Disc Brakes Letting Some Pros Down
Zen Master
Got it. So let me see if this sums it up, then -
You came across a statement from a pro rider that was so dumb that it didn't merit discussion. Since you wanted to generate a discussion, you decided to adopt the position of an intellectually challenged devil's advocate.
Is that about right?
Ron - Tucson, AZ
Ron - Tucson, AZ
Quoted: 4745 Post(s)
Liked 3,861 Times
Regarding the spokes - was there any chance he was riding non-metallic ones? The resin of carbon fiber spokes might not be high temperature stuff if it was going on a non-rim brake wheel and no one thought of disc temps.
Quoted: 20791 Post(s)
Liked 9,436 Times
A lot of discussion? The thread just limped in to a second page and more than half of the posts are clumsy devil's advocacy attempts or responses to them. Larry could flatulate and the resulting discussion would run laps around this.
Zen Master
You assumed I was speaking about here on this forum; I wasn't.
Ron - Tucson, AZ
Ron - Tucson, AZ
Quoted: 18320 Post(s)
Liked 15,298 Times
Like that never happened before—for good reason.
Likes For indyfabz:
Quoted: 3192 Post(s)
Liked 2,460 Times
I thought we just had a thread about this within the last month or two. The sad part about it is, every time one starts now, I'm thinking sock.
OM boy
Bikes: a bunch
Quoted: 502 Post(s)
Liked 623 Times
This
not doubting he had some wheel issues/broken spoke; but blaming it on overheating rotors, seems about as far fetched as can possibly be.
To have some degree of metal failure, at the very extreme of the hub flange, without affecting any of the other aspects of the hub function (like sealed bearings) seems ... not likely.
The amount of heat would certainly cause other failures well before.
Not doubting there was a wheel issue - but likely one of poorly built and subject to unbalanced stresses - wheel.
Considering what the team mechs need to do for every bike, wheel, and backup bikes, wheels, everything else, one can;t expect a full detailed inspection of everything...
And spokes are known to break...
he wasn't the only rider who had a bad/tough day on BlockHaus, especially Tesfatsion - also rotor overheating ?
Ride On
Yuri
Ride On
Yuri
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
At the pro level, especially Pro Tour EVERY last thing should be getting checked after every stage. There are 8 riders and most teams have 5-6-7 mechanics for Grand Tours. Every bike, including spares, and every wheel get cleaned and looked at every day. Some of the GC guys have their own dedicated mechanic that only has to worry about their bikes. This **** gets taken very seriously.
Happy With My Bikes
Quoted: 868 Post(s)
Liked 2,278 Times
I like my Domane with disc brakes, a pro bike racer would hate it. I like my Honda Civic, a pro stock car driver would hate it. Why would the average person eschew either one based on a pro's opinion when it suits the use of the average person?
Likes For Chuck M:
In the great words of coach Ron Washington "That's how baseball go" and I feel like that applies here.
Quoted: 18883 Post(s)
Liked 10,645 Times
Likes For Seattle Forrest:
Zen Master
Liked 10,645 Times
Well I already broke all my spokes by using disc brakes so what else am I supposed to do?
Quoted: 4274 Post(s)
Liked 4,712 Times
A more plausible theory (if we insist on linking this failure to disc brakes) is the extra torque applied to the wheel (more specifically through the spokes due to the load path) under braking with disc brakes vs rim brakes. The wheel should be designed with this increased braking torque in mind (along with the fork), but these are likely to be super-lightweight wheels riding a bit closer to the limit. Even so, we don't appear to be having a peloton wide issue here. Just one guy who had an unexplained spoke failure at a critical time. It's not like spokes have never failed before disc brakes appeared.
Likes For PeteHski:
Zen Master
My guess is that there's a range of braking habits across the field, and perhaps those who practice very hard late braking, transfer more energy into the brakes, or at least put that heat into them in a more concentrated, and repeated fashion.
I wouldn't know if it's enough to fatigue the wheel, but it certainly might push the limits of the brakes, and occasionally send some riders off the road when they cannot slow enough for an upcoming turn.
Ron - Tucson, AZ
Ron - Tucson, AZ
Liked 10,645 Times
Today I learned the problem with disc brakes is people can't slow down in time to turn.
Zen Master
ignominious poltroon
Quoted: 2185 Post(s)
Liked 3,337 Times
What is the physical mechanism by which heat is transferred from the pad/rotor interface to the spokes?
Liked 3,337 Times
Zen Master
Liked 3,337 Times
Likes For Polaris OBark:
Quoted: 3906 Post(s)
Liked 7,182 Times
The heat is carried by pheromones. That's why this problem only affects young, virile pro riders and not old guys on Internet forums. I break several spokes per week, because I'm a veritable pheromone factory.
Likes For tomato coupe:
Zen Master
I don't believe disc wheels cost a pro significant time across a race route, don't believe disc brakes transfer any significant heat to spokes, where did I say anything like that.
Ron - Tucson, AZ
Ron - Tucson, AZ
Quoted: 6882 Post(s)
Liked 10,873 Times
In other words, you are trying to put other words in my mouth. I shared a story and posed one of many possible viewpoints, for fun. Que the minions!!
Likes For Koyote:
Hear myself getting fat
Bikes: Sir Velo A Sparrow
Quoted: 335 Post(s)
Liked 265 Times
After his switch to rim brakes Wilco was able to get 4th on todays stage!
Rim brake for life!…
<whispers>
oh? Still rode those blades of death?
nevermind…
<whispers>
nevermind…
