All things being equal, which groupset?
Old 03-16-15, 06:27 PM
Plainsman
Quoted: 169 Post(s)
Liked 40 Times in 30 Posts
Let's say you have a choice between two brand new groupsets? One is 6700 10 speed Ultegra compact, the other is 5800 11 speed 105 compact. Same bike frame, wheelset, etc. Gearing (ability to have a huge rear cog) is not an issue. Just curious, which do you take and why?
Plainsman is offline
Old 03-16-15, 06:36 PM
datlas
Should Be More Popular
datlas's Avatar
Quoted: 22570 Post(s)
Liked 8,918 Times in 4,152 Posts
Tough call. Both are good.
If this would be my only bike I would lean towards 5800.
Since I have other road bikes running 10 speed, personally I would pick 6700 to maintain compatibility.
Originally Posted by rjones28
Addiction is all about class.
datlas is offline
Old 03-16-15, 06:43 PM
Shuffleman
Shuffleman's Avatar
Bikes: Colnago CLX,GT Karakoram,Giant Revel, Kona Honk_ Tonk
Quoted: 149 Post(s)
I would probably go with the least expensive one. They are both excellent quality groupsets but if I had to pick between the 2 I would probably go with the Ultegra. I think that it is just a little better than the 105 but truthfully I would not cry over either one.
One could make the case very easily for the 11 speed as it seems to be the wave of the current and future.
Of course I am a Campy fan so I would prefer to shift over to Athena or Record instead but that is a different debate.
Shuffleman is offline
Old 03-16-15, 06:48 PM
Plainsman
Quoted: 169 Post(s)
Interesting...and to even the playing field, let's say that they are available for the exact same cost!
Old 03-16-15, 06:58 PM
GuitarBob
Kit doesn't match
GuitarBob's Avatar
Bikes: 5
Quoted: 187 Post(s)
Liked 27 Times in 19 Posts
I'd go with the 11 speed 105 as it might be somewhat more future-proof. As others have noted, though, both are dandy.
GuitarBob is offline
Old 03-16-15, 06:59 PM
rms13
Quoted: 276 Post(s)
Liked 6 Times in 3 Posts
It's kind of a toss up. 5800 gives you extra gear and marginally better shifting and braking but 6700 has slightly better fit and finish and slightly lighter. Hood ergonomics are also different but it's a personal opinion as to which is more comfortable.
rms13 is offline
Old 03-16-15, 07:38 PM
Silvercivic27
Silvercivic27's Avatar
Bikes: Colnago, Cervelo, Scott
Quoted: 191 Post(s)
Silvercivic27 is offline
Old 03-16-15, 08:24 PM
Stucky
Old Fart
Stucky's Avatar
Bikes: '97 Klein Quantum '16 Gravity Knockout
Quoted: 163 Post(s)
Liked 3 Times in 2 Posts
6700. You won't notice any difference when riding...but the way I look at it, I'd much rather have the higher groupset than one extra cog. I like the old 9-speed Dura Ace on my one bike, better than the 10-speed Ultgra on my late-model bike (just aesthetics- no difference in performance)- and so I'd be willing to bet that I'd prefer last generation Ultegra to current 105. Brand new Chevy, or a few-year-old Town Car? I'd go with the Town Car. My ancient Dura Ace still impresses me. I'm sure 105 of the same vintage would be just fine...but I wouldn't be still loving it as much. Go Ultegra!
Stucky is offline
Old 03-16-15, 08:34 PM
fstshrk
fstshrk's Avatar
Quoted: 20 Post(s)
Liked 5 Times in 3 Posts
The extra cog is not noticeable. Get the 6700. That is a very solid groupset.
Better yet, if you can find a like new 7800, go with that. Best groupset ever made by Shimano.
fstshrk is offline
Old 03-16-15, 08:47 PM
KLiNCK
Optically Corrected
KLiNCK's Avatar
Bikes: 2012 Specialized Sirrus , 2012 Specialized Roubaix Comp
Quoted: 106 Post(s)
Liked 67 Times in 30 Posts
Personally, I'd go with the 6700 10 speed Ultegra. The 5800 11 speed 105 would be good as well, but as previously mentioned, I'd bypass the extra cog in favor of the Ultegras' "step up" in Shimanos' groupset hierarchy. I have the 6700 groupset on my Roubaix and it shifts like butter! Replacement chains are also cheaper for 10 speed vs. 11 speed. I don't think that 6700 (or any 10 speed) replacement parts will be hard to source for quite a while.
