How to lock your bike...
Bikes: 2010 Jamis allegro 1
After much reviews,and much research on the proper way to lock your bike and the proper locks needed,I went with these...
A 4ft,12 mm steel cable,a brinks high security padlock and a 4X9,15 mm Kryptonite U-lock.
Here is a video also that explains a how to lock your bike,but after watching this video and many like it,I asked myself how the hell do I carry these locks with me when I am not in full commuting mode?(With my rack,rear bag,etc)So watch the video,and answer these questions about your own bike...
How do you lock your bike?
What kind of lock(s) do you use?
How do you transport these lock(s)?
What grade do you think your bike would have gotten?
https://www.bikecommuters.com/2007/06/20/hot-to-lock-your-bike/
Noobie of the year :)
Bikes: 1980's Miyata Seven Ten
How do you lock your bike?: Sheldon Brown method. I would prefer to get the frame and rear wheel, but see next answer for reason.
What kind of lock(s) do you use?: Mini U-Lock. Not wide enough to fit around frame and tire, and not long enough to fit front tire with it.
How do you transport these lock(s)? Saddlebag.
What grade do you think your bike would have gotten?: Doesn't matter to me, I'm not too worried about thieves where I park my bike at work.
AS for your question about transporting yours - the U-Lock comes with a frame adapter it looks like, so you can likely put it under your toptube. And the cable can be looped around the back of your saddle through the rails.
OK,thanks.So you use a mini U and a cable?...I live in a relatively low crime area,but from time to time I stop on my route at the grocery stroe,or to grab a bite to eat and just want to know my bike will be there.May be a little overkill but if it got stolen I would be kicking my self in the arse.
No one carries the DogBoy
Kryptonite U-lock/cable. Lock through bike-frame and solid pole etc., cable through wheels to same lock. Seat/helmet on very small cable also to the same lock.
Kryptonite U-lock/cables
Saddle bag. I always have it on my bike. When I do road rides I take my road-bike and I don't lock it, I keep it in my possession.
B- or B. I only use one main lock, and the cable I use for seat/helmet is pretty flimsy.
mijnwraak sugessted the cable around my seat,which MIGHT work,the cable seems to be touching mybrakes a little,but I may be able to remedy.But the mount that came with the giant u-lock is not pratical in any application.It wont even fit around my top tube,and even if it did my brake cable runs the length of the tube so no-go.I tried to mount it on various places and just not happening...hmmm.I will figure it out Im sure.
I guess Im destined for a grade of C on my non-commuter rides,cause there is no way that u lock is coming with me with out a rack or bag.The cable is wrapped around my handlebars easily enough,but I tried every conceivable place with different bungees and there is just really not a way.Maybe I will just put the rack back on,and leave it on.
Bikes: Old steel GT's, for touring and commuting
Quoted: 39 Post(s)
1) How do you lock your bike?
2) What kind of lock(s) do you use?
3) How do you transport these lock(s)?
2) Depends on the day and the ride. I have Masterlock Cuffs, a fairly long, good U-Lock and a long thick cable, and a homemade very long NY chain of serious links, paired with a Masterlock padlock, both wrapped in old tubes. Most days the U-Lock and cable. Our house could use another U-Lock for when the choice should be two U-Locks and a cable (girlfriend is now using my spare U-Lock and riding most days to work).
1) Usually through the rear wheel, the bike rack (or something suitable) and the front wheel. Gonna have to get some Pitlocks when I finally invest in a really good saddle.
With the U-Lock locking front wheel to frame and cable through the rest.
The chain is simpler but weighs a ton. It has its moments though. It's long enough to lock up a friends bike properly as well as mine and makes it so I can leave my frame that I am very attached to and the rear wheel that I can't afford to replace (48 spoke Sun Rhyno Lite tandem) locked up at places that I want to go that lesser locks wouldn't be able to secure.
How do you transport these locks?
3) The NY chain I wear like a bandoleer (locked to itself at a good length for this with the tail of chain behind the lock wrapped around the low point - near my hip). The Cuffs end up in my Chrome or a pannier but I rarely use these. Most days it's the cable and U-Lock riding in a small laptop ("notebook/netbook" whatever those half size laptops are) case that I got at a thrift store for $2. It already had two small D rings sewn into it that I used two small leather straps (about the same size as tow clip straps) to secure it to one side of my rear rack. It also portages my pump, bungees and bungee net, the net doing double duty securing the lower half of the case to the lower part of the rack. The latter isn't really necessary, gravity pretty much keeps it there, but this way I don't have to worry about it and I was looking for somewhere to stow my net when I'm not using it anyway.
