted: 2024 Post(s)
Liked 3,099 Times in 1,596 Posts
Let's not forget that those freehubs with roller clutches should be silent at all times, regardless of lubrication. Those should spin as long as a front hub if properly adjusted.
-Kurt
cudak888 is offline
Likes For cudak888:
Old 12-03-22, 09:41 AM
tkamd73
Quoted: 563 Post(s)
Liked 857 Times in 453 Posts
Nice bike and workbench!
Tim
tkamd73 is offline
Old 12-03-22, 10:12 AM
martl
Strong Walker
martl's Avatar
Bikes: too many
Quoted: 286 Post(s)
Liked 377 Times in 198 Posts
If you try that with a well built Super Record wheelset, you can swap the stopwatch for a calendar...
martl is offline
Old 12-03-22, 11:49 AM
67tony
67tony's Avatar
Quoted: 199 Post(s)
I've got a Dura-Ace wheelset up in Virginia, it'll be interesting to compare it to my hub-wobbling 600.
67tony is offline
Old 12-20-22, 05:36 AM
martl
Strong Walker
martl's Avatar
Bikes: too many
Quoted: 286 Post(s)
give it a push in virginia, it will likely spin until you arrive in florida
martl is offline
Old 12-20-22, 07:39 AM
thinktubes
weapons-grade bolognium
thinktubes's Avatar
Quoted: 890 Post(s)
Liked 1,726 Times in 711 Posts
thinktubes is offline
Likes For thinktubes:
Old 12-20-22, 11:23 AM
gugie
Bike Butcher of Portland
gugie's Avatar
Bikes: It's complicated.
Quoted: 4261 Post(s)
Liked 4,187 Times in 1,795 Posts
@rccardr is famous in RC car racing circuits for finding loopholes in the rules to get more "HP" out of his cars. I don't want to pass along any of the secrets he shared with me in a conversation many moons ago, but there it is.
If we've got a competition here, I suggest that someone use a portacatena dropout and chain holder. It was designed for quick rear wheel changes, but there's another use - shift into the chain holder when you get to escape velocity BITD we called it Portugese overdrive, useful when using Crampandgoslow kit. No freewheel pawl friction, it'll spin as long as hub bearings and wheel aerodyamics allow.
gugie is offline
Old 12-20-22, 11:26 AM
gugie
gugie's Avatar
From the wayback machine.
gugie is offline
Old 12-20-22, 12:29 PM
bikingshearer
Crawlin' up, flyin' down
bikingshearer's Avatar
Quoted: 599 Post(s)
Liked 1,067 Times in 528 Posts
It's not a "mess." It's an "external organizational system."
bikingshearer is offline
Old 12-20-22, 12:38 PM
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Bikes: Bob Jackson, Wizard, Pegoretti Duende, Merckx ProSLX, Pelizzoli, Cannondale ST, Schwinn Tempo, Schwinn Voyageur, Canyon Endurace, Richard Sachs, Davidson Discovery
Quoted: 1886 Post(s)
Liked 2,191 Times in 841 Posts
Mmmmmm.
Many bearing secrets were developed that cannot be shared among the unitiated.
rccardr is offline
Likes For rccardr:
Old 12-20-22, 03:46 PM
stardognine
Partially Sane.
Quoted: 968 Post(s)
Originally Posted by thinktubes View Post
Cool cover, but where's page 26? 🤔😉
