Totally Tubular
#1951
Bikes: many
Quoted: 1442 Post(s)
Liked 1,387 Times
Challenge Strada Bianca 30mm on sale at BikeInn for $47 each:
https://www.bikeinn.com/bike/challen...de/137091210/p
As I understand it from a thread on The Paceline, Challenge is discontinuing the Paris-Roubaix and Strada Bianca products, folding them into their overall Strada product line. I'm full up on tubulars for the moment, so I won't be buying these. Just wanted to point out what looks like a decent deal.
#1952
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,828 Times
And in Tubular News:
First = Ronan McLaughlin sets Everesting record on Vittoria Corsa Speed 2.0 tubulars.
Inside Ronan McLaughlin's Everesting world record bike – VeloNews.com
Second = Deceuninck QuickStep will be riding Tour of Flanders on Specialized Hell of the North clinchers.
(sorry, can't find the reference - but read it earlier today.)
#1953
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4335 Post(s)
Liked 2,977 Times
It won't be the first time that clinchers will be used in the Tour of Flanders; Alexander Kristoff was on Vittoria Corsa tubeless clinchers when he raced to third place in the 2019 edition behind winner Alberto Bettiol. But he later regretted his choice after suffering numerous punctures in Paris-Roubaix that year.
#1954
Bikes: A few too many
Quoted: 1363 Post(s)
Liked 2,178 Times
After a really long search with no luck, I got a pm from obrentharris letting me know he saw these. I really lucked out and picked them up, NOS never glued and super supple!
Best, Ben
Conti 250 Sprinters in the elusive orange.
Best, Ben
Voltaire
Voltaire
#1955
Bikes: many
Liked 1,387 Times
Not sure if these have been outed before, but the price seems good:
https://www.ebay.com/itm/194014734547
#1956
If you don't have a flux brush handy a plastic bag will do to
apply glue in a pinch.
I've used the Conti glue with sucess, the LBS now has
panaracer and Hutchinson glue but I have no experience
with them.
A word on Tufo gluing tape.
I have to admit that I have used it, the normal one not the extreme tape.
I had no problem riding it, even in texas heat. I sometimes kept my bike
(and obviously tires) in my car where it got quite warm. The glue did
soften but not to the point where I felt it unsafe to ride.
The Tufo tape is very easy to use, and makes for an easy
introduction to tubulars.
I had the oppertunity to change one of the tires recently (sprinter
with enough wear that it was unsafe). Removing the tire was no more
difficult than a tubular glued with mastik or any other glue.
There was significant sticky residue left on the rims that cleaned
up (with a little difficulty) with goo gone (or goof off).
Marty
with them.
Marty
#1957
Quoted: 767 Post(s)
Liked 1,898 Times
Just saw these on sale and thought I'd pass it along:
https://www.excelsports.com/vittoria...g-tubular-tire
#1958
Quoted: 830 Post(s)
Liked 2,110 Times
@BFisher thanks for passing that along. Good deal on some nice tires. Question: When you click the Select option, what does "para/black" mean? Does anyone know if that is tanwall with black rubber as shown in the photo?
#1959
Quoted: 767 Post(s)
Liked 1,898 Times
#1961
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
Dirt cheap tubulars. $6.
$6 tire
I don't care how bad they are, surely they're worth $6.
https://planetcyclery.com/component/...120-dc-ms-spon
I bought a set a couple months ago, but haven't glued them yet.
$6 tire
Likes For Dylansbob:
#1963
Quoted: 1163 Post(s)
Liked 441 Times
$6 tire
$6 tire
#1964
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,186 Times
$6 tire
$6 tire
Bob
Bob
#1965
Quoted: 525 Post(s)
Liked 931 Times
I saw your post and decided to order 2 as well. My gut tells me it is a typo because when I cross checked these tires elsewhere they are listed as $75 tires. They are 28 mm which would work well with the Velocity Major Tom rims. I built the polished Major Tom rims into a road tubular wheelset, well to be precise I sourced the rims and hubs and my LBS master wheelbuilder built the wheels. But the Major Tom rims appear to be optimized for wider cyclocross tires.
I'm pretty sure you'll get them. They had been available late last year at the same price and I ordered a set. They are *very* tight. I haven't dealt with a fresh set of tires in 20yrs, but I don't remember having to stretch Rallys like this. Eventually I got it on a stretching wheel and hope to be glueing this weekend.
Here are some pics of what to expect. The valve stem is just an extender threaded onto a nipple on the tube. Might be a durability issue. I'll have to dig around to find some shorter ones.
Seems to run true, but I'd forgotten how much more you have to center big tubies.
Made in Thailand, but what big name tire isn't these days.
Not as garish as I had thought they'd look on
#1966
Liked 441 Times
Dylansbob - that is an odd arrangement for the valve. The Major Tom rims have the same “semi-aero” profile as A23’s and 43mm valves I believe are the correct length.
