Wheel upgrade choice for CAAD13
Old 09-18-21, 12:11 PM
Digger6255
Digger6255's Avatar
Bikes: CAAD13 Disc, Ridley Fenix, Electra Lux 7D
Quoted: 32 Post(s)
Liked 24 Times in 17 Posts
My CAAD13 has Bontrager Affinity TLR wheels. I bought the bike used with only 20 miles on it but the previous owner swapped the stock Cannondale wheels to the Bontrager. They are not bad but very heavy (2150 grams) and the rear hub seems pretty tight compared to my Fulcrum 5's on my Ridley. My riding is mainly on a paved MUP ranging from 15-60 miles on average with not much elevation gain. I would keep the Bontragers for the trainer and also keeping the Ridley for winter rides. I plan on running 30 or 32 tubeless tires
I have 3 wheels on the short list on around the same price point.
Fulcrum Racing Zero Disc tubeless. on sale at Competitive Cyclist for $922
Mercury S5 tubeless disc also on sale at CC for $910
I built a set of Light Bicycle. I'll take any suggestion on changes to the LB's
DT SWISS 350Front Axle12 / 100mm
Rear Axle12 / 142mm
Brake SystemCenter lock
Hub ColorBlack
Front Holes Count24H
Rear Holes Count24H
Ratchet 36T
SPOKES/NIPPLES
Spoke Sapim CX Sprint-Rear drive side/ CX Ray-Other sides
Nipple Brass Oil slick
Bead type Hook
Finish Glossy
Weave 3K
Center Channel Hole No Access Holes
Drain Hole No Drain Holes
DecalStealth (Grey)
Valve Stem Add Valve Stem
Tubeless Tape None
Piece Weight: 1556.72g+/-25
Subtotal: USD 868.40
Digger6255 is offline
