1991 Diamondback Apex
Bikes: 1991 Diamondback Apex, 2015 Trek Verve 3, 2020 Specialized Diverge
Quoted: 143 Post(s)
Liked 116 Times
I have a 1991 Diamondback Apex that has a very aggressive geometry. I would like to raise the handlebars and reduce the reach. Does anybody have any experience with this? I have already raised the handlebars as much as the stock configuration will allow. The stem and tube are one piece. I am thinking I will need to replace that integrated piece with something taller and possibly adjustable. Want to make it more comfortable to ride.
Likes For daverup:
Quoted: 143 Post(s)
Liked 116 Times
Yes, something like that is what I have in mind. Looking for technical details of how I would do that.
Bikes: A bunch of old bikes.
Quoted: 265 Post(s)
Liked 821 Times
I didn't change the stem, since it holds the front brake cable outer. I don't know what exact bars I used, it was old when I got it.
Check out Soma Sparrow bars, they are pretty close. You'll probably have to change some cables.
Likes For daverup:
Quoted: 143 Post(s)
Liked 116 Times
I was thinking I would need something like the following:
https://www.benscycle.com/zoom-quick...iABEgLHIPD_BwE
And I think you are right that I will need new cables.
Likes For Sorg67:
Quoted: 752 Post(s)
Liked 733 Times
Likes For bark_eater:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,445 Times
This is what I did for my buddy's DB, a taller quill riser stem with a riser bar. The difference in reach and lift is considerable, and the greater sweep of the bars also helps. Both stems are at the max height marks.
Likes For thumpism:
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 131 Times
I just used a quill stem with less reach and more rise. It did not have the cable stop built in so I used one that went below the headset nut. I think this is a 1992 DB Apex.
Likes For BradH:
Catching Smallmouth
Quoted: 88 Post(s)
Liked 131 Times
Something like this. As long as your headset is 1 1/8" and you have room in your headset stack. You may need to loose a washer or reflector.
Likes For BradH:
