Totally Tubular
#2026
Has anyone tried the Bontrager R4 Classics tubs? 700x28c, and on half-price sale for $50, which is about the upper end of my tire budget these days.
https://www.trekbikes.com/us/en_US/e...Code=black_tan
Likes For tcpasley:
#2027
Quoted: 2432 Post(s)
Liked 638 Times
Man, I might get those for my modern disc bike. It's odd they don't list the thread count but I found a review on the clincher version and it's 320.
The good thing about tubular tires is you can always find high end ones on sale because they probably have trouble selling them.
#2028
Quoted: 2338 Post(s)
Liked 2,822 Times
just for reference challenge elite pro https://www.bikeforums.net/classic-v...-tubulars.html
#2029
I see that the weight is 370g, which may be a little heavy, and it has flat protection, which might make it less supple. Seems like it might be kind of like Continental Sprinter Gatorskins, but wider. That would probably be OK with me.
#2030
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
In preparation for today's ride I mounted a new, well actually newly-repaired by Tire Alert, Veloflex Criterium on the rear of my Masi last night. The tire had been prepped already but that was over a year ago. The rim had been prepped too and ridden a fair amount but suffered a flat on its last ride so I'd mounted a many-times-repaired spare, rode home and parked the bike to be dealt with later. So I put a new layer of Vittoria Mastic on both, waited a while, then mounted the tire on the rim.
The ride today went just fine but I experienced something I've experienced before. The tire, I believe the new rear one, makes a cyclic noise. At speed it sounds like tchck..tchck..tchck at the speed of the wheel rotation. A slower speed the crisp tchck stretches out to skriit...skriit...skriit, or even shriiiish....shriiiish....shriiiish of longer duration. It seems to be the glue pulling away, probably around the valve stem where Ive generally left it more lightly glued. Sometimes it goes away or is quiet on every other or every third rotation, but not for long.
Have any of you ever experienced this? Know how to make it stop? I'm thinking I might pull the tire off and thicken the mastic around the valve stem, but that's just a guess. I imagine I think I believe that I remember that it goes away eventually. But maybe not. What am I doing wrong?
Real cyclists use toe clips.
jimmuller
jimmuller
#2032
I've been riding Vittoria Paris Roubaix sew-ups on my Bates for commuting and regular rides. They ride quite nice and are robust and comfortable. The only thing I don't care for is the green sidewall. I think I paid $60 each for them. As an aside, round Rallys are better then they get credit for.
#2033
Liked 638 Times
#2034
Liked 2,822 Times
Vittoria came out with their new line up of tires a couple of years ago and they got rid of the green sidewall option. The only tubular they make now is the Rally. I don't really like their new stuff. My favorite clincher tire was the Open Corsa and that's discontinued. I don't like the tread on their new tires.
#2035
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
#2036
Yeah pave, my bad. I think it looks like I'm trying too hard to color coordinate with my bike.
Bates bar
they definitely are nice tires.
I rode in to work today. Foggy and misty in morning.
Bates bar
Likes For JJScaliger:
#2037
Liked 645 Times
Thank you for the reply.
jimmuller
jimmuller
#2038
Quoted: 1949 Post(s)
Liked 2,010 Times
I can get that noise at the valve if I don't follow directions and give the newly mounted tire a day or two to dry. I have pulled the tire away near the valve and injected more glue but now I wait.
#2039
Liked 2,010 Times
Consider getting some Stans if the valves have removable cores(mine do). The base tape on Rallys is a ***** to remove when patching a tube. A Vittoria Corsa spare will introduce you to nice tires and be an ok match to your Rallys. Get a pair if you see a deal. I think the Continentals have the fewest QC issues. Gatorskins ride like Rallys and unless you ride gravel are not worth it. Regular Spinters are my go to and often on sale.
Likes For Classtime:
#2040
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
Anyone used Stan's in an FMB or Veloflex? It has been my experience that it ruins the latex tube in the long run. Someone else have experience to share?
#2041
It's MY mountain
Liked 2,980 Times
Didn't work at least once.
Next time I put on new tubulars, I'll cut one open to see what it's like. Here's one that didn't use any sealant.
#2042
Quoted: 591 Post(s)
Liked 663 Times
My experience was it was all good for a while. Then go to pump up for a ride one day and sealant all over the place. Trip to Tire Alert followed.
#2043
Quoted: 834 Post(s)
Liked 2,126 Times
Untitled by gaucho777, on Flickr
#2044
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Pulled out my fixed gear bike to ride today, and lo and behold, the rear tubular tire was flat. No sign of a sealant leak, so I couldn't determine where the puncture is. Nothing fancy; just a YJ "3 for $50" tire, but I've had good luck with those. This one is on its second or third season and still has decent tread. Felt like riding rather than dealing with it, so a swapped the tubular wheels for clincher wheels and went for a ride. When I got back, I squirted some more Stan's inside (not easy, as the valve cores aren't removable), pumped it up, swished it around, and still no obvious sealant leak. I'll keep checking, and if I find it, I'll position the wheel with the leak site down, so the sealant can pool there and plug the hole. Otherwise, if it's still holding pressure tomorrow, I'll put it back in service and hope for the best.
#2045
Liked 2,010 Times
My understanding is that early formula Stans was not kind to latex tubes. But nowadays, there is nothing to worry about.
#2046
Liked 638 Times
I've read that Caffélatex is good for latex tubes, it produces a foam. You can buy it in a little 60ml pouch that fits in a jersey pocket.
#2047
Liked 645 Times
I've been putting Stans in Veloflex tires with latex tubes for several years now and have had no problem. The only would-not-fix problem I've had was a hole it would seal but not be able to hold the high pressure I like to ride. Still, it would hold enough to get me home.
jimmuller
jimmuller
#2048
Le savonnier
Bikes: I can count 'em on one hand
Quoted: 729 Post(s)
Liked 602 Times
I'm having an aluminum tubular disc wheelset built for my modern bike and I'm going to buy Panaracer Race C Evo3's for $70/pair.
Panaracer Race C Evo3 Tubular Tire SET: 700c (28") x 26mm - Bulk Discounts (NEW, PAIR) - Bike Recyclery
#2049
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,833 Times
Day before yesterday had a flat out on the road on a tire that looked totally 100% good, and has been reliable. About 7 miles from home, and all I found in the tread were a couple of very small, almost imperceptible cuts in the tread with nothing to extract.
The old bottle of Stan's liquid latex was in the backpack and a very old spare. No glue, no tape.
Long story short = The liquid latex did not work, even with a 2nd larger shot of liquid; but the old tubular held out til home, but went flat soon thereafter.
I will post mortem this flat tire rather than just pitch it, to find what took it out so catastrophically and irreparably.
Luckily my wakeup call to be prepared with better spare and tape to hold it in place. Luckily I had a bunch of CO2 cartridges as I kept trying the Stan's, before going to spare tire.
Remember, after so many miles, those trusty old tires, ain't so trusty.
#2050
Quoted: 1607 Post(s)
Liked 2,216 Times
OH! does this belong in the "I hate flat tires" thread?
