I would LOVE to see photos of your MTB conversion
#476
weirdo
If you want to keep the drivetrain 3 X 7, you can easily do that (low level parts, but they`ll function as well or better as what you have now), or you can go whole hog with a zillion Dollars worth of high end 10-speed parts, or anything in between. The only thing you won`t be able to do without frame mods is convert to disc brakes, although you could switch from straddle cantis to "V" brakes as long as you replace the levers at the same time.
EDIT: If you go looking for replacement or upgrade parts for anything, note that an unknowledgeable or unscrupulous vendor or LBS employee might well tell you that you can`t do this or that. You`ll be doing yourself a big favor to research "speeds", cable pull, hub width compatibilities and work arounds for yourself before starting. Sources such as Sheldon Brown, Park Tools, or Biketutor will give you all you need to know, or you can just ask on the mechanics or collectors subforums here on BFnet or any other big cycling discusion forum. People will gladly explain exactly what you can or can`t do for any stage of a refurbishing.
#477
This has been a work in progress but I believe it is finished now. Put it on the trainer to get her all dialed in.
1993 Trek 830 Antelope
#478
Bikes: 1994 Mongoose Switchback, 1983 Schwinn Voyageur SP, Cheap unnamed ssfg road bike
Finally got a bit better picture of mine.
#479
ghost on a machine
Bikes: Rivendell A. Homer Hilsen, Serotta Colorado Legend TG, Rivendell Roadeo, Surly Cross Check, Surly Big Dummy
Quoted: 7 Post(s)
1984 Specialized Stumpjumper. His name is Ludlow. Nic put this together for himself. Nic is 16.
Likes For Bike Hermit:
#480
Ludlow is a classy ride. I'd be tempted to put a 50 or 52 ring on the front and drop the bars down to a roadie position. Then I could get to trailhead and back a little bit faster.
#481
Raleigh MTB touring build
Just noticed this thread was started in 2007! I'm building a Raleigh Mountain Tour Seneca MTB as a touring bike. Bought the frame from a forum member. mparker, also a forum member, gave me the idea and found the frame in this forum. Here are a few photos of the frame when I purchased it:
A local bike builder has added some brazeons and had it powdercoated. Velocity sealed-bearing wheelset is on order. When the wheels arrive, I will get them and the frame from the builder and post more pics. Stay tuned!
smcrane
smcrane
Likes For mobile_simon:
#484
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12736 Post(s)
Liked 7,647 Times
Only "converting" I did was rigging up brakes and shifters out on the barends and put an other pair of barends further inboard for sleeping bag lashing. Also had a light daypack full of stuff.
#488
Bikes: 2019 Trek Stash 7, 1994 Specialized Epic 1986 Diamondback Ascent 1996 Klein Pulse Comp, 2006 Specialized Sequoia Elite
Quoted: 418 Post(s)
Liked 521 Times
Thanks, it was here.
Likes For sculbertson:
#491
That Paragon is excellent! Hard to find all the touring braze ons on an older mountain bike.
Nothing compares to the simple pleasure of a bike ride - JFK
#492
Agreed. I snatched it up when I saw it on Craigslist. Probably the only downside is the 1-1/4" threaded fork but you can work with it. I ended up using the Nitto column with a 1-1/8" threadless extender. That gave me the height I needed and endless options with stems.
#493
Did I catch a niner?
Bikes: Vassago Fisticuff/Surly Ogre/Surly Pugsley/Surly Pugsley 29+
Quoted: 9 Post(s)
I have two:
1995 Trek 800 Sport
My mother currently uses this one when she needs it, I used this for a lot of years around the city. I bought this bike new with my own money all those years ago.
2010 On-One Inbred
This one is actually my daily driver, and no I do not have any issues with the big tire on the front. I am currently building an IGH for this one.
1995 Trek 800 Sport
2010 On-One Inbred
#494
Bikes: None in ridable condition
Quoted: 148 Post(s)
Liked 643 Times
#495
Quoted: 148 Post(s)
Liked 643 Times
FYI Maurice: There's a supported tour that's going to use that road for part of it's route this summer. Oregon Bicycle Ride 2015
#497
smcrane
smcrane
#498
Call Chris King in Portland OR, and I suspect something compatible is available ..
All else the well equipped Pro Bike shop can do a little Head tube reaming and facing to dress it Out a mm or so.
whats the head tube Bore Now? was it masked off and so no powder in side?
#499
If anyone who is considering converting a vintage MTB to a touring bike, make sure that you have a headset that fits, or that you can get one that fits. You must measure the inside diameter of the headtube to be certain. If the headtube is an odd size, a builder can braze in an adapter so that more standard-sized headsets will fit. This is an extremely important issue that you should address before doing anything else to the frame. I had a problem because we didn't discover that the headtube was an odd size until the frame had been powdercoated.
#500
