For the love of English 3 speeds...
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
I'm excited, well...as excited as one can be for the cold temps, but its fun to have a bike that I don't worry about as much. The S5 hub is working great with a 20T sprocket with plenty of low gear options in the range. Do you ever have issues with your brake lines freezing up? I did when I used to keep my winter commuter hybrid inside and then take it out into the cold. The Triumph will live outside, so with any luck that'll help.
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1293 Post(s)
Liked 933 Times
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 359 Post(s)
Liked 457 Times
I built up a winter commuter from an old 'hybrid' bike frame. I didn't use the canti-brake braze-ons; instead built wheels using Sturmey Archer drum brakes front and rear with a 5 speed SA IGH drum combo. The bike uses 700c rims with studded snow tires. Its held up really well but I've only been running it three years and I do try to clean it off. I went with drum brakes since I figured they would stop the bike regardless of ice.
With the three-speed bikes of the 50s, 60s, and 70s, the only thing I'd wish for is the quality, variety, and availability of multiple tire types for 650a like has happened with 650b. I'd like to run Soma Cazadero type tires for winter at 42mm wide and aggressive side tread, but the 38mm Panaracer Col de la vie will have to suffice. I'll just need to be more choosy of which days I go into the office.
Quoted: 3803 Post(s)
Liked 6,634 Times
I have found that 50s/60s 3-speeds can work with 700c wheels and fenders. Here's my 1950 Lenton Tourist with 700 x 32mm Paselas:
Could be a bit of a stretch to get 700 x 42mm tires AND fenders on there, however.
Quoted: 359 Post(s)
Liked 457 Times
I do like the 650B x 42mm Cazaderos for winter commuting, particularly in loose snow:
Liked 6,634 Times
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4677 Post(s)
Liked 5,790 Times
Note room for 650b x 42's and proper fenders
Likes For gugie:
Quoted: 359 Post(s)
Liked 457 Times
From previous threads it looks like you have a 73 and a 75 Competition? Either of those would make great starting points for a 650b conversion. It's the model that got me into doing it after I bought an already modified Competition frame from the master, Peter Weigle. Here it is built up and ready for a credit card tour:
PM with some questions inbound!
Thanks.
Likes For Ged117:
Standard Member
Liked 933 Times
A couple of Craig's List finds: A '67? Rudge Sports and a '70's Raleigh Superbe.
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 174 Times
Likes For arex:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Very clean, if confused, Twenty for $150 in MI.
https://www.facebook.com/marketplace...97776674220752
astro
Bikes: Raleigh Sports, '72, Bianchi Volpe, '97 (no more, it died), Greenspeed GTVS6, '05, Trek 520, '13
Quoted: 43 Post(s)
Liked 51 Times
- Ed
Bikes: '83 Viner Special Professional, '91 Pinarello Asolo 'spumoni', '93 Trek 930, '94 Giant Cadex CFR3, '97 Giant Atlanta MTB, '99 B1 Weblite Cross , '16 Cube Peloton Race.
Quoted: 92 Post(s)
Liked 375 Times
Rudge-Whitworth sports (1973). Nearly all original. With the Sturmey-Archer 3 speed.
Quoted: 359 Post(s)
Liked 457 Times
That is a cool one, Lucas - the red against the black is very sharp.
Likes For Ged117:
Standard Member
Liked 933 Times
Phyllo-buster
Quoted: 2295 Post(s)
Liked 2,044 Times
Perhaps it was made in the Netherlands? The fork dimples, rims, chainguard and crankset are not what quite what you'd expect from the typical Rudge.
Quoted: 359 Post(s)
Liked 457 Times
An exchange in the "drop bar three speed" thread got me thinking about lamps and dynohubs. I was originally planning to run a late '40s Sturmey Archer lamp set using a tire-driven dynamo on my Sun Wasp, but now I'm thinking I could source a 700c 32h CR18 rim and make a dynohub wheel for a more British C&V esthetic. I have a few options, as a few years ago I gathered dynohubs thinking I'd build another early '50s Raleigh, but now that I've found the Triumph I don't think I will be doing that. Hubs are below dated June 1946 and November 1947 respectively. I also have a GH6 dated 1962 out in the garage bin, but its earmarked as parts donor for the '75 dynohub on my Triumph. My only concern is in using the bakelite-clad version, because this hub will probably see many years of service, potentially to its centenary in the 2040s (well, hopefully, hah!). One would have to take care when tightening not to crack it, but I never had that problem with the 1950 AG hub on my Superbe. I suppose if it cracked, I could just replace the guts within the hub shell.
Has anyone built a standlight circuit and paired it with the Nicelite LEDs for these lamps? I run those in the Triumph's lamps, and I don't mind the flicker at low speeds, but it might be fun to try and build such a circuit and occupy myself over a winter weekend.
PXL_20221209_202457876
Likes For Ged117:
Quoted: 92 Post(s)
Liked 375 Times
Quoted: 92 Post(s)
Liked 375 Times
Likes For LucasHartong:
Quoted: 92 Post(s)
Liked 375 Times
Rudge at a certain moment fused with Raleigh in England. This bike is a mix of that fuse-time, I figured. As far as I could reconstruct Rudge bikes were later marketed as Raleigh. The bike is all original though; got it from son of the first owner who received it new as a gift from his parents. I love bikes with a personal story!
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 184 Post(s)
Liked 204 Times
So Sun probably does a limited run of these 590 rims and if you want them get them NOW.
Last new bike 1991
Last new bike 1991
Likes For dmark:
Standard Member
Liked 933 Times
Likes For 1989Pre:
Quoted: 359 Post(s)
Liked 457 Times
The CR18 in 590 flavour are harder to find - I may search some up eventually for my Sturmey five-speed Triumph Sports - but I'm building a 32/40 622 wheelset for my '51 Sun Wasp - the 40h being a Sun Ringle CR-16 I found NOS on ebay, being a US-made older rim from that company. The front will be a CR18, they look pretty darn close a match. For those of you looking to build drop bar or 700c rims, CR-16s in 40h are out there if you can't find a 700c CR18 in 40h, which seem to be rare now.
Bikes: 1951-2 BSA 900E Roadster, 1961 Triumph Sports, 1953 Raleigh Sports, 1981 Raleigh Superbe, 1976 Raleigh Twenty, 1951 Taxandria, ±1950 The Gold Lion Tandem
Quoted: 40 Post(s)
Liked 14 Times
Here is a 1963 catalogue image for the different (26 inch) front forks :
From the mid- sixties onwards, most (or all ?) non- Raleigh brands got the generic fork.
Peter
Likes For oldveloman:
Liked 2,446 Times
