Zipp 303S owners... Please step on in.
I agree. I always downvoted for this but hookless is crap. In essence yeah the wheels are indeed lighter but once you account for valves, sealant, and the heavy ass tubeless tires, a hookless wheelset can weigh just as much if not more than a wheelset with latex tubes. Secondly the whole idea of running a race bike with skinny tires hookless and at 72 psi or less is kind of crazy. Hookless is great on larger tires for gravel and MTB but inherently hookless is simply less secure. Oh then factor in the cost and availability of hookless tires and I just don't get why hookless is a thing
Race bikes are no longer all run on skinny tires. 28mm is already already being used and a 200 pound rider only needs about 65 psi.
Quoted: 3948 Post(s)
Liked 7,291 Times
Hookless still comes up with a suggested pressure that's 4psi lower, with the same 25mm IW. Depending on the brand, hookless is all that's offered. Buy some other brand and use a little more pressure Cinelli guess. I believe that there's also an alleged aerodynamic advantage to hookless. Users can buy whichever they want, if someone offers it. I'm buying hookless.
Lets not forget that the Zipp warranty is LIFETIME and includes damage due to potholes, rocks and what have you so yes, that matters to me.
Zipp name ok, $1300 great, but 1500g for a carbon wheelset is nothing special.
Again if the Zipp name and I will say LBS warranty and CS matter to you then yeah at $1300 these are fine for gravel but there are cheaper, lighter, and or better performing wheels if you aren't looking for a name brand LBS experience
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
Likes For garysol1:
Is there any difference in handling when going from hooked to hook-less tires of the same size, pressure and inner width? One thing not mentioned often is feedback. I feel much more confident bombing into a corner on wide, low psi, tubeless performance wheels/ tires. I feel more connected with the road. I know hook-less provide an aero advantage, but I wonder if they're equally confidence inspiring while cutting a corner.
Quoted: 1456 Post(s)
Liked 1,477 Times
In terms of confidence in the system - I've ripped through many hard corners during CX racing on hookless rims with 33mm tires at 25psi. I've never had one come off. My confidence on this setup is the same or greater than it is on a glued tubular.
Liked 1,477 Times
If you like skinny tires at high pressure - go for it. I don't think anyone is going to try to convince you that tubeless makes sense for this. This isn't typical for the road riders I know - most have moved up to 25-28mm tires and some go even wider, and we all run much lower pressure than we were 20 years ago.
On the topic of the hooks being more secure, maybe - but I don't hear many stories of hookless tires suddenly coming off the rim, and it's definitely not something I've experienced after using hookless rims for the last 18 months or so. This mostly seems like a made up problem that doesn't really exist.
In terms of availability, most if not all of the top tubeless road tires are hookless compatible now. Cost? Sure, tubeless tires are a little more expensive than tubed tires, but this is a thread about $1300 aftermarket carbon wheels that will be plugged into bikes costing 3-4x as much. Can you really argue this point with a straight face? If you're fretting over $40 a year in extra cost on your fancy road bike with carbon race wheels, you've seriously messed up somewhere.
I don't think anyone claims that the Zipp 303S is the lightest or best weight/$$$ purchase out there. 1500g is pretty average for a 45mm deep carbon wheelset and Zipp's higher end 303 Firecrest is a more brag-worthy 1300g. I'm also not sure there's any real performance difference between Zipp and any of the generic Chinese carbon wheels out there - but Zipp develops their own products, and they're a trusted name US brand that offers a lifetime warranty. That's a factor for many, and for me it definitely pushed the decision into buying Zipps.
Likes For msu2001la:
If you want a deep profile wheels and light weight, be prepared to pay $3-4,000 for a set. Most people don't compete, so there's not much point in paying maybe 4 times as much to save a little weight, but it's your money. BTLOS offers a large number of rim configurations that they sell separately or as built wheels. I've got 303s wheels and one set of BTLOS, with another set on order. I get mine with no spoke access holes, so no rim tape required. Just add a note to your order. Two sets cost about $1600. I've never had a warranty claim on any cycling component in 35 years, so it's not much of a consideration for me. BTLOS has excellent service by e-mail. Just keep in mind the time difference.
Below is Enve's take on hookless.
https://www.enve.com/journal/behind-...20construction
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,531 Times
In my case, if I were to run road tubeless, I'd want 28mm tires and also be inflated to approx 80 psi. Hence, no interest in hookless. It's a simple decision for me. ymmv
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
You are confusing a lot of talking points here. Hooked and hookless can both be tubeless, and both use the same valves, sealant and "heavy ass tubeless tires". It seems like your complaints here are about tubeless in general, and have nothing to do with the hook design.
Agree, 1500g for $1300 is not going to get the weight weenies very excited. The warranty is nice though.
I've never heard of BTLOS, but I considered buying wheels from Light Bicycle and was pricing out something in the $800-$900 range at around 1450g, and decided to buy the Zipp 303S instead.
Likes For phrantic09:
Why would you want to run 80psi in a 28mm tire running tubeless? Serious question.
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
*** Assuming a Merlin Cyrene rim brake bike.
Liked 7,291 Times
Finding a hookless rim brake rim might be difficult. Hookless goes hand in hand with disc brakes. A 23mm IW rim would support a 230 pound rider with 70 psi. https://axs.sram.com/guides/tire/pressure
Advocatus Diaboli
Liked 1,531 Times
Liked 7,291 Times
Advocatus Diaboli
Liked 1,531 Times
Liked 7,291 Times
Liked 1,477 Times
Since the topic of this thread is the Zipp 303S wheelset, it seems like it would make sense to use Zipp's tire pressure calculator.
For a 205lb rider on an 18lb road bike running 28mm standard tubeless tires on the 303S (21mm i.d. hookless rim), that calculator shows 64.6 PSI front/ 68.76 PSI rear. They suggest 58-61psi for wet conditions.
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
Likes For garysol1:
Liked 7,291 Times
Liked 1,477 Times
I'm not sure why anyone would ignore Zipp's calculator in a thread about Zipp wheels, but yup - that Perelli chart and the unknown chart above do show high numbers.
Advocatus Diaboli
Liked 1,531 Times
I'd generally go with whatever the wheel manufacturer recommends, but you do you. Enve's calculator gives similar results as Zipp's.
Zipp's calculator is just developed to progress and end at 73psi for the max weight they want to market their wheel as being able to handle (250lb rider, in order to compete with lot of other wheelmakers who want to say their wheels can handle 250lbs). The 303S I think is optimized for a 28mm tire, so with that width, the calculator results in 73psi for a 250lb rider.
Likes For Sy Reene:
Advocatus Diaboli
Liked 1,531 Times
Liked 7,291 Times
I think the salient issue is that numbers provided by tire pressure calculators should only be considered approximate starting points. There is no universal agreement about the "correct" tire pressure for a given set of conditions, and the range of results from different calculators illustrates that.
Liked 1,477 Times
Maybe they know what their tires can manage. The unknown chart is Silca's 'pro' calculator.
