Why I hate cottered cranksets...
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,393 Times
Not to toot my own horn, uh no scratch that, YES to toot my own horn... I mentioned three different presses in post #9. Including the awesome Bikesmith, which I mentioned twice (with links both times) and which I recommended people buy.
What do I win? Is there an award for "Most Thirsty"?
Well, make it another vote for the Bikesmith tool as the affordable no-brainer. And a vote for me to get some shuteye.
-Kurt
Likes For cudak888:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
A cotter press is no guarantee that even a virgin cotter with thick 7mm+ (Whitworth fine-pitch) stud will press free without bending.
If such a valuable cotter shows even a hint of bending, apply heat to the smoke point before tightening the cotter press further.
I leave the cotter press in place, tensioned, while applying heating cycles, which I feel helps the cotter to migrate in the free direction.
Liked 4,393 Times
This. Saved my bacon more than once.
-Kurt
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
Ergo, just but the tool.
Likes For smontanaro:
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,195 Times
Bob
Bob
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
Shoot. Now I know I'm half-asleep to have forgotten that big honkin (pun intended, @Mad Honk has the same one) VAR tool posted here and the others you mentioned.
-Kurt
-Kurt
Likes For Chuck M:
Quoted: 767 Post(s)
Liked 1,898 Times
Treatland.tv, a moped parts supplier out of CA, also sells a pin press. $38.
I have one. It required a little modification - removal of about 1/8 inch of material from each end of the "C". Otherwise it works well. Has removed several pins easily.
Bikes: Too, too many....
Quoted: 125 Post(s)
Liked 130 Times
And of course, suspend the bike from the ceiling and support the crank arm at the BB with a vertical hollow steel tube resting solidly on the floor before you hit it with the hammer so you do not brinnel the races or mark the crank shaft....
https://www.rexnord.com/blog/article...-is-brinelling
Likes For Binky:
Quoted: 964 Post(s)
Liked 1,451 Times
Is the Bikesmiths press made of steel? Or aluminum? What size and pitch is the bolt? Anything anyone wishes it had but it doesn't?
I'd been thinking I should machine one for myself out of some old scrap steel blocks that I have. May as well do that before I need it. I'm thinking of putting cottered cranks on an old constructeur bike I have.
Friendship is Magic
Bikes: old ones
Quoted: 26413 Post(s)
Liked 10,379 Times
I learned in the '60s and early '70s, when we didn't have the luxury of "hating" cotters, you just had to work on them, to be a bike mechanic, because most bikes had 'em. Well, Schwinn/Huffy/Murray/Columbia had one-piece, but those people never brought their bike to a bike shop for repair. A few fancy race bikes had cotterless (and were a joy to work on), but most of the bikes that came in for repair where I worked had cotters. We had a half-price winter overhaul deal, to keep the doors open in the off-season, so sometimes I'd be taking cotters out multiple times per day.
We only fired up the propane torch for super stubborn ones, but now that I have a heat gun, I'd go for the heat as a "first resort", not only as a last resort. Heat 'til the grease starts smoking, then a little more. Strike while the iron is hot!
Mark B
Mark B
Likes For 3alarmer:
Friendship is Magic
Bikes: old ones
Liked 10,379 Times
Bikes: many
Liked 1,392 Times
I have the earlier (I think) design without the curved edges. I need to occasionally remove a chainring bolt for clearance. Looking at a picture of the current product, I think it would fit a bit better.
blahblahblah chrome moly
Quoted: 1173 Post(s)
Liked 2,569 Times
Well, Mark who makes them says that of the many he's sold, a few that got heavily used eventually wore out. He considered making them of alloy steel, but it would double the cost, so he opted for keeping them affordable for the 99.9% who won't wear one out. But if you're making your own, why not make it out of 4140 or tool steel?
Other than that, it's a pretty refined design, so you should probably try to copy it as faithfully as you can. Definitely use a heat-treated alloy steel bolt for the pusher. Cupped on the end to match the typical radius on cotters.