KLiNCK is offline
Old 03-16-15, 08:58 PM
Up North
Bikes: P1 Domane Di2, SLR Emonda Di2, Trek Farley 9 Fatbike
Quoted: 10 Post(s)
Yep, Ultegra over 105.
Up North is offline
Old 03-16-15, 09:39 PM
cale
cale's Avatar
Bikes: Kuota Ksano. Litespeed T5 gravel - brilliant!
Liked 4 Times in 4 Posts
I don't see any point in getting older Ultegra unless you're a weight weenie.
cale is offline
Old 03-16-15, 09:46 PM
bt
5800, no question.
lol at old stuff being hierarchy.
yes, 7800 was good like mentioned but that's in part because it's successor was so bad (7900).
Also that was the first (6700 and 7900) under the bar tape group and shifting problems are notorious.
https://www.bikeradar.com/us/gear/cat...roupset-35500/
Shift performance – hidden cables but more friction
There's simply no way around it: the new hidden cables look better but the more convoluted routing also yields noticeably more friction than before – and unfortunately, Shimano's 1:2 cable pull ratio makes it more sensitive to that friction than its main competition.
bt is offline
Old 03-16-15, 09:57 PM
wallrat
Quoted: 18 Post(s)
I'd go Ultegra 10 speed. I don't think 1 extra gear makes much of a difference on a road bike with a double in the front. On a mountain bike going 1x, that 11th gear in the back vastly improves the setup. On a 2x, not so much.
wallrat is offline
Old 03-16-15, 10:04 PM
Stucky
Old Fart
Stucky's Avatar
Quoted: 163 Post(s)
Originally Posted by bt
5800, no question.
IMO, 7700 was the pinnacle! -and old as it is, I still prefer it to anything. Aesthetically (which is about 99% of the difference between the different levels and model years) the newer stuff seems to be going downhill.
Stucky is offline
Old 03-16-15, 10:14 PM
tekhna
5800, no question.
Also that was the first (6700) under the bar tape group and shifting problems are notorious.
Also agree, 5800, no question. Shimano has done itself a disservice with how good 11 speed 105 is. There's no compelling reason to ride anything else. And I ride Campy.
Setting aside 10 vs 11, the 5800 shifting is superb.
tekhna is offline
Old 03-16-15, 10:18 PM
bt
correct^^^^
there are some bad answers in this thread,, lol
bt is offline
Old 03-16-15, 10:38 PM
Astrozombie
Astrozombie's Avatar
Bikes: Diamondback Insight, Motobecane Mirage
Quoted: 14 Post(s)
Liked 5 Times in 4 Posts
Ultegra
Astrozombie is offline
Old 03-16-15, 10:58 PM
BoSoxYacht
BoSoxYacht's Avatar
Location: take your time, enjoy the scenery, it will be there when you get to it
Bikes: 07 IRO BFGB fixed-gear, 07 Pedal Force RS
correct^^^^
I agree with you both.
BoSoxYacht is offline
Old 03-16-15, 11:41 PM
raisinberry777
Quoted: 61 Post(s)
Completely agree, the new 5800 shifting is absolutely superb.
raisinberry777 is offline
Old 03-17-15, 12:53 AM
sam_cyclist
Neither. Tiagra 4600 shifts just as well as 105 or ultegra, and has a beautiful finish.
Take the hundreds of dollars saved and invest in a set of lightweight wheels, where the weight savings actually matters.
sam_cyclist is offline
Old 03-17-15, 01:21 AM
dtrain
L-I-V-I-N
dtrain's Avatar
^maybe a hundred...
"The older you do get, the more rules they're gonna try to get you to follow. You just gotta keep livin', man, L-I-V-I-N." - Wooderson
'14 carbon Synapse - '12 CAAD 10 5 - '99 Gary Fisher Big Sur
dtrain is offline
Old 03-17-15, 02:06 AM
BoSoxYacht
BoSoxYacht's Avatar
Incorrect
Old 03-17-15, 02:23 AM
khuon
DEADBEEF
khuon's Avatar
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times in 4 Posts
I'll second that statement. I held onto my old 7700 group until just recently when it became apparent to me that 6800 and 9000 had proven themselves and had enough advancements to offer to make it compelling to upgrade. Actually I was about to go full 9000 but found a striking deal that allowed me to go to a mainly Ultegra Di2 blended along with some Dura-Ace Di2 and FSA bits for not that much more.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
khuon is offline
Old 03-17-15, 06:25 AM
Shuffleman
Shuffleman's Avatar
Quoted: 149 Post(s)
For the same cost I would have picked the ultegra option as the extra cog is nice but not that important.
