Peugeot identification
Hi all
I suspect that this bike is not in original configuration, but can be year /model Identified ?
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
Look on the rear derailer cage plates for a date code like "4 74".
Probably it's a UO8 model based on it's features (though could be a UO9 model if the original crank was aluminum).
Likes For oneclick:
Quoted: 3807 Post(s)
Liked 3,331 Times
the presence of the rack mount eyelets and the dynamo mount bracket on the seat stays rule out model U08
final year for this AR636 model of rear mech was 1969-70
original chainset was DURAX cottered steel w/Cyclo chainwheels
original pedals were Lyotard model 36 fitted with Cibie amber bolt-on reflectors
original shift levers Juy alloy downtube controls
original stem/bar set AVA or PIVO
original saddle ADGA model 28A
original frame pump Ventolux by Poutrait-Morin
original handlebar wrap glossy black plastic
original handlebar plugs Velox black rubber
may be model UE-8 with mudguards, chainguard & lighting system removed
brochure page ca. 1969 -