Mark B
Mark B
Likes For bulgie:
Edumacator
Quoted: 2439 Post(s)
Liked 3,122 Times
It just so happens I bought that one Saturday. It was reasonable enough to warrant adding to the tool box.
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 165 Post(s)
Liked 267 Times
Send all your bikes with those pesky cottered cranks to me, I'll take care of them.
I'm always looking for an excuse to invest in a set of gorgeous Durax Service Course cranks, and would never stray simply due to a cotter pin.
One of these days I'll find a Var cotter tool and be good to go. Two of the three that I know of in this city happen to belong to my old employer, and they get used just about every day.
Edumacator
Liked 3,122 Times
Oops. Double post.
I had to deal with 2 pairs of cottered cranks recently. Removal was OK, but what I hate is waiting for weeks to get the new 9mm cotters I ordered.
Quoted: 1303 Post(s)
Liked 1,910 Times
Jdawg,
I went to the hardware store and spent $3.65 for an 8 grade bolt and two nuts and then went to the scrap yard and got a bit of C-channel and spent a bit of time with the welder tonight. So the $4 tool is ready to ship and will go out tomorrow, and you won't hate cotters anymore. Smiles, MH
Top is the $4 tool I made today to send to you. Bottom is the Park tool I have had for about 35 years. They both work the same way.
Likes For Mad Honk:
Edumacator
Liked 3,122 Times
Jdawg,
Myrtle Beach Crab
Bikes: enough one would think, but thinking isn't my strong point
Quoted: 271 Post(s)
Liked 541 Times
I've always wished that component makers would make ornate and beautiful cranksets that were square taper instead of cottered. i know this thread isn't about that, but that particular area of a road bike would be a great canvas for that sort of thing...
Likes For cocoabeachcrab:
Quoted: 478 Post(s)
Liked 634 Times
As to improvements to the Bikesmith press, only one and that would be that as already mentioned on some drive side arms it can be very tight, not just for the jaws but depending on the crank involved it can be hard to get a suitable wrench on the bolt, and also hard to get a socket on it to extend it.....I would be nice though not necessary to have alternative press bolts that have the nice concave end but with smaller heads or a socket head. For reference the crank I had the most trouble with was off a 1938 CCM. All of the english and french stuff I have done had no issues.
Oh and I was delighted to find the LBS (vintage friendly) had correct cotters of the same manufacture as Mike's good ones in stock. Saved a lot of waiting and cross border nonsense.
Liked 4,393 Times
I'd rather see it with a shallower profile at the cotter and a smaller hex on the shaft that can take a deep socket and a ratchet, which would be less prone to slippage over a large wrench, as now.
It'd also be nice to see an alternate bolt that tapers at the end for cotters that do break off in the crank. Last time that happened, I had to unscrew the BB behind the crank - thankfully, it was the left arm - and press the cotter out by centering a punch on it in the hydraulic press. Not fun worrying whether the punch will go flying either - I clamped it with a vise grip to hold it if it did slip.
I'd love to buy Mad Honk's VAR press at this point, but cannot justify it. Yet. Maybe a trade, MH? Hint hint.
-Kurt
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 359 Post(s)
Liked 465 Times
I think I ordered my Bikesmith cotter press from Mark in 2017, when I got my '50 Raleigh Superbe - it has a more rounded, refined looking shape, and fits everything I've needed it to fit so far. I hadn't worked on cottered cranks before, and the tool was of immense help. I was initially hesitant, thinking that I wouldn't use it so much after the Raleigh was back in shape, and of course I've used it a whole bunch of times since and I wouldn't mess around with cottered cranks without it. '70s Peugeot cottered crank removal x2, servicing someone else's old battered three-speed x3, installing Williams crank on my Sun Wasp, installing Williams crank on my '64 Triumph...
Likes For Ged117:
Liked 4,393 Times
Mark makes a good tool, regardless.
-Kurt