I figured there must be a “catch” as to why Planet Cyclery was selling these dirt cheap. Perhaps since they are so darn tight on the rims, they might be a good candidate for double sided tape? I have some red (3M equivalent) double sided tape that I might use. The tape is applied first to the rim in 2 pieces with a small opening opposite of the valve stem with the waxy outer tape left on while you slide the tight tire on and align it. The idea is that once the tire is where you want it, you can then peel back the outer waxy tape to expose the adhesive then to the tubular base tape. I have not tried this yet but hope it works....
Did you measure the width of the Velocitas inflated? Just curious if they will clear on my older Cannondale. Also, are these Maxxis tubulars the “fused” or “laminated” type? What I mean is that it appears they might not be manufactured by sewing the casing in the traditional manner but instead are built up with several overlapping plies that are somehow vulcanized or fused...
Another affordable tire to mention: Panaracer Race A Evo 2. The 26 mm width ones appear scarce but I purchased 2 of the 23mm width ones on-line for a little more than $20/each. I saw them in the clearance section of several online vendors (I got mine from an individual on eBay). Panaracer clinchers seem to be very underrated. I’m hoping for good results with these Panaracer tubulars, I just wish I had found the 26’s.
#1967
mycocyclist
Quoted: 909 Post(s)
Liked 811 Times
Rubenesque Tubbies
Dylansbob - that is an odd arrangement for the valve. The Major Tom rims have the same “semi-aero” profile as A23’s and 43mm valves I believe are the correct length....
"Another cool thing about the Velocitas is the valve. Most wheels that people are using tubs on these days are deep section, but the majority of tyres don't have removable valve cores to add an extension. The Velocitas come supplied with a 60mm anodised extension that screws on directly to the tub and if you need to go longer for time trial wheels of 80-100mm deep, for instance, then you can buy longer ones separately."
#1968
Quoted: 525 Post(s)
Liked 931 Times
That being said, dry mounted on an AVA rim they are measuring 27mm @80psi
#1969
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
At the age of 68, I am beginning my tubular journey. I had them on my full SL Trek 930 and the ride was harsh. I was not impressed. Through an accident of nature, I recently put that wheelset onto the PDG Paramount, made with Tange Prestige OS tubing A very stiff frame. They ride like a dream.
#1970
Quoted: 2337 Post(s)
Liked 2,812 Times
#1971
Quoted: 2432 Post(s)
Liked 638 Times
Is anyone running Kinlin TB25 Tubular rims? Wondering about the overall quality because I never had that brand before. I'm planning on ordering a wheelset from PWB for my Wabi Special single speed with Phill Wood hubs and they have those Kinlins as an option. It's a good price and the measurements I want for a 23mm tire. The Major Tom rims are wider.
https://www.prowheelbuilder.com/kinl...black-rim.html
#1972
Bikes: many
Liked 1,387 Times
I suppose I could have posted to the "where'd you ride today" thread, but there really wasn't anything special about my route. On the other hand, today was the first ride on my NOS-ish FMB tubulars:
I noticed when I set them up that a) they say "Made in Thailand," so definitely training tubies (cotton casing) and b) the base tapes were stamped "May 2011," so oldish NOS. They looked sorta like they had a coating on the base tape, but there was no indication they'd been mounted before (no dimples from eyelets, for example). They ride nice, as good as my Veloflex Vlaanderen I think.
#1973
Quoted: 1814 Post(s)
Liked 923 Times
Thanks for posting of these. Late last night I spent some time researching and found this:
That sounds like the Vittoria set up that they thankfully abandoned. Substantial PIA in practice- the stem can come loose on the mounted tire, and no replaceable valve core- recommend avoid.
#1974
mycocyclist
Quoted: 909 Post(s)
Liked 811 Times
Certainly for the price they are tires!
The valve core is removeable. I unscrewed one moments ago. And it does look like the stem is removable as well, though I haven't tried that yet.
At $6 each for a robust 28mm wide tire, I'm not asking a lot.
(With shipping and tax they did come to like ~$7 ?)
Last edited by machinist42; 04-24-21 at 10:06 AM. Reason: OCD Fine Tuning Editing of my Editing At This Point
#1975
Liked 923 Times
Thanks again for posting of these. My purchases arrived a couple of hours ago. They seem very sturdy, and should be suitable "touring tubulars" for my riders which can't accommodate anything wider. I figure I can run them at a lower pressure,
Too late!
The valve core is removeable. I removed one moments ago. And it does look like the stem is removable as well, though I haven't tried that yet.
(With shipping and tax they do come to like $7.50?)
Too late!
Yeah, I saw that they do have removeable cores, and the stems mentioned even as a fix for the Vittoria ones.
Good luck with the tires!
Likes For woodcraft:
