Road carbon fork fit
Hi,
I have problems in finding a carbon tapered fork 1 1/8 to 1 1/4 for a road bike. Grateful if somebody can clarify:
1. Road bike forks for sale usually have cylindrical crown as shown below. What kind of bearing (headset) they use? The existing bearing, attached in picture, has a conical shape, so it does not fit?
2. How important is fork rake? Do I risk to choose a wrong fork, since it is difficult to measure rake and find an identical replacement?
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
here's a Simplified primer on Rake and TRAIL... Bicycle people use the terms incorrectly... they also confuse offset with rake, further muddying the Bicycle waters... the drawing in this piece shows Zero offset...that won't be seen in the real world .https://www.cycleworld.com/2015/05/2...ake-and-trail/
here's the Bicycle world version of the whole steering thing... https://www.ebcyclinglaw.com/bicycle...teering%20axis.
in the automotive world.. "Rake" or "Steering head angle" is called CASTER... and CAMBER is a sideways version of CASTER.
the "offset" is used to alter trail and aid steering ease. You may or may not be able to sense small changes in this spec. A bike with ZERO Rake (Steering Head angle) will put you on your noggin in a hurry if you aren't prepared. Tiny differences in the specifications are the subject of Endless debate. Any number of Opinions exist.... feel free to look up several! Expect such a discussion to develop here shortly. I won't choose to join it.
Likes For maddog34:
Quoted: 514 Post(s)
Liked 448 Times
Bikes with less trail are more responsive to handlebar steering inputs. Bikes with more trail are more responsive to weight shift steering inputs. The steering tends to feel "heavy" at the handlebar. Obviously, you need a bit of both.
Generally, with a head angle of 72-73.5 degrees, you can't go wrong with 43-45 mm of offset. With a head angle of 72 degrees or less, or if you like a lighter feel over rough terrain, look for 45-50 mm.
Likes For oldbobcat:
Head angle is 73.5, so it means I should look for 43-45 mm.
Am I wrong, or the offer for replacement road carbon forks seriously decreased? I encounter big difficulties to find a good carbon tapered fork 1 1/4 - 1 1/8, for rim brakes, not to mention the price....
Quoted: 514 Post(s)
Liked 448 Times
Here's one: rim brake & QR, 1 1/8 at the stem, 1 1/4 at the crown, 43 or 45 mm offset. https://www.jensonusa.com/ENVE-Carbon-20-Road-Fork
Thanks, it looks ok. However, hard to find in Europe. Taxes and transport from USA would raise the price from 450 to some 600. I'll still search in EU, to make some savings.
Quoted: 1109 Post(s)
Liked 1,200 Times
Have you looked at Columbus forks? Last time I looked, there was a bunch of different versions, and many online sellers. Good quality, not cheap, but commensurate with quality.
Yes, but you can not really find them in EU. At least not tapered 1 1/4 to 1 1/8 for rim brakes...
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
Here are two online options should your local shop not be able to order them:
https://ciclicorsa.com/shop/futura-caliper-slx-1-1-4/
https://www.bike24.com/p2275600.html
Here is also a list of their distributors:
https://www.columbus1919.com/en/distributors-en/ (of which Cicli Corsa is one of them)
If nothing else I am pretty sure QBP has a European side and the Whisky Parts Co. forks are quite excellent and those are a house brand of QBP.
Quoted: 514 Post(s)
Liked 448 Times
I used to sneak into QBP using my old employer's login, just to see what's available. But that account is gone. If you have a local shop I always recommend checking with them first. Unless you hate them.
