Go Back  Bike Forums > Bike Forums > Winter Cycling
29er MTB studded tires, what are you using?
Winter Cycling Don't let snow and ice discourage you this winter. The key element to year-round cycling is proper attire! Check out this winter cycling forum to chat with other ice bike fanatics.
Old 12-15-22, 12:41 PM
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,581 Times in 2,342 Posts
I had some tame 2" tires but I went down 1 too many times last winter so I was thinking a cpl MMs wider & more aggressive w/ bigger deeper voids. I moved the MTB tires to my hybrid. your standard marathon winters
hanging loose before mounting
yeah, yeah, fat bike, fat bike, I know, I know ... but I ain't got, so ...
rumrunn6 is offline
Old 12-16-22, 11:08 AM
wolfchild
Quoted: 4227 Post(s)
Liked 2,488 Times in 1,286 Posts
I am using Schwalbe Marathon Winter 700 x 40 mm, they actually measure closer to 42 mm wide which I find perfect for all around riding...I also have a set of Schwalbe Winter in a 700 x 30 mm size, these are a cheaper version of Marathon Winter which have two rows of studs along the middle...In the past I've used Nokian Extremes 294s
wolfchild is offline
Likes For wolfchild:
Old 12-16-22, 02:26 PM
rumrunn6
rumrunn6's Avatar
about 10 yrs ago I had some Continental Spike Claw Studded Mountain Bike Tires (240 studs) but they were on a 26er
rumrunn6 is offline
Old 12-30-22, 11:25 AM
Black Jaque
I have Nokian Hakkapalliitta W240 size 700x40 but they need to be replaced. It doesn't look like they make them anymore so I'm interested in what would be comparable. They were dang good.
Black Jaque is offline
Old 12-30-22, 12:10 PM
rumrunn6
rumrunn6's Avatar
you might enjoy this article
https://www.peterwhitecycles.com/studdedtires.php
rumrunn6 is offline
Old 12-30-22, 12:14 PM
rumrunn6
rumrunn6's Avatar
forgot about this thread. I had the itch one day so I found these, but have yet to mount them up. 58F degrees right now, so I think I'm OK ...
Schwalbe Ice Spiker Pro Hs379
29 x 2.25 (aka 57-622)
rumrunn6 is offline
Likes For rumrunn6:
Old 12-30-22, 03:19 PM
wolfchild
Save them for when there is some serious ice, no point of wasting them on pavement.
Old 12-30-22, 07:26 PM
rumrunn6
rumrunn6's Avatar
oh yeah, totally agree. got them for fresh powder over ice. I want payback for my body slam last February
rumrunn6 is offline
Old 01-20-23, 07:14 PM
rumrunn6
rumrunn6's Avatar
got the 2.25" ice spikers mounted up. 30psi front 35psi rear. but then got them down to 22psi front 27psi? rear
rumrunn6 is offline
Likes For rumrunn6:
Old 01-21-23, 04:15 PM
wolfchild
got the 2.25" ice spiders mounted up. 30psi front 35psi rear. I'll tweak those when I take them out tomorrow
That last pic, looks like some of the studs are not installed all the way in, I would push them in and go for a ride on bare pavement to set the studs properly.
Old 01-21-23, 04:38 PM
rumrunn6
rumrunn6's Avatar
good catch. too bad I didn't read it until now, hehe. hope they stayed in. gotta check
rumrunn6 is offline
Old 01-22-23, 07:49 AM
rumrunn6
rumrunn6's Avatar
the one that looked really bad got pushed in. I did ride on some pavement getting to my ride yesterday, but not a lot. I did lose 1 stud
rumrunn6 is offline
Old 02-06-23, 05:25 PM
rumrunn6
rumrunn6's Avatar
loosing track but I think I got a 2nd ride in? anyway, bought some replacement studs & discovered I lost 6 studs in the rear tire. wonder if I will loose more
they go right in, easy peasy
rumrunn6 is offline