I hate having my locks make noise while I am rolling so I've taken to stowing the U-Lock as two separate components.
I'll post a pic of this set-up later.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
U-lock through the spokes of the rear wheel, around the seat stays and the bike rack.
OnGuard Pitbull
I leave it attached to the rack at work.
It depends on whether or not the grading scale is adjusted for location. If so, then I'd give myself an A. Theft is pretty rare where I park the bike, and the rear wheel and frame are reasonably secure. If I locked the bike like this in NYC, I'd probably get a C- because my front wheel and saddle are both vulnerable and not cheap. I have a cable that I could use to secure the front wheel, but I don't bother because of my location.
OnGuard Pitbull
Thanks for the responses guys! Hey jus wanted to let anyone know who might be interested....I found a pre-packaged security chain on the cheap from,of all places,wally world.Boron alloy,heat hardened,cut proof,etc.Made from the same steel/material that kryptonite,abus,onguard,thebikeregistery chain,etc use for their chains.Now some of these companies use square links,some 6 sided,and some regular links,but all the same material.
I found this chain on the "lock isle" of wally world,3 feet of this HEAVY chain was only $14.98 Couple that with a good disk or u-lock(you will however have to figure out a cover for this mammoth as to not scratch the finish of your bike) and you will have A+ security for a very reasonable price.You can buy this grade of chain online for 7.50 a foot+$10 flat rate shipping ie;this would cost you 32.50 deliverd on line.
I didnt purchase this chain today,but as soon as I found a super deal on a good lock,one that is just as strong as the chain,Im gonna scoop them both up and ride with that baby bandolier style like rambo!!!
Bikes: 2008 Scott SUB 30, 1981 Miyata Ridge Runner, Dahon Speed 8
Just got another Onguard Bulldog Mini from Amazon, on sale at $23.00, for my younger daughter's bike. This one came with a very cool bracket for mounting to a frame tube that was a huge improvement over the brackets that came with the ones purchased earlier. We each use the unlock to lock the frame to a metal pole or rack, and a cheap coiled cable through the wheels locked back to the ulock. No problems yet parking carefully in Albuquerque.
1-The little cute girls behind the counter thought I was a moron
2-Not many people must lock there bikes up there
3-The theft of bikes must be fairly low in this area
So that did make me feel a little bit better,but I still want it just for the WOW factor...
From the thief:"WOW,I cant get this bike!"
From a fellow cyclist:"WOW,this guy is the king of FREDS"
How & What:
Low risk- Onguard Bulldog Mini U, Sheldon style through rear wheel. Abus Futura Mini U, front wheel & frame.
High risk- Kryptonite New York STD U, through seat or chain stays + rear wheel. Abus or Onguard Mini U, front wheel & frame.
Transport: Msgr Bag, Pannier, or tucked into belt.
I have no faith in the bracket mounting systems that come with most U-locks. I don't even bother. I removed the mount from the U-lock immediately & threw the bracket away, never looked back.
I also have no faith in cables. I just don't see the point, they can be clipped so easily. I'd rather use two U-locks. I've heard the argument about different tools, different locks, but I don't buy it. First, If a thief is using power tools, I'm sure he has a pair of bolt cutters somewhere. Second, power tools can cut through cables. Neither do I see the point in getting a beefy padlock for a cable. It's like adding one strong link to an otherwise weak chain. The math just doesn't add up.
That said, to each his own. Everyone is entitled to use what works for them. Not trying to be contentious. Just my opinion/experience.
ps- Pee-Wee's Big Adventure rocks.
How & What:
I agree about the cable just being too easy.I am going to get that chain I described earlier,w/a nice lock,or the bikeregistry.com chain and relagate the cable/lock combo to my lawnmower eventually.The more I read about that chain from bikeregistry the more I want it,and its only $38 delivered,its kind of hard not to get it.
Quoted: 39 Post(s)
Part of the reason I went with making my own was that I wanted to be sure that I had enough length to go through both wheels and lock up to a bike rack or even things with more girth. You might want to measure the distance between your wheels and estimate how much more you might need to lock to something. The bike registry lock looks pretty good, but I'd be concerned that the 39" might not be enough. I don't recall how long mine is, a little shorter than Pee-Wee's though!
And what size tube did you use,vs the size of the chain? How hard was it to get the chain in the tube?
Quoted: 39 Post(s)
A little shorter? LOL!!!!!!!! That thing was like 40 ft!!!! HAHA!!! I think 3ft will be enough,I have quick release wheels so easy to put frame/both wheels close together and lock it up...Still torn between DIY chain and the bikeregistry chain.There both the same material,but the bikeregistry one has square links,but the other has BIG links,just round.
Here's the pic of the thrift-store-find small laptop bag lashed down with a couple of leather straps with a little (probably unnecessary) assistance from one of my bungee nets:
The other leather strap is hidden by the bag behind where my Road Morph pump is poking out of the top of the outer pocket.
My girlfriend is no fan of used things and often raises her eyebrows to some of my solutions to things, but in this case she actually expressed that she was envious of this one and that it looked like it had been specifically designed for what I was using it for! I love that my lock makes no noise and is quick and easy to stow now. Of course when I need to run two panniers I need to pull this off, but that takes just a minute.
^^^Good job!!! I like the look of the bag,and thanks for the info on the cover...Although I think I am going to just purchase one ready to go.
I have decided to put the rack/trunk bag back on and just embrace the "weight issue",I suppose I will get a road bike one day and riding the hybrid with all the weight will actually be benificial in the long run.Im ordering the bikeregistry chain or the tulsa chain company security chain on pay day.The tulas chain is around $8 cheaper,but doesnt come with a lock,but damn if it isnt sweeeet!!! And I can get it with a red cover whick will match my black/red JAMIS...Link below,as well as the picture of my hybrid when it has all the gear.
https://www.tulsachain.com/asccustomp...&navParent=367
Bikes: quite a few
I have an OnGuard U Lock (a shorter one, but not a mini) with a cable. I just hang it off my bar ends when I ride and wrap the cable around my shoulder/neck like a messenger bag. I usually secure just the frame (downtube) to the rack, and only bother doing the cable around the wheels if my bike will be there awhile, or if there are very few other bikes there.
I keep my commuter bike at my desk at work so it doesn't need a lock. I just use my lock for my mountain bike when I ride to the train station.
Quoted: 39 Post(s)
I forgot someone had asked about the Masterlock Cuffs too. Although I use mine infrequently, now that my girlfriend is using our second U-Lock I occasionally use it. Today I had to go pick up a package that I thought was at the Post Office in the U-District. Expecting to be inside for some time (there are always long lines there) and figuring it was a high theft area I brought the Cuffs in addition to my U-Lock and cable. I was reminded that the Cuffs are pretty easy to use and the flexibility of the joint in the middle is nice. Here they are and how I used them today:
The cable is through the rack, front wheel, and rear triangle with the U-Lock, although it would have been a little more secure with the Cuff's run from frame to rack I didn't expect that anyone was really going to cut her free and drag off my 50 pound rig, so I went with high deterrent instead to keep anyone from messing with the front wheel. I ran a number of errands on this trip and for most of the less risky stops I used only the Cuffs from the top tube to the bike rack. Despite the quick release, my front wheel takes a minute to get off, so I felt like that was enough at other locations today. It rode in the bottom of an Ortlieb pannier that I was using to carry my man-purse and loot I was picking up.
Bikes: Gunnar, Surly
I will be getting a new commuter in the next couple weeks. I will keep it in my office at work, and plan to use it for errands around town. For locking around town (San Francisco), I plan to go with either the BikeRegistry chain + padlock approach, OR get an Abus chain OR get an OnGuard or Kryptonite chain + u-lock solution. I will just keep the chain in a pannier or strap it on top of the rear rack. The chain seems like the easiest and best option for securing both wheels and the frame, quickly and easily when I am shopping.
Which trunk bag is that? My girlfriend is looking for one and I am considering one as an alternative to a pannier for my work commute as well.
The rack I have is a schwinn seatpost rack,w/custom supports I made from aluminum flat bar.The trunk is motorcycle tailbag I bought from walmart.com for $35 bucks,and I added the DOT reflectors on either side.
